    RDoc question
    24 Posts 5 Posters 2.2k Views 5 Watching
      Trying out Allison - as it was frameless and had a nice quick filter feature. But I get errors trying to build the docs.
      C;\Program Files (x86)\Google\Google SketchUp 7\Plugins\TT_Lib>allison *.rb --main README.txt --debu
      g
      --inline-source will be removed from RDoc on or after August 2009
      Parsing sources with 2 thread(s)...
      100% [14/14]  window.rb
      Generating Darkfish...
      could not find template "C;/Ruby/lib/ruby/gems/1.8/gems/allison-2.0.3/lib/allison"
      C;/Ruby/lib/ruby/gems/1.8/gems/rdoc-2.4.3/lib/rdoc/generator/darkfish.rb;111;in `initialize'
              C;/Ruby/lib/ruby/gems/1.8/gems/rdoc-2.4.3/lib/rdoc/generator/darkfish.rb;90;in `new'
              C;/Ruby/lib/ruby/gems/1.8/gems/rdoc-2.4.3/lib/rdoc/generator/darkfish.rb;90;in `for'
              C;/Ruby/lib/ruby/gems/1.8/gems/rdoc-2.4.3/lib/rdoc/rdoc.rb;314;in `document'
              C;/Ruby/lib/ruby/gems/1.8/gems/rdoc-2.4.3/bin/rdoc;15
              C;/Ruby/bin/rdoc;19;in `load'
              C;/Ruby/bin/rdoc;19
      In that folder there is:
      allison.css allison.js allison.rb
        allison --path returns C:/Ruby/lib/ruby/gems/1.8/gems/allison-2.0.3/lib/allison
        Seem to be missing .rb
        So I tried rdoc *.rb --main README.txt --debug --template "C:/Ruby/lib/ruby/gems/1.8/gems/allison-2.0.3/lib/allison.rb"
        but that resulted in
        C;\Program Files (x86)\Google\Google SketchUp 7\Plugins\TT_Lib>rdoc *.rb --main README.txt --debug -
        -template "C;/Ruby/lib/ruby/gems/1.8/gems/allison-2.0.3/lib/allison.rb"
        could not find template "C;/Ruby/lib/ruby/gems/1.8/gems/allison-2.0.3/lib/allison.rb"
                C;/Ruby/bin/rdoc;19
        I have no idea why. incompatible RDoc version?
          I installed Ruby on a secondary machine. I got the allison to work now. Seem that my ruby installation is a wee bit screwed up.
          But the original rdoc does not support formatting for bold -italic- and underlined etc. and call-seq also isn't recognised.
            and updating rdoc causes the same loss of pragraphs etc... and still missing directive. and it broke the allison template.
            ok. I think I might have to settle for original Rdoc, and use allison with less formatting options. but still wish the directives would work...
              makes so sense that I'm missing the formatting with the RDoc that comes with ruby. http://ruby-doc.org/core/ <- should be supported.
              gaah. why is this not an easy operation?
                Found a solution: bye bye RDoc! Hello Yard!
                http://yardoc.org/
                • Dan RathbunD
                  Dan Rathbun
                  Markup
                  • The markup engine looks for a document’s natural left margin. This is used as the initial margin for the document.* Consecutive lines starting at this margin are considered to be a paragraph.
                  Does RDoc recognize \n ?
                  As in:
                  ` # Returns an Array object.
                  \n
                  Added: 1.1.0
                  def to_a(orient_by_columns = false)`
                  or would that just produce "*n" ?
                  I think I have seen some markup in the standard ruby lib files that had <p></p> embedded.
                  _
                  I'm not here much anymore.
                    The missing paragraphs in Darkfish might just be due to it's CSS style. With the original RDoc they where there.
                    But it would not recognize various directives, couldn't find my README file.
                    The original seemed bugged, as in when you rebuilt it'd rebuild just the changed files, but you'd lose the existing in your index.
                    The exeprience is that it's abig mess.
                    While YARD just worked. Based on RDoc syntax, but with @tags.
                    • Dan RathbunD
                      Dan Rathbun
                      I'll have to bookmark that then. maybe it should go on the Sticky Links page?
                        Maybe. Could be worth to test it first? I've only looked briefly on it, but over the weekend I hope to get time to document my TT_Lib library with it. Then I can say if I recommend it.
                        But I do like the sound of the @tags it has available. Appear to leave more control than plain RDoc. Such as parameter types and return types and version numbering.
                        • Dan RathbunD
                          Dan Rathbun
                          It's sounding better all the time!
                          Keep us advised.
                          • 2 / 2
