    Help Me Draw A Dome [TUTORIAL]
    322 Posts 10 Posters 102.2k Views 10 Watching
      D0me
      Hi Guys
      Thanks so much for the replies.
      Chris, I hear what you're saying and will surely implement the given advice wherever I can. I may have access to a Plotter but if not then I will Sketch the drawing using my dimensions. Because this is a first time for me, both Sketching and Building/Masonry, I will explore different methods and use the most accurate and not necessarily the most easiest. As a comparison, I will also print the model on A4 or larger paper and see where it leads to from there.
      "Kick Off?" My planned date is Next Weekend. I have planned other dates before but it never went according to plan but this time I am a little more confident. I am actually of to the hardware store today to try and source material I will require.
      Gaieus: Thanks for the step by step on how to print this model to scale. Always look forward to your tutorials.
      Regarding the plugin you mentioned to sort out the ugly cut, where can I download it in the mean time so I can start playing around?
      Did you get a chance to figure out how we going to resolve the problem with my Dome Height after creating the bung hole/bevel?
      Thanks again
      Regards
      D0me
      • GaieusG
        Didn't you like my 'quick and dirty' solution? You know - to scale up everything by that bit. Oh well - you would have just a little bit thicker walls for your dome. πŸ˜’
        Edit: and here is TIG's SectionCutFace plugin.
        • chrisglasierC
          chrisglasier
          When you have taken out the spinner pipe (it needs to be pipe not a pole in order to rotate on the spigot), fill the void with sand and dome the top. Pour the bung. Your height will be same as before.
          • GaieusG
            Ah good, thanks Chris. No wonder I did not suggest that - these technical details (even the whole process) is not my strength. I also thought that hole will have function later.
            What is this "bevel" thing with the dome BTW?
            • chrisglasierC
              chrisglasier
              The hole is to accommodate the spinner pipe. (It also stubs the pointy bit of the segments, which could easily break if transported.) The bung is cast at a different time so there may be a slip plane at the joint. The beveled edges stop the bung falling through. The bung is an oculus shaped keystone if you know what I mean.
              • GaieusG
                @chrisglasier said:
                ...The bung is an oculusshaped keystoneif you know what I mean.
                Now we are speaking! πŸ˜‰
                Why didn't you start with this???
                πŸ˜„
                • chrisglasierC
                  chrisglasier
                  @gaieus said:
                  And take the mystery out of the topic? Notice I haven't asked why the d0me is in four segments. Another mystery yet to be revealed - eh!
                  And what's this got to do with anything:
                    D0me
                    Sorry Gaieus, I must have misunderstood you. In a previous post you mentioned this solution but didn't say how to do it. You did say you were rushing over to the bank and we'll figure something out when you get back.
                    Thicker walls should be fine but the important thing for me is to learn more about the power of SU.
                    After my Sand Dome, I will add to it the Refractory Dome with the pipe still in place. The Refractory dome will be made in 4 Pieces. Because Refractory material is a quick hardening material, and this is a first time for me, I will cast 1 piece at a time. After all 4 pieces are casted, I will join them together. Because each piece will be casted with the pipe in place, this will automatically create the bunghole in the centre. I will just fill the centre with refractory cement to close it of thus creating the "Keystone".
                    I may be wrong but with the way I plan on doing things, the height of my inner refractory dome will decrease a little.
                    Really don't know why I'd didn't as I should have started with this first. Its not too late to do so. Any advice to make sure I do it right especially the height.
                    Chris, I guess the picture attached is what should be used as my spinner. I went to my Hardware store today and explained to the salesman what I require and how I will use it. Unfortunately he couldn't think of anything to supply me with that could help me create a spinner.
                    Also regarding the pipe, any pipe you recommend?
                    Lastly, how large of a diameter should my bunghole be and this will be the same diameter of my pipe.
                    Regards
                    D0me
                    • GaieusG
                      No, that was meant for Chris. He clarified it to me with the "oculus" term.
                      πŸ˜‰
                      Then as he explained that you will fill the missing sand back anyway (and this way fix the height difference), my "quick and dirty" solution has become deprecated anyway.
                      Of course, we can still learn a few tricks if you are inclined - even if you do not need them for your current project.
                        D0me
                        πŸ˜‰
                        I'm leaning towards redoing this model and since I now know the pipe will be part of it, how do you suggest I implement it? In the begining before sketching my dome pieces or after the dome pieces are sketched?
