    Nock House - competition project
    30 Posts 10 Posters 3.7k Views 10 Watching
    • Mike LuceyM Offline
      Mike Lucey
      @mtntrails said:
      Nice work there, you've got my vote as well. Interested in the hall's varying width; I'm thinking to manipulate interior perspective? Or am I missing something else?
      The hall would appear to be a dual use area, transit and overflow living area. Its really only a true hall from the front the kitchen to the rear entry, neat planning 👍
        cheffey
        Mike has it right on target. It's overflow so that the living space can expand. You know when you have your friends over playing wii or rock band!
        Thank you all for the support, I truly appreciate it. After this is over with I'll upload an updated version here that addresses those suggestions you guys are giving me.
        BROS RŌMAN BRÄUN
        • DanielD Offline
          Daniel
          Very nice, Cheffey. Two comments: 1) the closet in the master bedroom is too small for two people; and 2) you might consider sliding the garage forward, or rotating it closkwise 90 degrees, so it doesn't block the view from the bedrooms.
          My avatar is an anachronism.
            Mike Lucey
            Cheffey, It will be interesting to see how the design develops. I looking forward to seeing your final design, although with all the comments you are getting and probably will continue to get, it may be an ongoing project 😉
            I would really like to see more designers showing their works on SketchUcation. It would add a totally new and interesting dimension. Hopefully we see more and more.
              MtnTrails
              Yeah. Took a quick look at the plan view, and the overhead beams/ walls didn't register. 😳 Thanks for pointing that out, Mike. Now it becomes clear...
              -Brian
              Keep doing what you're doing and you'll keep getting what you're getting.
                arjunmax09
                nice work!!! .. I'd like to ask that how did you create those filled walls in sectional views? SketchUp is modelling... my walls come as hollow on sectioning...
                when you fail at something....you haven't really failed...you've found one way the thing will not work out
                  linea
                  Cheffey
                  I enjoyed looking at your design, it is well considered. I support your selection of a helical wind turbine.
                  The building I work in has an array of small (residential scale) traditional 2 blade prop turbines which require constant maintenance. The mechanisms that allows them to turn into the wind need regular tweeking. As I understand it, there is also 2 gearing systems, one to increase the number of revolutions that go to the transformer but also a mechanism that restricts their spin in high wind as they could shake themselves apart. This gearing adds a lot of weight to each turbine so they are inherently inefficient. According to the expert that does the maintenance for us helical turbines have nowhere near as many problems! You probably know this Cheffey but I thought it might be good info for somebody else.
                    Mike Lucey
                    Cheffey,
                    I was keeping an eye on the design's progress in the competition and noticed one of the comments,
                    %(#0000BF)[3/3/2010
                    Mike: From the living room, you'd see the water closet of the shared bath unless you kept the door close, otherwise, not a bad design.]
                    I hope you don't think it was me after my above comments in relation to what I said above.
                    I also noticed this,
                    %(#0000BF)[3/4/2010
                    Greg La Vardera: This is a great scheme - I love the play between the two volumes of rooms. And this is something plausible for a middle class home owner to afford. This should have more votes than it does.]
                    I know Greg from the old @Last Forums. He designs some really cool houses. Receiving this comment from him carries weight ..... so SketchUcation Members! Get your arses over to the site http://www.freegreen.com/whosnext/view/plan-general.aspx?id=43 and give the Nock House a vote.
                    Mike
                    • daleD Offline
                      dale
                      Cheffy
                      Nice work
                      Don't give up on wind yet. Honeywell has just released a new wind generator that operates in winds as low as 2 mph, can produce 2750 kwh /year and is a complete package with inverter ready to install for about $5500 U.S. The system dumps a lot of restricting drag by placing the coil around the tips of the blade.
                      http://www.earthtronics.com/honeywell.aspx
                      Good luck.
                        cheffey
                        Thanks for the comments guys. I don't mind it being a work in progress for a while 😄
                        I know the Mike that was he's a developer friend of mine. He doesn't care for modern design at all.
