    Count instances in selection???
    3 Posts 3 Posters 320 Views 3 Watching
      artofseeing
      hi all,
      i have a script where i am at one point helpless with a problem:
      its a script giving me a summary of weights.
      i have components with dynamic attributes "gewicht" (weight).
      i select a couple, then i get a dialog box with the following:
      number of selected items.
      total weight.
      then:
      number of item a - name of item a - single weight item a
      number of itemb - name of item b - single weight item b
      and so on...
      depending on how many things are in my selection.
      one part doesnt work though, that which i put in bold above.
      it doesnt show me the number of instances in my selection, as iwant, but
      it rather shows me the number of instances in my model.
      and i cant see the code for it.any body got some advice? thx alot πŸ˜„
      the problem is, where it says: "e.definition.count_instances"
      so basically i want: "e.definitions.count_instances" for my selection.
      here's the part of the code:
       name=[]
         ss.each{|e|
            if e.class==Sketchup;;ComponentInstance
             name=name+[e.definition.count_instances.to_s+ "x \t"+e.definition.name+ " \ta "+e.definition.get_attribute("dynamic_attributes","gewicht",0)+" kg"+"\n"]
      as long as there is a voyage away, there's always a journey back...
      http://artofseeing.carbonmade.com
        cjthompson
        My initial thought would be:
        numSelectedInstances = (e.definition.instances & ss.to_a).length # & intersects two arrays
        You'll probably want to stick around and see what the others say.
          You want to count the instances in a selection...
          counts=[]
          ss.each{|e|counts<< e.definition if e.class==Sketchup;;ComponentInstance}
          countsuniq=counts.uniq
          compocount=[]
          countsuniq.each{|e|
            count=0
            counts.each{|c|count+=1 if c==e}
            compocount<< [e.name, count]
          ### compocount is an array, with each item as an array of the instance's definition.name [you could change it to just the definition itself 'e' ?] and then its number of instances as counted in the selection (ss)...
