    Slooping lines, Pull-Up.
    4 Posts 3 Posters 386 Views 3 Watching
      Rambola
      First, take a look on this picture
      http://img130.imageshack.us/img130/3866/15075218.png
      (I have only draw the red thigns on the picture, found it on this page).
      I want to learn how to draw slooping lines with Pull-Up like number 1 on the picture. I havent figure that out and i can only do number 2 on the picture.
      It would be nice if someone here can tell med how to do it. Im not familiar with the words who has with editing to do, so my description aint so good.
      Thanks.
      If i post something in the wrong sub-forum. Ill be more then happy if some mod put it where it should be.
      Havent english as my mainlanguage so I aint that good at it.
        d12dozr
        As TIG said, use the scale tool on a single face after push/pull:
        [flash=853,505:2lz170p0]http://www.youtube.com/v/I_xqUsZnzJA&fs=1[/flash:2lz170p0]
        You should watch all of these videos if you have not already:
        http://www.youtube.com/view_play_list?p=4EA4466179F2B044
        http://goo.gl/f7ooYh
          Rambola
          Okey, thanks man. I will do that.
          • mitcorbM
            mitcorb
            If you study the figure/model on which you drew the red things, you can learn how to do what you want.
            Start with the first notes at the bottom of the model.
            For instance:
            start with a circle on the ground, then use pushpull tool to make a cylinder.
            Select the top face, then scale face larger or smaller than the original diameter.
            This model is an excellent way to learn these techniques.
            EDIT: ok I see that others have posted.
