    What is it?
    70 Posts 23 Posters 10.4k Views 23 Watching
      Roger
      Lions no, but bronze tigers I will give you and dolphins too. Arty bronze she be. Near the water but has never has sailed the sea.
      http://www.azcreative.com
        Roger
        The clues get stronger, let hope the answers don't get wronger.
        Maybe this will put you inTOUCH with the answer.
        I thought this would be an easy model, but there was more detail than I imagined.
          d12dozr
          Touch hole for a cannon!!
          http://goo.gl/f7ooYh
            Roger
            Good work. Yes, it is a touch hole for a cannon, but which cannon? This one actually has a unique name other than its classification as an artillery piece. And if you figure that out you should be able to give a location and describe the damage it did.
            • W Offline
              watkins
              It looks like the gun carriage for a 32 pounder from HMS Victory, but I have no idea what its name might be. I am assuming it is linked to HMS Victory.
              Some interesting stuff on HMS Victory, but no cannon names.
              http://www.funtrivia.com/en/World/HMS-Victory-14208.html
              I am sure that the gun crews had names for their cannons, but I'm damned if I can find a reference.
              Bob
                Roger
                Remember this was the bane of Nelson. Let me pass on a short story:
                Nelson was the rock star of his day and had many female admirers. A lady inn keeper approached him with the idea of changing the name of her establishment to the NELSON ARMS. He replied, "Unfortunately I have only one so that will not work."
                Remember the clue feline but not a Lion.
                Also if you were to shoot a small burrowing rodent-like burrowing creature with rudimentary eyes what kind of gun would you use?
                • W Offline
                  watkins
                  Okay the mole is the Mole of Teneriffe, where Nelson was wounded on 24 July 1797. In fact, his arm was so badly damaged by a cannon shot it had to be amputated. The shot was reputedly fired from the Castle High Pass by 'El Tigre' (Museo Militar de Almeyda, Santa Cruz), and so I think we have it. Nelson Arms, or lack of one, plus the feline connection to the cannon's name.
                  The cannon is very ornate, and so I wish you luck with the model. It is the kind of detailing Simon Le Bon would enjoy
                  Regards,
                  Bob
                    Roger
                    Watkins, you have the answer. When can I expect you here in Phoenix for the prize?
                    The parts of the cannon are done, but the decorations are tedious. It is a great lesson in organic modeling. I have done every little section of the cannon as a separate model as the file sizes are so large and unwieldy. When done I will ahve a go at a Kerkythea Render and may even build an illustration around it.
                    • W Offline
                      watkins
                      Thinking about an American breakfast reminds me of the time I went into a dinner for breakfast in San Francisco. The waitress asked me what I would like, and I told her. She then she asked me how I would like me eggs. I looked at her with a quizzical expression on my face, and said, "Cooked?". She looked and me and said, "You're English, aren't you!"
                      I'm glad the quiz is over. I can go back to sleep again!
                        john.warburton
                        I'm working on my own canon too, part of a much larger project to model the HM Bark Endeavour.
                        A long way to go.
                        Life's a reach, and then you gybe.
                          Roger
                          You have an elevating wedge to aim the gun mine has an elevating screw. Mine also has lifting dolphins to lift the barrel into the carriage. Otherwise they seem quite similar.
                          Are you doing this for yourself or do you have a client for this kind of work? Are you working off the real dimensions or like me working from a model. I should have scaled everything up. I am running into follow me not working for some of the fine detail. What renderer do you plan to use.
                          Will the cannon be polished or have some patina? And the wood? Oak I suppose. Did they oil it, varnish it, wax it?
                          I used to work for a tech company and was visiting the UK office in Isleworth. Went into the cafeteria and ordered beans and toast and they threw the beans on top of the toast. Walked into a tavern called the Prince of India and hit my head on the ceiling beams. The story has it that the country was being deforested to supply the Royal Navy, but the inn keeper traded free food for for the oak beams used to make the tavern.
                            Roger
                            Carriage is coming along, I need to work on the gun.
                            Need some old oak texture
                                Roger
                                Thanks TIG, but I think I will need a bigger sample and probably darker.
                                  john.warburton
                                  I am working from measured drawings. The HMB Endeavour is an extremely well documented vessel. I also have the advantage of having had extensive access to the replica! This is a personal project, so progress will be sporadic and slow, I expect. I have several photos of the replica canon and one of an original on which the replicas were based that was recovered from the seabed.
                                  As for the carriage finish - the Australian National Maritime Museum experts came up with the matt red finsh as the most likely to be used!
                                  I plan to try a range of rendering solutions.
                                    Roger
                                    Wrapping a photo texture.
                                    The trick here is unwrapping the image from a real world 3D image of the cannon and then rewrapping it in the virtual model.
                                    My problem now is that I do not understand the path of events in adding a bump map when I get to the render engine.
                                    I have not added bronze to the non decorated part of the cannon's muzzle as I was in a hurry to see how the image unwrapping and rewrapping would go. And if you think this looks OK, it can be mad to look 10x better. I did not use my studio to take the shot. The cannon barrel was held in one hand and the camera was held in the other without tripod. And a series of 4-5 images was shot under a dim flourescent light. Then the images were merged and flattened in photo show to make a long narrow panorama.
                                    Not bad for sub-optimal conditions. Sizing of the wrap was not perfect and so the repeat is not perfect. But like the other side of the moon, I am not going to show that part.
                                      Roger
                                      The fun begins
                                      I have finished 80 percent of the project but I think the last 20 percent of the project will take 80 percent of the time.
                                      Where did our ancestors find the time to spend on so much decoration. The lifting dolphins were my first attempt at any sort of organic modeling. They are not great, but they are OK. The important thing is that I am loosing my fear or modeling organic shapes.
                                        Roger
                                        When will it end?
                                        At this point I feel like I am just along for the ride and don't know when or where this project will end.
                                          KXI System
                                          Well if their gonna invade you gotta look nasty, if your gonna lose you gotta look good. Apparently thats how it worked in the middle ages, the ugly ones kept destroying the better looking one accomplishments.
                                          Getting the perfect sig is hard...
                                          Google it!
                                            Roger
                                            Thing are going a bit slow as I am running out of processing power for the Royal escudo (heraldic seal) at the rear of the cannon. I should put the different pieces on separate layers, that I can turn off until I get to the final render. My poor computer is dying when I do anything complex. I tried to bend the escudo using Fredo's bend tool. It ran for 15 seconds and then choked.
                                            I need to think more about optimization and planning.
                                            • 2 / 4