                          racer123246
                          I was confused at first and now I'm more confused. 😳
                          • chrisglasierC
                            chrisglasier
                            @d0me said:
                            The Refractory dome will be made in 4 Pieces. Because Refractory material is a quick hardening material, and this is a first time for me, I will cast 1 piece at a time. After all 4 pieces are casted, I will join them together. Because each piece will be casted with the pipe in place, this will automatically create the bunghole in the centre. I will just fill the centre with refractory cement [concrete] to close it of thus creating the "Keystone".
                            Ah ha!
                            As the angle at the top is now 90 degrees the acute angle problem has gone away and you don't need the bunghole for that reason. I think you can screed off the sand and lower domes by eye using lines drawn on the form. So you don't need the complication of spinner and so on.
                            Just make another screeder for the topmost layer with a curve the same as the largest diameter and 2" longer than the quadrant base.
                            Set up your panel assembly (form), place and compact the sand then carefully lay up the concrete layers evenly not to disturb the substrate using the hawk and steel trowel. Hold the top screeder horizontally to rule off the surplus concrete pressing against the side pieces going from bottom to top if casting vertically *. Of course fill any depressions and rule again. Just as the concrete is beginning to set use a wood float to dress the surface. After that you can use the steel trowel but be careful not to bring too much cement/water slurry up to the surface. (Try it out on the hidden surfaces).
                            • You might consider making a cradle to sit your form horizontally. Then you could use a slightly wetter mix.
                            Just wait for D0me to post the WIP photos. All will be clear.
                              D0me
                              @chrisglasier said:
                              Ah ha!
                              Hi Chris
                              I've been reading your post over and over, trying to grip the important advice you have given. I am finding it a bit confusing so I'll take a few steps back.
                              Firstly, you mention that the angle at the top is now 90 degrees instead of being acute. Would you mind elaborating on you've come to thing conclusion. Sorry, my understanding on architecture jargon is limited to none.
                              I was always under the impression that a screeder and spinner was the same thing. I was obviously mistaken. Where can I see images of how the 2 work in their own way.
                              I more or less understand the rest of your advice and it will become even more clearer when I get more clarity on the above points.
                              As for pics on WIP, most definately. This post will not be complete without them.
                              Regards
                              D0me
                              • chrisglasierC
                                chrisglasier
                                Originally you had six segments meaning the angle at the top of each segment was 60 degrees - an acute angle. Acute angles in concrete are difficult to make because the material runs out to nothing, and are therefore easy to break.
                                The screeder in flat work would normally be called a rule or straight-edge, which I thought might be confusing as you are working with double curves. The spinner is just a device that rotates the rule or "curved edge."
                                But anyway I think what I suggested in my previous post should really give a very good chance to do a good job. Let me know it any part is unclear.
                                And yes I agree photos are a must!
                                • chrisglasierC
                                  chrisglasier
                                  D0me, you may find this Sunday idea the basis for a good solution.
                                  See also sketch .skp
                                  D0me - simple form.skp
                                    D0me
                                    Hi Chris
                                    With regards to the spinner, I'm still curious to know what sort of contraption can be made to fit on my wood and the pipe (2" Diameter)?
                                    This contraption should be able to stay in a stationary point on the pipe and spin.
                                    I've thought up a few ideas but had to disgard them because if I have a contraption that will be tightened in place and at the specific height on the pipe, it won't spin if you know what I mean. And if I leave it loose it won't stay at the height on the pipe I wish for it to stay.
                                    Any ideas?
                                    Regards
                                    D0me
                                    • chrisglasierC
                                      chrisglasier
                                      Basically you need two pipes one fitting inside the other like a telescopic leg. One has the wood clamped to it and rotates; the other needs to be solidly fixed to keep vertical. The size will depend on what you can find that will work.
                                      • chrisglasierC
                                        chrisglasier
                                        Trying to improve my analytical Sketchupping:
                                        • chrisglasierC
                                          chrisglasier
                                          One plus one ...
                                            D0me
                                            Hi Chris
                                            Nice sketching
                                            Can you upload the skp of those images? Would love to get a better view of things.
                                            Guys, I'm also starting to redo the model but I am going to use the advice Gaieus gave and start with the pipe first.
                                            Any tips on how I should go about doing so, like e.g the domes first then pipe or the other way around???
                                            Regards
                                            D0me
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
