    SketchyPhysics3 FAQ.
    38 Posts 27 Posters 96.5k Views 27 Watching
    • N Offline
      NewOne
      Is there a User Manual for SketchyPhysics3 or not (yet)? I remember that for SP2 was a website http://sketchyphysicstutorial.googlepages.com/, but I don't know if is something for SP3.
        Sgal
        Use of the joints 2
        Other thpes of joints
        1. Corkscrew: Object linked to this joint can spin around his axe and move between maximum and minimum.
        2. Spring: Object linked to this joint can move linearily along his axe. The spring joint will try to bring back them to the first position.
        3. Ball: Object linked to this joint can rotate freely around the joint. The object axe points to the joint.
        4. Universal: Object linked to this joint can rotate almost freely around the joint. Unlike the Ball one, the Universal joint won't allow the object to rotate around his axe. See those images (I found them in an old post of CPhillips) to understand the concept:
          http://www10.atwiki.jp/bambooflow/?plugin=ref&serial=19
          http://www.impulse-based.de/manual_images/balljoint.jpg
          Sgal
          Thanks to =Physicsguy= for the correction.
          I think that an "official" SP manual is a primary need. This plug-in is growing too complex for an immediate comprension for a new user. Maybe a Wiki...
            CPhillips
            Cleaned up the thread a bit. Yeah the faq is getting sort of long. Maybe it should be moved to the new Wiki. ๐Ÿ˜„
              darkPhysics
              [*]How do I make a simple objects
              You can make simple objects using the SketchySolids toolbar as you will se in Flash file.
              Link: http://rapidshare.de/files/46603991/untitled_demo.swf.html
                Mitchieboy
                I still don't know how to activate trusters.. I want to make my jetski work.... please anyone HELP!
                  rfresa
                  @cphillips said:
                  Now that you have installed SketchUp, use the following link to view the latest SketchyPhysics downloads...
                  http://code.google.com/p/sketchyphysics2/downloads/list?can=1&q=&sort=-uploaded&colspec=Filename%20Summary%20Uploaded%20Size%20DownloadCount
                  Again, run it, and follow the on screen prompts. It will install itself in the SketchUp Plugins folder.
                  This is just for windows, right? Because SketchyPhysics never installed itself on my mac. I finally figured it out, but some more info on how to install would be appreciated. For mac users that are reading this: Put the downloaded, extracted files in this folder: username/Library/Application Support/Google Sketchup 7/Sketchup/plugins.
                  I had to create the plugins folder because it wasn't there. Then I got another bug, "Error Loading File SketchyPhysics.rb
                  undefined method `file_loaded?' for main:Object"
                  I found many references to this bug, but no answers, until I found this tip from fernandogalin on the issues page (http://code.google.com/p/sketchyphysics/issues/detail?id=9๐Ÿ˜ž
                  • copy sketchup.rb from Tools folder to Plugins folder
                  • edit sketchyphysics.rb from Plugins folder and add this line at the begining of the
                    file: load "sketchup.rb"
                  This solved my problem and now I can use SketchyPhysics, which I love! This is the awesomest plugin ever. Hopefully this info will save some others from going through the same confusion that I did, so they can get to the good part.
                    togethearth
                    Mmmh, not sure if this thread is still active.
                    BTW, I'd like to share my 2 cents work with the community, I "updated" the Quick Reference Card (mostly for togethearth MAC users at first):
                    http://togethearth.com/files/SketchyPhysics_QuickReference_Card_MAC.pdf
                    If other Mac users find it useful let me know.
                      jonesey429
                      Is there a plugin for SketchUp that computes electrical systems voltage, current, resistance? Or maybe a more complex plugin that accepts more variables?
                        sf741852963
                        why does my SketchyPhysics 3x freeze when I press play? ๐Ÿ˜•
                          arjunmax09
                          where can i get tutorial for sketchyphysics 3...maybe a pdf file...??
                          when you fail at something....you haven't really failed...you've found one way the thing will not work out
                            CPhillips
                            http://sketchyphysics.wikia.com/wiki/SketchyPhysicsWiki
                            • robintR Offline
                              robint
                              Hi all
                              great stuff pls keep it up. I will try to add my 2 cents as i progress
                              I cant post any links or skp models to demo my points, this is very limiting
                              As one door closes another one slams in your face
                                MikeR
                                i got a SketchUp v6 and want to try and learn sketchy physics. what version should i download? thanks ๐Ÿ˜•
                                  demigamer
                                  hey guys
                                  he says where emitters are; its such as ''hidden''
                                  why? i want to make a twilight render
                                  but even sketchyreplay doesn't see my emitters ๐Ÿ˜ž
                                  can someone help me? its for a project ๐Ÿ˜„ so i need it
                                  thanks anyway
                                  greetz,demi
                                    KSJ100
                                    Only SketchySolids works for me!! I have a mac PowerPC 10.5.8 mac!!!!!
                                    the ruby consle says this [img]Picture%201.png[/img]
                                    First click
                                    potentialParent #<Sketchup;;Drawingelement;0xc9d77c0>
                                    Error; #<NoMethodError; undefined method `getKeyState' for #<MSketchyPhysics3;;CreateJointTool;0xc9d8b70>>
                                    /Users/justin/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyPhysics3/JointTool.rb;432;in `onLButtonDown'
                                    First click
                                    Error; #<NoMethodError; undefined method `getKeyState' for #<MSketchyPhysics3;;CreateJointTool;0xc9c26f4>>
                                      KSJ100
                                      First click
                                      First click
                                      • jgbJ Offline
                                        jgb
                                        Hi Chris. I need to get back into SP again.
                                        I "left" only because I found the learning curve got too steep too soon, but now I am determined to get it to work.
                                        BUT.....
                                        "Now that you have installed SketchUp, use the following link to view the latest SketchyPhysics downloads...
                                        http://code.google.com/p/sketchyphysics2/downloads/list?can=1&q=&sort=-uploaded&colspec=Filename Summary Uploaded Size DownloadCount
                                        And which file(s) would that be????? I would have expected the latest file(s) to be, and remain, at the top of the list, but it is buried down and I am confused as to which one(s) I need (Win XP) to get going. ๐ŸŽ‰
                                        jgb
                                          ahnvtk
                                          @sgal said:
                                          can move linearily along his axe.. The object axe points to the joint.. the Universal joint won't allow the object to rotate around his axe.
                                          I believe you mean "axle", not "axe"? ๐Ÿ˜‰
                                          • jgbJ Offline
                                            jgb
                                            Still no answer on which file(s) is the latest release.
                                            I went to the Download page and noticed a few things that make no sense; to me, anyhow.
                                            What is a Deprecated file?? โ“ โ“
                                            Why is the release level not fully defined in the file name?
                                            3.x is meaningless. ๐Ÿ‘Ž ๐Ÿ‘Ž
                                            Why is the "Release Date" column blank? ๐Ÿ˜ฎ โ“ โ“
                                            Why are the file descriptions/summaries so terse and literally non-informative? ๐Ÿ˜’
                                            I sorta expected better than this based on the quality of SP in general and the high level of user support Chris and users deliver.
                                            jgb
