    The A show (post your Thea images)
    152 Posts 41 Posters 24.6k Views 41 Watching
    • N Offline
      notareal
      There is Thea Render manual.pdf that comes with installation, it's good to browse trough specially when you to start to modify materials. SU2TH has a own separate manual - download that with the plugin.
      SU2TH plugin do save material info inside the SU scene. I think that the best work flow is to set material with the SU2TH plugin. Then, with a simple scene, there is not much else to do in Thea than hit the render button.
      Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
        D-space
        Thea beta? How can I miss this! πŸ˜†
        Awesome renders Solo!
        http://blibestmentalt.no/54981
        • EarthMoverE Offline
          EarthMover
          Great.....new toy. Now I'll get no work done today!
          Awesome renders Pete. Some of your best stuff by far! I'd be curious to know the render times on the images posted.
          Content Creator at Skapeup
          • soloS Offline
            Thanks.
            Adam, I cannot remember them off hand, especially the unbiased ones, I will make a point of remembering the biased ones that I render from here on however.
            Biased renders, no post processing at all.
            http://img710.imageshack.us/img710/4117/mustang2bsde.jpg
            http://img710.imageshack.us/img710/7804/mustang2bsd.jpg
            • soloS Offline
              9 minutes 7 seconds, original size 1718x527, no post work (silvershadow's black hawk model)
              http://img710.imageshack.us/img710/3882/blackhawk9m7sareduced.jpg
                d12dozr
                You make one helluva case for Thea, Pete! Awesome stuff πŸŽ‰
                http://goo.gl/f7ooYh
                • soloS Offline
                  LOL, I'm just glad I can post Thea images, felt like I was AWOL from the gallery for too long.
                  http://img710.imageshack.us/img710/3360/bunnyinhole1.jpg
                  http://img97.imageshack.us/img97/9538/theaclassroom.jpg
                    D-space
                    Goodness...more pics? Awesome! πŸ‘
                    Just downloaded Thea , load files and click render...it works fine...
                    IMHO no learning curve for me!
                      EarthMover
                      I've downloaded and have been playing a little as well. So far it is a lot like Kerkythea as far as interface, so those coming from Kerky would find the learning curve smaller than others. I love the robustness and all the features. Still trying to figure out the navigation and the camera options.
                      Pete, the grass in the Blackhawk render....displaced, or clipmap? Also do you know if Thea will support alpha transparency? So far I can't get it working.
                      • soloS Offline
                        Cool, create some textures, it's so much fun using the material editor.
                        http://img687.imageshack.us/img687/3550/oldwallc.jpg
                        http://img687.imageshack.us/img687/6236/zebraskin.jpg
                        http://img687.imageshack.us/img687/2668/concrete1.jpg
                        http://img687.imageshack.us/img687/5764/barbedwire.jpg
                        http://img687.imageshack.us/img687/6597/galvgrid.jpg
                        • soloS Offline
                          The grass is clipmap instances.
                          Yes it supports alpha transparencies, got an image or scene I can test for you?
                          • N Offline
                            notareal
                            Clip mapping turns to Alpha transparency when you turn on "soft" under clip map properties.
                              remus
                              Im really trying to resist buying thea, and your certainly not making things any easier pete πŸ˜„
                                Sir
                                this looks fantastic, im gonna take a look πŸ‘
                                • soloS Offline
                                  http://www.get-the-skinny.com/blog//images/bush_borg.jpeg
                                    EarthMover
                                    If it is supposed to work without a clipmap by checking "soft", it doesn't seem to be working for me. I've tried a bunch of different .png faceme plants and no go. Adding an actual clipmap works, but I've kind of resorted to clipmap free life from here on out. It's too much of a workflow killer if you use a lot of 2D plants like I do......to the point it becomes a make or break when thinking of purchasing a new renderer.
                                    • soloS Offline
                                      Adam, can you share one of your trees in PM so I can try?
                                      • david_hD Offline
                                        david_h
                                        after my first install of the plugin. .. it asks me to choose 16 or 32 bit and then expects me to hunt down the proper file. Any help on this?
                                        Thx,
                                        David H
                                        • soloS Offline
                                          32 or 64 right? that's your OS.
                                          Then you need to navigate to where you installed it like c:program files/thearender/thea.exe so that the plugin can know the path to Thea when exporting.
                                          • david_hD Offline
                                            david_h
                                            I've got it installed okay . .but this is going to take a bit of reading. . . .Too many buttons. 😳
                                            • 2 / 8
