    The A show (post your Thea images)
    152 Posts 41 Posters 37.0k Views 41 Watching
      sepo
      Sounds good....I must try it.
      • soloS Offline
        although i cant see much reason to go for thea over twilight apart from displacement, what do you think? is learning curve similar to twilight?
        No, there are more variables, the learning curve is greater than Twilight, Twilight is very simple and powerful integrated render solution, Thea has many more options for you to tinker with, a material editor which IMO is second to none.
        It will take some learning to get fluent with Thea, the results and speed of Thea is worth every second spent learning it however as IMO it's one of the fastest CPU based biased and unbiased engines around.
        • olisheaO Offline
          olishea
          thanks for the reply pete πŸ‘ gonna give it a go
          oli
          • N Offline
            notareal
            There is Thea Render manual.pdf that comes with installation, it's good to browse trough specially when you to start to modify materials. SU2TH has a own separate manual - download that with the plugin.
            SU2TH plugin do save material info inside the SU scene. I think that the best work flow is to set material with the SU2TH plugin. Then, with a simple scene, there is not much else to do in Thea than hit the render button.
              D-space
              Thea beta? How can I miss this! πŸ˜†
              Awesome renders Solo!
              http://blibestmentalt.no/54981
              • EarthMoverE Offline
                EarthMover
                Great.....new toy. Now I'll get no work done today!
                Awesome renders Pete. Some of your best stuff by far! I'd be curious to know the render times on the images posted.
                Content Creator at Skapeup
                • soloS Offline
                  Thanks.
                  Adam, I cannot remember them off hand, especially the unbiased ones, I will make a point of remembering the biased ones that I render from here on however.
                  Biased renders, no post processing at all.
                  http://img710.imageshack.us/img710/4117/mustang2bsde.jpg
                  http://img710.imageshack.us/img710/7804/mustang2bsd.jpg
                  • soloS Offline
                    9 minutes 7 seconds, original size 1718x527, no post work (silvershadow's black hawk model)
                    http://img710.imageshack.us/img710/3882/blackhawk9m7sareduced.jpg
                      d12dozr
                      You make one helluva case for Thea, Pete! Awesome stuff πŸŽ‰
                      http://goo.gl/f7ooYh
                      • soloS Offline
                        LOL, I'm just glad I can post Thea images, felt like I was AWOL from the gallery for too long.
                        http://img710.imageshack.us/img710/3360/bunnyinhole1.jpg
                        http://img97.imageshack.us/img97/9538/theaclassroom.jpg
                          D-space
                          Goodness...more pics? Awesome! πŸ‘
                          Just downloaded Thea , load files and click render...it works fine...
                          IMHO no learning curve for me!
                            EarthMover
                            I've downloaded and have been playing a little as well. So far it is a lot like Kerkythea as far as interface, so those coming from Kerky would find the learning curve smaller than others. I love the robustness and all the features. Still trying to figure out the navigation and the camera options.
                            Pete, the grass in the Blackhawk render....displaced, or clipmap? Also do you know if Thea will support alpha transparency? So far I can't get it working.
                            • soloS Offline
                              Cool, create some textures, it's so much fun using the material editor.
                              http://img687.imageshack.us/img687/3550/oldwallc.jpg
                              http://img687.imageshack.us/img687/6236/zebraskin.jpg
                              http://img687.imageshack.us/img687/2668/concrete1.jpg
                              http://img687.imageshack.us/img687/5764/barbedwire.jpg
                              http://img687.imageshack.us/img687/6597/galvgrid.jpg
                              • soloS Offline
                                The grass is clipmap instances.
                                Yes it supports alpha transparencies, got an image or scene I can test for you?
                                • N Offline
                                  notareal
                                  Clip mapping turns to Alpha transparency when you turn on "soft" under clip map properties.
                                    remus
                                    Im really trying to resist buying thea, and your certainly not making things any easier pete πŸ˜„
                                      Sir
                                      this looks fantastic, im gonna take a look πŸ‘
                                      • soloS Offline
                                        http://www.get-the-skinny.com/blog//images/bush_borg.jpeg
                                          EarthMover
                                          If it is supposed to work without a clipmap by checking "soft", it doesn't seem to be working for me. I've tried a bunch of different .png faceme plants and no go. Adding an actual clipmap works, but I've kind of resorted to clipmap free life from here on out. It's too much of a workflow killer if you use a lot of 2D plants like I do......to the point it becomes a make or break when thinking of purchasing a new renderer.
                                          • soloS Offline
                                            Adam, can you share one of your trees in PM so I can try?
                                            • 2 / 8
