ℹ️ GoFundMe | Our friend Gus Robatto needs some help in a challenging time Learn More
Couple new pool renders (Vray)
23 Posts 16 Posters 1.8k Views
  • E Offline
    EarthMover
    Been a while since I posted in the Gallery. Here are a few renders from a recent project. All modeling done in SU....Renderer was Vray/Max. Plants are a combination of some 3D trees and the rest from CadPlants.com . I also recently purchased the Cebas PSD Manager which I am absolutely in love with for post processing. I can create channels out of any surface in the render and instantly select items in photoshop. Especially comes in handy when using 2D plants that need levels and saturation adjustments. Background images are actual site photos sent to me by my client, but were pretty low res...tried to make them work the best I could.
    I didn't have a whole lot of time to spend on these, but I'm relatively happy with the overall outcome.(Except the steps in the first render are messed up....I didn't originally intend to do a close up with the steps showing and using Fredo's planar shear was fast but distorted the risers)
    C&C appreciated.
    Content Creator at Skapeup
      ScottPara
      The first three are fantastic! On the forth one the house stands out as being too sketchup. Nice work!
      Scott
      Love the fact that some HATE my avatar.....
        steelers05
        I think these are really nice images. The vegetation definitely looks better in some images than others, but still well done. The second to last image is the most convincing to me. Good work
          dermotcoll
          Super renders - you should be winning loads of work with these images - truly inspiring for a rookie like me.
          When you burn your arse - you gotta sit on the blisters!!
            tomsdesk
            MAN! you got the falling water down!
            2.5D Trees & Shrubs!
              cmoreink
              Great work 😉
              my portfolio
                CaptainsLS
                Nice renders Adam, I’m really digging the planting scheme! The second and third image sells the job for me. Is the pergola a prefab unit? I’d love to see the bases (about half way up the supports) be veneer matching the spa veneer. That would tie everything together IMO. Your waterfalls never cease to disappoint, but the first one is a bit over exposed. Nice work!
                • E Offline
                  EarthMover
                  Thanks for the comments everyone!
                  Captain...the pergola is a prefab. It's the same one I modeled a while ago, just without the shutters. Waterfall was recycled from another job also. I agree on the stone support columns. This is actually not my job, or my design. It's for another contractor out of Missouri. I did the modeling and rendering based off of a few photos and a Dynascape blueprint. Personally, I'm not in love with the planting scheme (or the pergola placement) and would never put three Blue Atlas cedars and three dogwoods together like that, but hey...to each his own.
                  BTW - None of the plants were added in photoshop. They were all faceme components added directly in Sketchup using RPTools component browser, my Cadplants library (which I renamed to include both common and botanical name) and the layer face camera plugin. I can just type in almost any plant name and instantly have a few dozen to choose from and RP tools lets you just click and drop as many plants as you'd like. I swapped some of the generic trees and shrubs out for 3D trees in Max. Also, in Max I typically put all the faceme plants on their own layer and for each render view, I select all the plants at once and rotate them at the parent level which rotates them all on their own axis. It does take time to try and adjust each plant later as a lot of the cadplants are over saturated, but it's still quicker than photoshopping in a whole landscape design for every render, especially when using the PSD manager to assign each plant to it's own channel.
                  Here's a few of the raw renders....they were nothing too special.
                    marked001
                    awesome stuff......great job with the pp... the second to last with the waterfall is definitely my favorite.. but the integration with the background photos in the other (despite being low res) really sells them.
                    http://www.revision21vis.com
                    instagram: revi21on
                    • E Offline
                      EarthMover
                      Thanks Jason! Gotta love Ron's waterfall brushes for PS!
                        CaptainsLS
                        Yeah, I’m not liking the cedars at all. A nice row of blue spruce would be killer… Other than that I like the plantscape. Too bad this isn’t one of yours, I’m sure your gonna have more pools in the pipeline once you finish up the current pool job.
                        • E Offline
                          EarthMover
                          I don't know Captain..I try and keep Blue Spruce away from the pool. Needles are too sharp. I like perhaps Cryptomeria with Crape Myrtles, or keeping the Yellow dogwood and doing Heritage River Birch instead of the Blue Atlas. Fastigiata Blue Atlas might work there, but the regular cultivar gets like 25' wide.
                          I hope to land some more Pool designs and installs. Fact is, I should be out selling spring work right now instead of freezing my azz off doing masonry by day and other contractors designs by night. I'm almost done our current pool job, then I have to try and really market for spring work. Here's a progress timeline of the current pool build I put together - http://www.facebook.com/#/album.php?aid=179089&id=230582785069&ref=mf Kind of neat to see the progression from render to build.
                          • O Offline
                            olishea
                            great work mate
                            oli
                              michaliszissiou
                              Very nice adam, difficult scene, I really like them. 👍 👍 👍
                              • E Offline
                                EarthMover
                                Thanks Michalis and Oli!
                                  d12dozr
                                  Good job Adam, I liked your Facebook album and its clear that you guys know your stuff (that's coming from a cementhead) 😄 Excellent work - on the renders and on the job!
                                  http://goo.gl/f7ooYh
                                  • E Offline
                                    EarthMover
                                    Thanks Marcus. Yeah, the construction is what I'm doing for 50+ hours a week. Running the business, sales, design and rendering gets squeezed into the remaining 30 hours of my 80 hour work weeks. Needless to say, I don't often have near as much time as I'd like to spend on my modeling and rendering. This year, hopefully I can hire a good project manager and get out of the field...although it's in my blood and I'd probably miss it too much!!
                                      stefanq
                                      You can play in the "sandbox" whenever you like! 😆
                                      Adam, you're a man with many skills. I hope you'll get the extra-time that you need so bad.
                                      Regards,
                                      Stefan
                                        teofas
                                        what the F..word!! i thought at first they were photos, wow bro, very nice renders!! only critic is output, i think its too small to enjoy all the details, anyway awsome renders!
                                        http://www.spazioarquitectura.com
                                        • E Offline
                                          EarthMover
                                          Thanks Teo....means a lot coming from your bro! I should probably double my output size. What size do you typically output renders at? My render times were like 12 minutes on these, so I could afford to go bigger.
                                          Stefan, thanks for the kind words.
                                          1 / 2
