    [FIXED!!!] Anyone seen this web dialog bug?
    11 Posts 5 Posters 2.5k Views 5 Watching
    • T
      todd burch
      I'll also add that if I code a SketchUp UI.messagebox instead of a javascript alert in the rescue clause to report the invalid value, I get the same erroneous behavior.
        Never seen it.
        Got the code to poke about?
        • T
          todd burch
          Here's my test case that does not show the error. I think perhaps having more callbacks in the mix might make it happen, I just haven't spent the time to go there yet.
          require 'sketchup.rb'
          myhtml =<<DATA
          <html>
          <head>
          <meta http-equiv="Content-Type" content="text/html" charset="utf-8"/>
          <script>
          function toHex(str) {
          	var hex   = '' ;
          	var achar = '' ;
          	var bchar = '' ;
          	var cchar = '' ;
          	for (var i = 0 ; i < str.length ; i++ ) {
          		cchar = str.charCodeAt(i).toString(16) ;
          		if (cchar.length == 1) cchar = '0' + cchar ;
          		hex += '' + cchar.toUpperCase() ;
          	return hex ;
          </script>
          </head>
          <body>
          <form name='myform'>
          <label for='input_field'>Enter Value</label>
          <input
          	id='ifield'
          	name='myfield'
          	type='text'
          	maxlength='10'
          	size='10'
          <br />
          <input
          	type='button'
          	value='OK'
          	onclick="window.location='skp;setvalue@' + toHex(document.getElementById('ifield').value);"
          </form>
          </body>
          </html>
          DATA
          wd = UI;;WebDialog.new("WebDialog Bug with Alert on Windows",  true, nil, 300, 270, 600, 200, true) ;
          result = wd.add_action_callback("setvalue") {|dialog, parm|
          	value = nil ;
          	parm = [parm].pack('H*')
          	begin
          		value = parm.to_l
          	rescue
          		UI.beep
          		dialog.execute_script("alert('Invalid length >#{parm}<');")
          	end  # begin
          wd.set_html(myhtml) ;
          wd.show
            Jim
            almost seems like a mis-placed quote, or at least something quote-related.
            • T
              todd burch
              No indications of a syntax error anywhere. Only place (that would make sense) where the syntax error or misplaced quote might be would be in the ALERT function, but, even when I remove that and use a messagebox, I still get the error.
              It's almost as if the rescue is somehow changing the internal browser's stack to get confused in what should be displayed or something.
                Jim
                The example you posted displays the alert for me.
                UPdate - Ok, you already said this DOES work and the error is hard to reproduce.
                • alexschreyerA
                  alexschreyer Extension Creator
                  I get this with normal websites when I forget the "return false" at the end of the onClick code so that the browser does not try to follow the link. Maybe try:
                  onclick="window.location='skp;setvalue@' + toHex(document.getElementById('ifield').value);return false"
                  Cheers,
                  Alex
                  Author of "Architectural Design with SketchUp":
                  http://sketchupfordesign.com/
                  • T
                    todd burch
                    WOO-HOO!!!
                    That didn't fix it directly, but it did get me in the right area.
                    I first tried changing from a direct onclick="window.loc............" to calling a js function instead. I run the dialog, and enter junk:
                    In the function, I did the callback, and after that, coded up a return false;, and this is what I got:
                    So.... being the inquisitive guy I am... I removed the "false" from return false;. That did the trick!! Go figure.
                    I'm so HAPPY!! Thanks Alex.
                    • Dan RathbunD
                      Dan Rathbun
                      @dan rathbun said:
                      therefore... you should be able to do it in the input tag thus:
                      onclick="void( window.location='skp:setvalue@' + toHex(document.getElementById('ifield').value) );"
                      .. and shouldn't need to have a function call.
                      ON second thot... chances are we'll forget and have the same 'bug' again on other projects.
                      Let's promote Jim Foltz's idea of using a generic callback function.
                      from Jim's v6 webconsole:
                      %(#8000BF)[
                      // Javascript
                          function cb(name, args) { // CALLBACK
                              window.location='skp;'+name+'@'+args;
                      modified with a void operator and a bit of typechecking:
                      %(#8000BF)[
                      // Javascript
                            if typeof(name)=='string' {
                              if typeof(args)!='string' { args=args.toString }
                              void( window.location='skp;'+name+'@'+args; );
                            else {
                              void( window.location='skp;webError@Callback name is not a string!';);
                      So, Todd's callback could be:
                      onclick="cb( 'setvalue',toHex(document.getElementById('ifield').value) );"
                      I'm not here much anymore.
                      • Dan RathbunD
                        Dan Rathbun
                        return [( [expression] [)];]
                        "If expression is omitted, or no return statement is executed from within the function, the expression that called the current function is assigned the value undefined."
                        http://msdn.microsoft.com/en-us/library/22a685h9(VS.85).aspx
                        void expression
                        "The void operator evaluates its expression, and returns undefined. It is most useful in situations where you want an expression evaluated but do not want the results visible to the remainder of the script.
                        The expressionargument is any valid JScript expression."
                        http://msdn.microsoft.com/en-us/library/e17c7cbe(VS.85).aspx
                        .. this is why you often see void(0); used in the HREF attribute for controls (such as a <A> tag,) that display popups or alert boxes.
                        ADDED: See SCF topic: [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=25252:dqe1rmdx]Webdialogs and Javascript void[/url:dqe1rmdx]
                        EDIT: put MSDN quotes in quoteboxes for clarity.
