    Nock House - competition project
    30 Posts 10 Posters 3.7k Views 10 Watching
      cheffey
      Thanks for the comments guys. I don't mind it being a work in progress for a while 😄
      I know the Mike that was he's a developer friend of mine. He doesn't care for modern design at all.
      I don't let that bother me though.
      BROS RŌMAN BRÄUN
        cheffey
        @linea said:
        According to the expert that does the maintenance for us helical turbines have nowhere near as many problems! You probably know this Cheffey but I thought it might be good info for somebody else.
        I had not heard this but I did get have some info on these wind turbines from a local newspaper article about a residence that has been adding wind and solar to bring their monthly bill down. I'll have to see if I can dig that article up.
        BROS RŌMAN BRÄUN
          lavardera
          @mike lucey said:
          I also noticed this,
          %(#0000BF)[3/4/2010
          Greg La Vardera: This is a great scheme - I love the play between the two volumes of rooms. And this is something plausible for a middle class home owner to afford. This should have more votes than it does.]
          Yup - thanks Mike. I've also entered the competition, but I'm voting for my favorites including Cheffy's. I also had wind generators featured prominently in my scheme although I just made them up - not based on any real product.
          I've been bookmarking new small wind generators as I come across them. The Honeywell product is promising as described - the generator is at the rim rather than the hub, so gearing is eliminated. And the vertical axis type also seem simpler. There is a lot of innovation going on with small wind generators. Its fascinating. Some links:
          vertical axis:
          http://urbangreenenergy.com/turbine.php?id=14
          http://www.oregonwind.com/
          Non bladed - less blade tip noise:
          http://www.inhabitat.com/2008/09/03/energy-ball-by-home-energy/
          http://swiftwindturbine.com/?r=1
          http://www.jetsongreen.com/2009/12/honeywell-wind-turbine-coming-soon.html?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+jetson_green+%28Jetson+Green%29
          this one is interesting - vertical or horizontal, and you can build arrays:
          http://www.aerotecture.com/products.html
          Greg
            cheffey
            @mike lucey said:
            I know Greg from the old @Last Forums. He designs some really cool houses. Receiving this comment from him carries weight ..... so SketchUcation Members! Get your arses over to the site http://www.freegreen.com/whosnext/view/plan-general.aspx?id=43 and give the Nock House a vote.
            Mike
            Mike, I agree. Greg has been doing a high level of design work that I've been admiring for awhile. To have him make such comments is a big win for me regardless of how the competition goes for me. It's a total honor to have him give me a vote and even take the time to comment on my thread here. There have been a lot of people come and go from the modern residential scene here in the USA; but Greg has been doing it the right way year in and year out. So, go over and give Greg a vote on his entry as I did!
            http://www.freegreen.com/WhosNext/view/plan-general.aspx?id=27
            BROS RŌMAN BRÄUN
              cheffey
              @arjunmax09 said:
              nice work!!! .. I'd like to ask that how did you create those filled walls in sectional views? SketchUp is modelling... my walls come as hollow on sectioning...
              Thanks, I exported the view from sketchup and then did a filled layer above in photoshop and filled in the section. There is a plugin for this but I never loaded it up.
              BROS RŌMAN BRÄUN
              • Mike LuceyM Offline
                Mike Lucey
                Hi Greg,
                Good to see you popping in here, reminds me of old times at the @Last Forums. I have indeed given you a vote for the LAGOM HOUSE. I've actually viewed design this some time ago as I often check out your site to see what you are up to.
                For the members that are not familiar with Greg's work, I am attaching an image. A nicely designed, practical house all under 1500 sq.ft. I particularly like the stairs treatment, dual entry from what I can gather and a widened well to give an anti claustrophobic feeling when using it .... if I am reading it correctly. The dormer window treatment is something that I have not come across before but imagine they serve their purpose well.
                Mike
                  lavardera
                  Thank you Cheffy and Mike! But I have to protest - this is Cheffy's thread and you both are mucking it up! 😆
                  I appreciate the vote - things have slowed down a bit there and if we could gain 30 or 40 votes Chefy and I could both punch up in the ratings a good bit - so let fly with the mother of all voting!
                  Greg
                    cheffey
                    Just wanted to say thank you to you guys for the support. I'm working on some changes and will re-post the full design here. cheers!
                    BROS RŌMAN BRÄUN
                      Mike Lucey
                      Glad to have been able to help the cause. Looking forward to viewing the finished design.
                      Mike
                        lavardera
                        Come on Folks - its friday, your day may be winding down, you are reading the messageboards, maybe wasting some time on YouTube? Instead - why not jump over to the contest and place a vote for Cheffy and me. Here are the links:
                        Cheffy:
                        Greg:
                        http://www.freegreen.com/whosnext/view/plan-general.aspx?id=27
                        It will only take you a minute and you will make two very happy architects. 😄
                        Greg
                          Mike Lucey
                          Greg, is there a pint in it for everyone that votes for you guys ..... that is if one of you wins!
                            lavardera
                            If I win, and we meet some day, then I would be honored to share a pint with you on me!
                            Greg
                              lavardera
                              This is is Sketchuppers - Today is the last day of voting - closes in roughly 6 hours at 5pm EST. Give your fellow Sketchup users some support by jumping over and voting for our entries:
                              Cheffy:
                              Greg:
                              Greg
                                Mike Lucey
                                Greg, I have done 'my duty' but I think you might be flogging a dead horse. I was surprised and disappointed not to see more members checking out your entries and giving support 😞 It only takes a few seconds 😒
                                  lavardera
                                  Yes, well when it comes to this contest flogging a dead horse is my speciality. I'm actually very glad its almost over and I can refrain from badgering everybody I know...
                                  Greg
                                  • 2 / 2
