    All Ancient Rome models from 3DWarehouse together
    167 Posts 26 Posters 52.9k Views 27 Watching
      OK, although not a "Classic" and not even in Rome (a 4th century basilica in my home town), but the first panorama I could export with a decent quality:
      [flash=640,480:2mmp0vsm]http://www.you3dview.com/viewer/viewer.swf?xml=http://www.you3dview.com/flvideo/310/viewer.xml[/flash:2mmp0vsm]
      It was exported as 6 sides of a box of a QTVR (QuickTime Virtual Tour) from Twilight and put together in GoCubic. With "good" quality settings (between medium and best) and optimised for streaming, it is less than 1 Mb!
      And yes, I know that I have to redo the lights. In fact, this panorama is the first time when I see some mistakes (others were apparent before).
        cadmunkey
        Looks great Gaieus. Some seriously good work in this thread!
          Thanks, Cadmunkey.
          I have also fixed those weird shadows - not the panorama is a bit cleaner.
            pichuneke
            No paintings? Were fragments of paintings found in the archeological exavation?
            That white walls are not very roman, although I know that Spain is not Hungary...
            (And yes, good work and so on... πŸ˜† )
            Forgive my spanglish...
              No paintings were found but some evidence of plastering. As this project must be as minimalist as possible (with a reconstruction, you always have to go for the "simplest possible" solution to avoid being influenced by your imagination and romantic sentiments), this is how "archaeologically" it can be done.
              Then, is I wish, I can add frescos when I export it into a game engine πŸ˜„
                pichuneke
                Which one? You can count on me πŸ˜„ (if you want).
                  Well, that was just an example. πŸ˜„
                  We have beautiful frescos in the Roman cemetery though.
                  πŸ˜‰
                  (Google search depends on your location and language settings - I don't know what the above link will give to you - hopefully "safe search" is on on your browser! πŸ˜„ )
                    pichuneke
                    Well... I was refering to which game engine πŸ˜†
                    Textures for roman paintings are as we say in spain "a headache". It's problematic to find good ones. Anyway I want to make some of the in the future (too much things for the future... when I have time) for my model of the roman theatre.
                      Yes, I know what you meant with the game engine - and that's what I also meant; if I want to use the model for something "more liberal" than this archaeological reconstruction, I am free to do it - "say" in a game engine.
                      Our paintings here are all Christian (many Biblical scenes and such) but they would still need some photoshopping πŸ˜„
                      • Z Offline
                        Z-Akh69
                        Hi everyone,
                        Here is a comparison between my work and L.VII.C.'s Vespasian temple.
                        I did not put the capitals on this image because they are not completed.
                        What do you think ? πŸ˜’
                        http://img709.imageshack.us/img709/7876/templedevespasiendg.jpg
                        http://img704.imageshack.us/img704/3688/templedevespasiendf.jpg
                        • DanikD Offline
                          Danik
                          Gaieus, amazing render. As I see you avoid defects with lighting in it.
                          I've finished rendering of my previous model - roman Pantheon. I took into account latest advices to improve render quality. Also I've added the rays as you can see.
                          [flash=500,400:3i0lgp5s]http://www.you3dview.com/viewer/viewer.swf?xml=http://www.you3dview.com/flvideo/319/viewer.xml[/flash:3i0lgp5s]
                          Z-Akh69, as for me the models are both intersting and well done. Your model is a little bit more detailed. But we have to take into account than the temple which made by L.VII.C. is only the part of the great and beautiful ensemble, so it's normally that it is less detailed.
                          • Z Offline
                            Z-Akh69
                            Yes, I know. I modeled a maximum of detail because I want to import the model into Zbrush for transform reliefs in normal map ! πŸ˜‰
                            Congratulations for the render, the pantheon is an beautiful building. I've already visited three times and I'm always fascinated.
                              Yes, Z-Akh, really nicely detailed model (although of course, I would not throw L.VII.C's away either πŸ˜„ )
                              Danik:
                              Textures, textures and textures. Beside a good model (which this Pantheon is indeed), 70-80% of a good render depends on textures.
                              (I have also seen your Nerva forum render - the same there. Some of the textures are very repetitive and need some care).
                              This Pantheon is very cool. Good idea NOT to place the camera completely into the middle (as little fantasy as I have, I would have πŸ˜’ ). Some interior lights and some very subtle soft shadow would liven it up a bit I think
                              (Hope you don't mind the critiques - you know that I love these panoramas and renders - and only want to see them even better)
                              πŸ˜‰
                              • Z Offline
                                Z-Akh69
                                L.VII.C's temple is nice too but i'm very maniac so i want to build the same temple with real proportions. πŸ˜‰
                                With a render, his model is more beautiful than mine because the entablure is short. Mine is real but too massive.
                                • DanikD Offline
                                  Danik
                                  Thanks Gaieus πŸ˜„
                                  Actually these are my old models when I haven't enough good textures, now I'm planning to re-texture them, so in future you'll have the opportunity to see the changes.
                                  Panorams of the forums:
                                  Forum of Nerva:
                                  [flash=500,400:5kxuqtcm]http://www.you3dview.com/viewer/viewer.swf?xml=http://www.you3dview.com/flvideo/320/viewer.xml[/flash:5kxuqtcm]
                                  Forum of Vespasian:
                                  [flash=500,400:5kxuqtcm]http://www.you3dview.com/viewer/viewer.swf?xml=http://www.you3dview.com/flvideo/321/viewer.xml[/flash:5kxuqtcm]
                                  • Z Offline
                                    Z-Akh69
                                    Beautiful render Danik !
                                    Maybe you can place few 2D character in the scene. How many time for the renders ?
                                      Two more suggestions, Danik:
                                      I don't know if the proportions of those stone slabs covering the fora are correct but they seem to be enormous to me.
                                      Also, could you raise the camera height just a little bit? I know that these fora are grand but with a little bit of added height, it would be more "comfortable" to view them. Now they are too depressingly big (which they used to be, surely so maybe I am not right).
                                      And of course, I have already seen them (as I am subscribed to your "channel" or what and receive email notifications)
                                      πŸ˜‰
                                      • Z Offline
                                        Z-Akh69
                                        The difference in the forum :
                                        http://img706.imageshack.us/img706/1418/24522005.jpg
                                        http://img690.imageshack.us/img690/5315/97259656.jpg
                                        πŸ˜„
                                        • DanikD Offline
                                          Danik
                                          Z-Akh69, each of these renders take about 3-4 hours
                                          Two more renders of baths of Caracalla.
                                          Caldarium:
                                          [flash=500,400:1dm3i1z6]http://www.you3dview.com/viewer/viewer.swf?xml=http://www.you3dview.com/flvideo/324/viewer.xml[/flash:1dm3i1z6]
                                          Tepidarium:
                                          [flash=500,400:1dm3i1z6]http://www.you3dview.com/viewer/viewer.swf?xml=http://www.you3dview.com/flvideo/325/viewer.xml[/flash:1dm3i1z6]
                                          • Z Offline
                                            Z-Akh69
                                            Beautiful render !
                                            It's very sad that buildings so beautiful as this one have disappeared! Thank you for putting the characters to get an idea of the scale. πŸ‘
                                            • 5 / 9
