    Question regarding "from contours" Sandbox tool
    9 Posts 3 Posters 670 Views 3 Watching
    • leedeeteeL
      leedeetee
      Just wondering if anyone can help with a quick question.
      I'm trying to create a simple bit of landscape, with 2 contours, one on "0" the other 1.5m higher. I draw the two contours, then move the higher contour to the appropriate height. I then simply select the two countours, go to sandbox and activate the "from contours" function.
      I however, get this result....
      This can be rectified by manually amending but it takes a while - just wondering if I'm doing anything wrong in the first place?!
      Thanks ....
        have you the file of the initial drawing?
        • leedeeteeL
          leedeetee
          Initial drawing is here, thanks!
          Morley.skp
            Seems you have resolved the problem πŸ˜‰
            • leedeeteeL
              leedeetee
              Sorry, that was the wrong file!!! Sorry! Two seconds! ....
              • leedeeteeL
                leedeetee
                Sorry, CORRECT model is now attached!
                Just needs "from contours" applying to see the problem!
                Morley.skp
                  Maybe like this?
                  Works better with "open curves"! πŸ˜‰
                  • GaieusG
                    Hi Lee,
                    The problem with the "From contours" tool is that it gives these faulty results all the time there are edges exactly above each other. So best is to exclude those edges from the selection when you use the tool first and then just close the faces with a couple lines afterwards.
                    • leedeeteeL
                      leedeetee
                      That's absolutely fantastic, thanks very much chaps. πŸ˜„
