    PhotoSculpt
    extensions
    71 Posts 11 Posters 90.2k Views 11 Watching
      @hipe-0 said:
      Thanks ! Don't worry you still have the time and there will be other competitions too after this one. 😉
      I really hope so!
      @xrok1 said:
      well i think that's a pretty reasonable decision on the price.
      True. I would also priced it a bit higher (but of course, I don't want to give ideas - hipe-O know that anyways...)
      • H Offline
        hipe-0
        @gaieus said:
        I really hope so!
        Thanks guys for your feedback. I'm pleased the price is ok for you. It's a difficult question and from the marketing study that you guys helped on (thanks!) I think this is reasonable.
        Q: there is a thread I didn't knew about but strangely I cannot access it when I'm logged in "You are not authorised to read this forum." : http://forums.sketchucation.com/viewtopic.php?f=51&t=25791 My web site detected trafic from it and they seem to have questions. Any idea about what I should do?
        Hippolyte from http://www.PhotoSculpt.net/
          @Hipe
          Il faut s'inscrire au sous-forum "Français"
          En passant par les menus des messages persos, onglet "Usergroups"
          • H Offline
            hipe-0
            @Hipe
            Ca a marché merci Pilou!
              New function Alpha Map 😉
              [flash=640,385:28lfqw47]http://www.youtube.com/v/G8wwrInbnfM&hl[/flash:28lfqw47]
                BTW Pilou,
                What method do you use to bring the models into SU (if you do at all) and with what settings?
                • MALAISEM Offline
                  MALAISE
                  Hi ALL
                  First class software. To import the result into Sketchup, we may use OBJ-Import.
                  MALAISE
                  • Mike LuceyM Offline
                    Mike Lucey
                    Hi Guys,
                    I have a question. I should explain beforehand that I would like to try this software out when I manage to get it running under Bootcamp on my Mac but to my question.
                    Does anyone think it would be possible to take some pictures of an abject from the front and create a PhotoSculpt and then do likewise from the rear and then put the two PhotoSculpts together in SketchUp to form a model?
                    I would have something like the attached in mind.
                    Any thoughts?
                    Mike
                      Just take 2 photos from the front face of your object, and 2 photos from the backface 😉
                      And past the result
                        Mike Lucey
                        Thanks Pilou,
                        I'll get the camera out and do that and PM them to you.
                        Mike
                          Little test with Chaoscope 😄
                          A crazzy prog who has not 3D file export only 2D images but can rotate in "3D view" the current view of parameters 😄
                          So you can make 2 images with any rotations like a camera 😉
                          Then use Photosculpt 😎
                            @Mike Lucey
                            Of course you will not have top and bottom 😉 (here 20° between photos)
                            [flash=480,385:1iwa7p0g]http://www.youtube.com/v/dGEIKs69K2A&hl[/flash:1iwa7p0g]
                            • H Offline
                              hipe-0
                              And past the result
                              Yes that will work, I expect some manual rework as the sides will look like stretched UV but nothing impossible.
                              I have a similar example here, one side only.
                              http://www.photosculpt.net/gallery/sculptures/4377635
                              • H Offline
                                hipe-0
                                [attachment=0:2bmsp35a]<!-- ia0 -->chaos.jpg<!-- ia0 -->[/attachment:2bmsp35a]
                                This is cool, I love this ChaoScope. The images on that link are great! 🎉
                                • EarthMoverE Offline
                                  EarthMover
                                  Had fun playing with the Demo version on screen. Disappointed that there are no export capabilities in the Demo version. I'd never buy this program without knowing how it will integrate into my workflow or what I can do with the mesh beyond the PS interface. I'd say you'd do better with a 30 day fully functional trial period.
                                  Content Creator at Skapeup
                                  • H Offline
                                    hipe-0
                                    Do you really think so? That's an interesting point of view 😲 . Who shares the same opinion? Is this 30 day trial without save option too strict? 😞
                                    You'll understand that i'm trying to protect my software (... against illegal use like the people that change their computer's clock every months or so. I've done that myself, I know what I'm talking about (one month and only once) 😉 😳 ). If PhotoSculpt is loosing sales because of this overprotection, then this is not a good thing to do right at release 😠 ! Please advise?
                                    • X Offline
                                      xrok1
                                      i totally agree with earthmover. a software is useless unless it works with your other software, and if you can't test it you will soon forget about it.
                                      as far as clock changing if someone will go through this they aren't the software buying kind anyway. and its like the big boys say if people are stealimg software we'ed rather they steal ours than the competitions. 😉 (the more people that use it, the more people will buy it...)
                                        Hi hipe-O,
                                        I can somewhat understand Adam's concerns. There are often problems and needed workarounds to correctly export/import certain models fro one application to the other. Now if someone works professionally (i.e. for a living, not neccessarily a "power user") in certain apps, he would like to see how he can integrate a new product into his current, existing workflow.
                                        I also understand your concerns about piracy and changing the computer clock to cheat. But how about a solution where you can allow a certain number of saving/exporting the produced model? I have seen such solutions with other software, too, so it should be doable. Say you allow 10 different models to be saved (and after saving them, you allow tweaking, resaving and different ways of exporting) just to make sure that trial users get the full potentials of the software.
                                        If they are satisfied, they would then buy it I am sure - and if somebody is very desperate, they will probably crack the software anyway so you can never totally exclude piracy but this way you may be losing potential legit customers who would otherwise never go for pirated software.
                                        PhotoSculpt - for those who would really exploit its cool features and potentials - is a great tool and priced pretty well so letting trial but potentially legit users to try it out fully would probably lead to more sales even though you may open a window for piracy a little bit more.
                                        • H Offline
                                          hipe-0
                                          Thanks for posting guys that's really cool. I also think that photosculpt makes beautiful normal maps. But that quality cannot be seen unless rendered in ones's software.
                                          Concerning the 10 saves, well thank you for proposing, but I don't like it. I want simple. And simple may just be recompile the demo with full save options turned on as you proposed. It will be a big present for pirats 😉 they will thank me!
                                          I need to think about it. thanks for your time!
                                          • X Offline
                                            xrok1
                                            another thought. i think someone may be more likely to pirate software (download pirated software) that's doesn't have a full featured demo. sometimes its the only way to fully try it out without buying it first 😢 . also someone may have a pirated copy of a software they only use once or twice, but if the need to use it increases they are likely to get a legit license at that point because that's the software they're comfortable with. (provided its not ridiculously priced)
                                            in short it doesn't seem to me that you will lose legitimate customers to pirates.
                                            • 3 / 4
