    The A show (post your Thea images)
    152 Posts 41 Posters 28.5k Views 41 Watching
    • soloS Offline
      Pete, the grass in the Blackhawk render....displaced, or clipmap? Also do you know if Thea will support alpha transparency? So far I can't get it working.
      The grass is clipmap instances.
      Yes it supports alpha transparencies, got an image or scene I can test for you?
      • N Offline
        notareal
        Clip mapping turns to Alpha transparency when you turn on "soft" under clip map properties.
          remus
          Im really trying to resist buying thea, and your certainly not making things any easier pete πŸ˜„
            Sir
            this looks fantastic, im gonna take a look πŸ‘
            • soloS Offline
              http://www.get-the-skinny.com/blog//images/bush_borg.jpeg
              • EarthMoverE Offline
                EarthMover
                If it is supposed to work without a clipmap by checking "soft", it doesn't seem to be working for me. I've tried a bunch of different .png faceme plants and no go. Adding an actual clipmap works, but I've kind of resorted to clipmap free life from here on out. It's too much of a workflow killer if you use a lot of 2D plants like I do......to the point it becomes a make or break when thinking of purchasing a new renderer.
                Content Creator at Skapeup
                • soloS Offline
                  Adam, can you share one of your trees in PM so I can try?
                  • david_hD Offline
                    david_h
                    after my first install of the plugin. .. it asks me to choose 16 or 32 bit and then expects me to hunt down the proper file. Any help on this?
                    Thx,
                    David H
                    • soloS Offline
                      32 or 64 right? that's your OS.
                      Then you need to navigate to where you installed it like c:program files/thearender/thea.exe so that the plugin can know the path to Thea when exporting.
                      • david_hD Offline
                        david_h
                        I've got it installed okay . .but this is going to take a bit of reading. . . .Too many buttons. 😳
                        • soloS Offline
                          πŸ’š those buttons have strong kung-fu.
                          • david_hD Offline
                            david_h
                            @solo said:
                            :mrgreen: those buttons have strong kung-fu.
                            you are most wise sensei.
                            • Horseman04H Offline
                              Horseman04
                              Amazing work. I have a question about Thea though. I know it has the ability to produce a Physical Sky, but does it do Real Sky Simulation like in Artlantis, with clouds?
                              Again Phenomenal work.
                                D-space
                                @solo said:
                                IMHO no learning curve for me!
                                Cool, create some textures, it's so much fun using the material editor.
                                .... πŸ˜† probably the material & texture editor...but definetly loads of fun! πŸ˜‰
                                http://blibestmentalt.no/54981
                                • ken28875K Offline
                                  ken28875
                                  Wow, really nice renders, Pete. Seems like you had lots of fun with Thea the past few days.
                                  Do you or anyone else use Vray for Sketchup? How does Thea compare to Vray?
                                  After seeing all your images, I need to try that new render.
                                  _KN
                                  Follow Your Dreams.
                                  • F Offline
                                    fymoro
                                    Hi all,
                                    Pete, these renders are awesome... πŸ‘
                                    Because we are on a SU Forum, can you do a comparison between Twilight and Thea render ?
                                    Example: render a SU/Twilight scene, and export it as an "XML" file into Thea Render and render it also without changing settings. Only to compare the speed and the quality.
                                    Actually, for me the interface and the material editor of Twilight is the most easy and practical in the market.
                                    It Should be great for me, to setup a scene with the twilight interface, and render it with Thea render, maybe more quickly ?
                                    http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                                      dedmin
                                      This could be a real comparison if the settings of the two renders are the same - not an easy task if possible.
                                      • soloS Offline
                                        Fred, even though Twilight can export a .xml does not mean that it works perfectly with Thea, the lighting and textures are different and need to be tweaked in Thea.
                                        If Twilight was able to work with Thea then Tomasz would not have needed to create a new exporter right?
                                        As for speed, Twilight works with presets, which have been carefully setup for individual scenarios and expected results, where Thea lets the user tweak the settings, so comparing one against the other would take some fiddling to get the exact quality in order to see which is faster.
                                        Also comparing Thea unbiased to Vray is impossible for the same reasons, my suggestion is to try Thea and see for yourself.
                                        The most important thing IMO is to try see if you can enjoy using it, create some cool materials, get involved then make a personal decision if it's for you.
                                        If you cannot get to grips with it then stick to what you know and works for what you need, if you are looking to up your game and want an engine that can achieve greater heights then by all means give Thea a go, but do remember it will take effort on your side to learn Thea before expecting wonders.
                                        When I started with Thea I had NOT used Kerkythea, and I thought it was a disadvantage, looking back I say it was to my advantage actually as many folk who are KT users had more difficulty getting to grips with the new terminologies and UI, where I had no expectations and approached it as a completely new engine and was able to grasp it quick. Thea is still in beta and there are a ton of new features still to be added which means a ton of new stuff still to learn, I really do enjoy Thea and looking forward to the official product release soon with all the bells and whistles, I also encourage anyone with issues to use the Thea forum as the support there is fantastic and very helpful.
                                        That said, I will still be here to help where I can.
                                        New render...
                                        Candy apple (apple model thanks to Michalis), unbiased render, no post work.
                                        http://img717.imageshack.us/img717/1737/candyapple.jpg
                                        • FrederikF Offline
                                          Frederik
                                          Well said, Pete...! πŸ‘
                                          Couldn't have said it better myself...
                                          Cheers
                                          Kim Frederik
                                            sepo
                                            This does not work for me as well for some reason. I can't get action 2 to work and pane with action 3 and 4 does not appear.
                                            Sorry, understood your question a bit wrong. You don't need a separate clip map. With this kind of 2D plant there is no need to turn soft on, clipmapping is good enough. SU2TH should take care of adding alpha channel from png to clip mapping, but all features are not there yet. Now you need to do it manually...
                                            [attachment=0:xyx6ehp2]<!-- ia0 -->UseAlphaFromPNG.jpg<!-- ia0 -->[/attachment:xyx6ehp2]
                                            Soft -option turns clip mapping to alpha transparency.
                                            • 2 / 8
