    Creeping bug (WxSU + SU Tool) SU 7 only
    9 Posts 3 Posters 877 Views 3 Watching
      tomasz
      Hi all,
      I have recently a problem with a tool using WxSU library.
      I have created a SU Tool that has a non-modal WxSU dialog associated with it.
      Everything works well, as long as I won't let SU run idle for a while (say 2 minutes). Once I will do it and invoke the dialog (@dialog.show) it starts to display it and stops half way. SU freezes, WxDialog is unresponsive. No bugsplat or error in the console. Same thing happens when I want to close already opened WxSU widnow.
      I have read somewhere that it can be related to GarbageCollector. How can I tackle such a creeping bug?
      Tomasz
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
        remus
        bit of a stab in the dark, but you could try GC.start to kick the garbage collector in to action.
          tomasz
          I have found an adivce to GC.disable and check if the error still happens. Will check it.
            tomasz
            GC.disable didn't help.
            I have found something else. The bug exists in SU 7.1.6087 (Pro), but the script works without a problem in SU 6.4.112 (Free).
            I perform same actions in both programs and only SU7 freezes when opening\closing wxSU window after few minutes of inactivity. SU6 works perfectly.
            I presume this is something only Google people could help me with. I think it has something to do with a way SU refreshes a view.
              tomasz
              After reading that SU uses Ruby 1.8.0 in this thread I have replaced original version with 1.8.6 - officially 'used' version.
              The bug is gone. It looks like WxSU has been compiled to suit 1.8.6.
              Can someone tell me how the compilation of a Ruby Gem looks like from a source?
              == Compilation prerequisites
              • A C++ compiler: MSVC or MingW for Windows; gcc (g++) for Linux and OS X
              • A recent version of SWIG, especially for Ruby 1.9.
              • rake
              • A compiled wxWidgets library, either built yourself or installed from
                via a package manager
              == Setting build options
              If you're compiling on Windows, you must set an environment variable
              to indicate where the WxWidgets libraries and header files can be found:
              set WXWIN=C:/path/to/wxMSW-2.8.9
              The path should be the top-level directory of the unpacked wxWidgets
              tarball; it's recommended that the path does not contain spaces.
              If you have multiple parallel versions of wxWidgets installed, you may
              influence which build is selected by setting or unsetting the
              environment variables WXRUBY_DEBUG, WXRUBY_RELEASE, WXRUBY_STATIC and
              WXRUBY_DYNAMIC. eg
              export WXRUBY_DEBUG=1
              Forces wxRuby to be built against a -debug version of wxWidgets.
              Lastly, you may specifically exclude certain classes; this is most often
              useful if a particular class is causing problems:
              export WXRUBY_EXCLUDE=ThisClass,ThatClass
              == Running the compile task
              From the top-level directory of the unpacked or downloaded wxRuby
              directory, just start the rake build with the command:
              rake
              There is no ./configure step, nor do you need to run ruby
              extconf.rb. wxRuby has approaching 300 classes to generate, compile and
              link, so the process may take some time.
              I have MSVC++ compiler, downloaded source, I presume will have to install 1.8.0 Ruby.
              The most mysterious thing for me in the instruction is the 'rake' thing. Will it do the whole compilation for me?
                tomasz
                There is another solution. I could replace the original Ruby dll with 1.8.6 in an installer of my plugin, but I am afraid that this could upset other plugins.
                Does someone know if any plugin already does that?
                  As a user I'd not be too comfortable with plugins that replace files of my SU installation...
                    And the SU developers has said: the Ruby 1.8.0 implementation isn't a standard Ruby packages. Parts has been customized for SU - which is why I'm very hesitant to change it.
                      tomasz
                      In the thread related to Gem installation Dan compared bit by bit both rubies and they are identical.
                      I would do that if I would be sure that nothing unexpected occurs, but no-one can predict it.
