    WebDialog set_file
    24 Posts 7 Posters 7.5k Views 7 Watching
      File.dirname( File.expand_path(__FILE__) )
      Seems that __FILE__ didn't return an absolute path when you skipped the πŸ˜„ in your path
        MartinRinehart
        Bingo!
        A few more experiments, a Mac answer and then maybe a sensible set_file(). Maybe I won't have to fire myself!
        • C
          cjthompson
          One other idea is to use the File class to get the string from the file, and then use set_html.
            Then everything the HTML file links to will be relative to a random temp folder - which can cause problems unless you use absolute URIs for everything. Or include a <base> tag.
              MartinRinehart
              Edited solution into original post. Zero reported problems from movie viewers, so maybe it works.
                @dan rathbun said:
                Found the problem on PC.
                It's a boo-boo using the File.join method. An extra SEPARATOR is getting inserted at the beginning of the URL string, so that whatever the pathname, whether you use the optional relative path (2nd argument) or not, the resulting URL passed to the browser begins with:
                file:///
                file:/// is a valid URI. http://en.wikipedia.org/wiki/File_URI_scheme#Windows
                Firefox diplay local URIs like that. IE will open such URI and convert it into what you see in Windows Explorer. So odd that it'd be problems with the webdialog then.
                  ah. .set_file was passed the URI. now I see.
                  • Dan RathbunD
                    Dan Rathbun
                    No I thought .set_file was doing this:
                    def set_file(filename, path='') %(#F0F0F0)[__]protocol='file://' %(#F0F0F0)[__]set_url( File.join(protocol,path,filename)) end
                    But Ruby's File.join is actually kinda smart. Google may have used their own dumb version that adds extra /s.
                    But I'm not sure:
                    my_dialog.set_file('C:/scite/WebDialogTips.html','')
                    Works
                    my_dialog.set_file('C:/scite/WebDialogTips.html')
                    Works
                    my_dialog.set_file('WebDialogTips.html','C:/scite')
                    Error ('Cannot Load Webpage' Error Webpage, but NOT MSIE Error dialog.)
                    my_dialog.set_file('WebDialogTips.html','C:/scite/')
                    Works
                    EDIT NOTE: For this test, I copied file 'WebDialogTips.html' into 'C:/scite/' because the sciTE folder is in my System PATH (not my Ruby $LOAD_PATH.)
                    my_dialog.set_file('WebDialogTips.html','')
                    and
                    my_dialog.set_file('WebDialogTips.html')
                    both produce the MSIE Error Dialog, that says:
                    "Cannot find 'file:///WebDialogTips.html'. Make sure the path or Internet address is correct."
                    So the Win System PATH makes no difference.
                    _
                    I'm not here much anymore.
                    • Dan RathbunD
                      Dan Rathbun
                      Yes 3 slashes work if I paste it into the addressbar of a normal MSIE browser.
                      But for WebDialog, on PC (Win32),
                      where path=Sketchup.find_support_file(''):
                      my_dialog.set_url('file://localhost/'+path+'/Support/webpage.html')
                      Works
                      my_dialog.set_url('file:///localhost/'+path+'/Support/webpage.html')
                      Error
                      my_dialog.set_url('file:////localhost/'+path+'/Support/webpage.html')
                      Works
                      my_dialog.set_url('file://///localhost/'+path+'/Support/webpage.html')
                      Works
                      my_dialog.set_url('file://////localhost/'+path+'/Support/webpage.html')
                      Works
                      my_dialog.set_url('file://localhost//'+path+'/Support/webpage.html')
                      Works
                      my_dialog.set_url('file:///localhost//'+path+'/Support/webpage.html')
                      Error
                      my_dialog.set_url('file:////localhost//'+path+'/Support/webpage.html')
                      Works
                      my_dialog.set_url('file://///localhost//'+path+'/Support/webpage.html')
                      Works
                      my_dialog.set_url('file://////localhost//'+path+'/Support/webpage.html')
                      Works
                      Any more than 6 /'s before localhost or 2 following, does not work for WebDialog.
                      • Dan RathbunD
                        Dan Rathbun
                        UI::WebDialog.set_file
                        BUG found
                        file:///
                        For this test I have Rick Wilson's lil' html help file in the Support folder:
                        Rename it to .html and put it in the Sketchup Support folder
                        my_dialog=UI;;WebDialog.new('Smustard Organizer Compatibility',true,'test',800,600,100,100,true)
                        SUpath=Sketchup.find_support_file('') #empty string needed!
                        my_dialog.set_file('Support/Smustard_Organizer.html',SUpath)
                        my_dialog.show
                        On the PC this results in MSIE error dialog stating that 'Internet Explorer cannot find the file:
                        "file:///C:/Program Files/Google/Google SketchUp 7/Support/Smustard_Organizer.html"_'
                        Trying various combinations of the set_file method: 1 argument, 2 arguments, etc., I have also been able to get 2 types of error webpages, 'Internal Server Error' and the normal useless 'Cannot Open the Webpage error' with the likely reasons ie: No Internet connection, etc.
                        LESSON
                        UseUI::WebDialog.set_url instead.
                        # Remove leading file separator on Mac (or Win without Drive;)
                        SUpath.slice!(0,1) if SUpath[0,1]==File;;SEPARATOR
                        # File.join will put it back in
                        my_dialog.set_url( File.join('file;//localhost',SUpath,'Support/Smustard_Organizer.html'))
                        my_dialog.show
                        It is quite likely that .set_file actually just calls .set_url passing the latter improperly concatenated pathname string portions misusing the File.join method. (Obviously the set_file method could be fixed using the slice! technique above.)
                        UI.openURL
                        The same technique can (and should) be used with UI.openURL so that code is cross-plaform.
                        • On Mac, testing has shown that OSX wants 'file://localhost' at the begining of the URL or it can't find the file.* On PC, Windows will adjust the URL, stripping off the 'file://localhost' and passing the rest of the path to whatever application is registered for the file extension. (Not always the browser.)
                        WebDialog.new
                        Two things to note here.
                        Comma Separated Parameter List form: IF the pref_key argument is nil or '' (empty string), the remaining arguments are ignored. (This is why I set the key to 'test' in the examples above.) So if you are attempting to make a WebDialog that does not save settings, and it is not showing at the position and size you want, this may be why.
                        Hash as Parameter form: Contrary to what has been said that the dialog_title parameter cannot be set through the hash, it CAN be. However, there is a bug in this new Hash based functionality. In that the Google coder did not take into account that there are several ways of defining a Hash, ie, with Symbol keys or String keys. The coder should have just converted each key using to_s and then made the value assignments based on the keystring, but didn't. So the Hash based form is 'quirky'. You must use Symbolsas keys, NOT Strings:
                        hsh=Hash[:dialog_title=>'Title passed by Hash', :scrollable=>false, :preferences_key=>'MyDialog', :width=>800, :height=>600, :left=>100, :top=>100, :resizable=>true]
                        AND once again if you omit the :preferences_key value pair, it seems the remaining arguments are ignored.. ie default position is 0,0 and size is 250,250 instead of those specified in the hash.
                        Conclusion: Because of the kwappy way the WebDialog API was coded, we must pass ALL parameters or Hash keys (which actually defeats the advantage of the Hash, over a Comma Sep'd Parameter List.)
                        _
                        • 2 / 2
