    Something New-Pavilion
    16 Posts 9 Posters 3.8k Views 9 Watching
    • olisheaO Offline
      olishea
      Playing with tensile structures.
      Going to be a pavilion but still not finished yet I've only designed the roof.
      I've attempted this before but I'm trying to perfect the technique and achieve a regular tessellation.
      I only rendered at low res so please excuse any jaggy lines etc. its just a preliminary study.
      http://i654.photobucket.com/albums/uu269/olishea/rev1.jpg
      comments appreciated.
      oli
        alpro
        Looks interesting, looking forward to the progress. Exactly what is your technique, plugins used?
        Mike
        • olisheaO Offline
          olishea
          I just started off with a sphere and used FFD to get the general shape. (the other half of the structure is below the ground plane)
          I exported to wings 3d (faster than SU) to subdivide it....but you can do exactly the same with the 'subdivide and smooth' plugin.....it can create the tessellation too. just a bit slower.
          no exact science to it really, i just used a silhouette to gauge some human scale.
          cheers
          oli
          • michaliszissiouM Offline
            michaliszissiou
            I find this fantastic. Just this naturalistic background and sky is where I have a problem. For the moment, I mean. πŸ‘ πŸ‘
              JuanV.Soler
              maybe if you put the sun on top of the girl at the left, it will balance the scene so you can decide easier
              i like it
              • david57D Offline
                david57
                Kids will like this for climbing.
                • troyhomeT Offline
                  troyhome
                  is it moving? πŸ˜‰
                  i should add that I am a fan of your abilities πŸ‘
                  IOviz.com
                  SU Pro 2024 PC
                  • artysmediaA Offline
                    artysmedia
                    Hello! I think there is too much blur and the girl of the right part has some problems with her neck! πŸ˜„
                    But it looks very shine! β˜€
                    Waiting for more! πŸ˜‰
                    Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                    Blog: Artysmedia
                    • olisheaO Offline
                      olishea
                      thanks for all the comments!!
                      I used radial blur because it was quite jaggy and I wanted to suggest some movement, like a kinaesthetic....the actual structure isn't moving lol I agree its a bit over-the -top.
                      thanks troy!
                      david57: there is glass to the inside so you cannot actually touch it. perhaps I should add some slight colour to the glass so its more evident.
                      michalis: the background is just from the raw render....its a spherical hdri, I will add the context when I have finished the design. thanks.
                      I will post the sketchup view of the structure its pretty sexy!
                      oli
                      • olisheaO Offline
                        olishea
                        http://i654.photobucket.com/albums/uu269/olishea/1-5.jpg
                        GLAZING:
                        http://i654.photobucket.com/albums/uu269/olishea/2-3.jpg
                        http://i654.photobucket.com/albums/uu269/olishea/4.jpg
                        http://i654.photobucket.com/albums/uu269/olishea/5-1.jpg
                        SOME STRANGE GEOMETRY TO THE LEFT IN THIS ONE LOL:
                        http://i654.photobucket.com/albums/uu269/olishea/6.jpg
                        http://i654.photobucket.com/albums/uu269/olishea/7.jpg
                        http://i654.photobucket.com/albums/uu269/olishea/8-6.jpg
                        http://i654.photobucket.com/albums/uu269/olishea/9-1.jpg
                        oli
                          red_shift
                          It's great to see this experiment! It will be cool to watch it develop. I'm not familiar with Wings3D, but will look at it after seeing this.
                            arjunmax09
                            cool work!!!!! πŸ˜„ what plugin [not subdivide and smooth] did you use to make these internal triangular framework??
                            when you fail at something....you haven't really failed...you've found one way the thing will not work out
                            • olisheaO Offline
                              olishea
                              thanks for comments, its appreciated πŸ‘
                              its Wings 3D (free subdivision modeler)
                              I just collectively offset each triangle that made up the mesh and then collectively push/pulled the frame to give it depth (like push pull). this is a lot easier in wings because it remembers what you have selected.....don't need to go round the model clicking all the time. I'm not sure how feasible this structure would be in the real world!!! πŸ˜•
                              oli
                              • david57D Offline
                                david57
                                Good idea about the glass, didnt think it.
                                I just found this on the web and i guess you already saw it:
                                http://www.nhit-shis.org/cspace-pavilion-a-temporary-structure-design/
                                • olisheaO Offline
                                  olishea
                                  no ive never seen it. good spot!! cheers
                                  oli
                                    michaliszissiou
                                    Lets talk about construction now, because this is amazing. BTW I love the SU raw 2d exports, its more 'projective' (sorry for my english), some pp could help.
