    RDoc question
    24 Posts 5 Posters 2.4k Views 5 Watching
      http://workshop.thomthom.net/su-unicode/
      RDoc Documentation
      This is the API documentation for 'RDoc Documentation'.
      How do I change what that says for the RDoc generated documentation?
        Jim
        Did you create a README file? (Just guessing.)
          No. Where's the instructions for that?
          Also: my comments that have multiple paragraphs - they all come out merged.
          	# Returns an Array object.
          	# Added; 1.1.0
          	def to_a(orient_by_columns = false)
          		arr = []
          		self.each(orient_by_columns) { |value|
          			arr << value
          		return arr
          That come out as
          Added: 1.1.0
          No space in between the paragraphs.
          Not getting the space like you see in the docs here: http://rdoc.rubyforge.org/RDoc.html
            MartinRinehart
            Wonder what a "<p>" would do?
              hmm... Only class description can have spaced paragraphs? not methods?
                Not mentioned in the RDoc docs. And I'd really not want to use that. Don't want to be using HTML markup in the comments.
                I do seem to get paragraphs for class/module descriptions. But not methods... 😞
                  I'm wondering if my RDoc installation isn't all that good.
                  From this: http://rdoc.rubyforge.org/RDoc.html
                  :call-seq:
                  Lines up to the next blank line in the comment are treated as the method’s calling sequence, overriding the default parsing of method parameters and yield arguments.
                  to me it only prints out ":call-seq:" ...
                    hmm...
                    C:\Users\Thomas>gem query
                    *** LOCAL GEMS ***
                    fxri (0.3.6)
                    fxruby (1.6.16)
                    hpricot (0.6.164)
                    log4r (1.0.5)
                    nokogiri (1.3.3)
                    ptools (1.1.6)
                    rake (0.8.1)
                    rdoc (2.4.3)
                    ruby-opengl (0.60.0)
                    test-unit (2.0.1)
                    win32-api (1.2.1, 1.2.0)
                    win32-clipboard (0.4.4)
                    win32-dir (0.3.2)
                    win32-eventlog (0.5.0)
                    win32-file (0.5.5)
                    win32-file-stat (1.3.1)
                    win32-process (0.5.9)
                    win32-sapi (0.1.4)
                    win32-sound (0.4.1)
                    windows-api (0.2.4)
                    windows-pr (0.9.3)
                    C:\Users\Thomas>
                    That matches the version number in the docs....
                    • Chris FullmerC
                      Try it using the standard rDoc generator, instead of the fancy Darkfish one you used. See if that helps.
                        Nooooooo! I was looking hard to find a more user friendly and better looking RDoc generator. 😢
                          Would this be correct to make an readme file be the index description: RDoc *.rb --main README.txt ??
                            Darkfish is what the latest RDoc is using.
                            Just tried to reinstall:
                            C;\Users\Thomas>gem install rdoc
                            Successfully installed rdoc-2.4.3
                            1 gem installed
                            Installing ri documentation for rdoc-2.4.3...
                            Updating ri class cache with 2246 classes...
                            Installing RDoc documentation for rdoc-2.4.3...
                            C;\Users\Thomas>
                            still not working...
                              Jim
                              I could never get rdoc to do what I want either.
                              Just some links..
                              Allison: http://blog.evanweaver.com/files/doc/fauna/allison/files/README.html
                              Hanna: http://github.com/mislav/hanna
                              webri (? no idea about this, but it looked relevant): http://webri.rubyforge.org/
                                Trying out Allison - as it was frameless and had a nice quick filter feature. But I get errors trying to build the docs.
                                C;\Program Files (x86)\Google\Google SketchUp 7\Plugins\TT_Lib>allison *.rb --main README.txt --debu
                                g
                                --inline-source will be removed from RDoc on or after August 2009
                                Parsing sources with 2 thread(s)...
                                100% [14/14]  window.rb
                                Generating Darkfish...
                                could not find template "C;/Ruby/lib/ruby/gems/1.8/gems/allison-2.0.3/lib/allison"
                                C;/Ruby/lib/ruby/gems/1.8/gems/rdoc-2.4.3/lib/rdoc/generator/darkfish.rb;111;in `initialize'
                                        C;/Ruby/lib/ruby/gems/1.8/gems/rdoc-2.4.3/lib/rdoc/generator/darkfish.rb;90;in `new'
                                        C;/Ruby/lib/ruby/gems/1.8/gems/rdoc-2.4.3/lib/rdoc/generator/darkfish.rb;90;in `for'
                                        C;/Ruby/lib/ruby/gems/1.8/gems/rdoc-2.4.3/lib/rdoc/rdoc.rb;314;in `document'
                                        C;/Ruby/lib/ruby/gems/1.8/gems/rdoc-2.4.3/bin/rdoc;15
                                        C;/Ruby/bin/rdoc;19;in `load'
                                        C;/Ruby/bin/rdoc;19
                                In that folder there is:
                                allison.css allison.js allison.rb
                                  allison --path returns C:/Ruby/lib/ruby/gems/1.8/gems/allison-2.0.3/lib/allison
                                  Seem to be missing .rb
                                  So I tried rdoc *.rb --main README.txt --debug --template "C:/Ruby/lib/ruby/gems/1.8/gems/allison-2.0.3/lib/allison.rb"
                                  but that resulted in
                                  C;\Program Files (x86)\Google\Google SketchUp 7\Plugins\TT_Lib>rdoc *.rb --main README.txt --debug -
                                  -template "C;/Ruby/lib/ruby/gems/1.8/gems/allison-2.0.3/lib/allison.rb"
                                  could not find template "C;/Ruby/lib/ruby/gems/1.8/gems/allison-2.0.3/lib/allison.rb"
                                          C;/Ruby/bin/rdoc;19
                                  I have no idea why. incompatible RDoc version?
                                    I installed Ruby on a secondary machine. I got the allison to work now. Seem that my ruby installation is a wee bit screwed up.
                                    But the original rdoc does not support formatting for bold -italic- and underlined etc. and call-seq also isn't recognised.
                                      and updating rdoc causes the same loss of pragraphs etc... and still missing directive. and it broke the allison template.
                                      ok. I think I might have to settle for original Rdoc, and use allison with less formatting options. but still wish the directives would work...
                                        makes so sense that I'm missing the formatting with the RDoc that comes with ruby. http://ruby-doc.org/core/ <- should be supported.
                                        gaah. why is this not an easy operation?
                                          Found a solution: bye bye RDoc! Hello Yard!
                                          http://yardoc.org/
                                          • Dan RathbunD
                                            Dan Rathbun
                                            Markup
                                            • The markup engine looks for a document’s natural left margin. This is used as the initial margin for the document.* Consecutive lines starting at this margin are considered to be a paragraph.
                                            Does RDoc recognize \n ?
                                            As in:
                                            ` # Returns an Array object.
                                            \n
                                            Added: 1.1.0
                                            def to_a(orient_by_columns = false)`
                                            or would that just produce "*n" ?
                                            I think I have seen some markup in the standard ruby lib files that had <p></p> embedded.
                                            _
                                            I'm not here much anymore.