                        I don't let that bother me though.
                        BROS RŌMAN BRÄUN
                          cheffey
                          I had not heard this but I did get have some info on these wind turbines from a local newspaper article about a residence that has been adding wind and solar to bring their monthly bill down. I'll have to see if I can dig that article up.
                          BROS RŌMAN BRÄUN
                            lavardera
                            %(#0000BF)[3/4/2010
                            Yup - thanks Mike. I've also entered the competition, but I'm voting for my favorites including Cheffy's. I also had wind generators featured prominently in my scheme although I just made them up - not based on any real product.
                            I've been bookmarking new small wind generators as I come across them. The Honeywell product is promising as described - the generator is at the rim rather than the hub, so gearing is eliminated. And the vertical axis type also seem simpler. There is a lot of innovation going on with small wind generators. Its fascinating. Some links:
                            vertical axis:
                            http://urbangreenenergy.com/turbine.php?id=14
                            http://www.oregonwind.com/
                            Non bladed - less blade tip noise:
                            http://www.inhabitat.com/2008/09/03/energy-ball-by-home-energy/
                            http://swiftwindturbine.com/?r=1
                            http://www.jetsongreen.com/2009/12/honeywell-wind-turbine-coming-soon.html?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+jetson_green+%28Jetson+Green%29
                            this one is interesting - vertical or horizontal, and you can build arrays:
                            http://www.aerotecture.com/products.html
                            Greg
                              cheffey
                              Mike
                              Mike, I agree. Greg has been doing a high level of design work that I've been admiring for awhile. To have him make such comments is a big win for me regardless of how the competition goes for me. It's a total honor to have him give me a vote and even take the time to comment on my thread here. There have been a lot of people come and go from the modern residential scene here in the USA; but Greg has been doing it the right way year in and year out. So, go over and give Greg a vote on his entry as I did!
                              http://www.freegreen.com/WhosNext/view/plan-general.aspx?id=27
                              BROS RŌMAN BRÄUN
                                cheffey
                                Thanks, I exported the view from sketchup and then did a filled layer above in photoshop and filled in the section. There is a plugin for this but I never loaded it up.
                                BROS RŌMAN BRÄUN
                                  Mike Lucey
                                  Hi Greg,
                                  Good to see you popping in here, reminds me of old times at the @Last Forums. I have indeed given you a vote for the LAGOM HOUSE. I've actually viewed design this some time ago as I often check out your site to see what you are up to.
                                  For the members that are not familiar with Greg's work, I am attaching an image. A nicely designed, practical house all under 1500 sq.ft. I particularly like the stairs treatment, dual entry from what I can gather and a widened well to give an anti claustrophobic feeling when using it .... if I am reading it correctly. The dormer window treatment is something that I have not come across before but imagine they serve their purpose well.
                                  Mike
                                    lavardera
                                    Thank you Cheffy and Mike! But I have to protest - this is Cheffy's thread and you both are mucking it up! 😆
                                    I appreciate the vote - things have slowed down a bit there and if we could gain 30 or 40 votes Chefy and I could both punch up in the ratings a good bit - so let fly with the mother of all voting!
                                    Greg
                                      cheffey
                                      Just wanted to say thank you to you guys for the support. I'm working on some changes and will re-post the full design here. cheers!
                                      BROS RŌMAN BRÄUN
                                        Mike Lucey
                                        Glad to have been able to help the cause. Looking forward to viewing the finished design.
                                        Mike
                                          lavardera
                                          Come on Folks - its friday, your day may be winding down, you are reading the messageboards, maybe wasting some time on YouTube? Instead - why not jump over to the contest and place a vote for Cheffy and me. Here are the links:
                                          Cheffy:
                                          Greg:
                                          http://www.freegreen.com/whosnext/view/plan-general.aspx?id=27
                                          It will only take you a minute and you will make two very happy architects. 😄
                                          Greg
                                            Mike Lucey
                                            Greg, is there a pint in it for everyone that votes for you guys ..... that is if one of you wins!
