    Cursor and snapping to points.
    4 Posts 2 Posters 939 Views 2 Watching
    • John SayersJ Offline
      John Sayers
      I'm getting extremely frustrated at the inability of the cursor to snap to points onscreen. For example you copy an object and drag it to lock to a wall corner - it is unbelievably hard to get it to do it. Sometime I have a corner and want to lock it to a wall frame and they are only mm away yet the cursor won't recognise the adjacent snap point. see attached pic.
      May I suggest the programmers at Sketchup load Version 4 or 5 and compare the ability of a cursor to automatically find a snap point. It started to go downhill when someone add the up/down/left/right move factor to lock to axes.
      When I first used sketchup I remarked that it was most intelligent cursor I'd ever used, now it's become the dumbest.
        remus
        I think the change most likely occurred in the move to version 7, as there wasn't much done to the inferencing code before that (to my knowledge at least.)
        A few things i've found that help: rotating the view and starting the move again can often kick it in to working.
          John Sayers
          yes - I agree with the changing the view but it's definitely lost a lot of it's ability to offer snap points.
            John Sayers
            another couple of points
            1 - in model info/components adjustments regards shading other components don't save and it reverts to the original position. I've tried everything to make it stay to where I want it set but no way.
              • the tab in windows start bar doesn't show the current model - for example you open the program an it reads untitled. You then load a program called Model 1 and work on it yet the tab still reads untiled.
