    Follow me, if you feel like it I guess
    4 Posts 3 Posters 387 Views 3 Watching
      Alleyviper
      I was attempting to create the head of a screw with SU and noticed something odd with the follow me tool. I would start by drawing a 2d circle on the ground about 1/8" diameter. Then, I would draw a line up from the center of the circle about 1/8". Using the arc tool, I would draw the shape of the screw's head out from the top of the center line to the outer edge of my circle. Then, draw a line from the bottom of that arc to connect it to the bottom of the center line. I know this is hard to follow but basicly what I have at this point is a circle on the red axis and the shape of half of my screw head on the blue axis. Now, I use the follow me tool to drag the screw head around the circle hopefully ending in what should resemble the top half of a sphere right?? No, I end up with a smaller circle on the red axis or a partial shere with faces missing. When I do the exact same process but scale everything up from inches to feet, I get the result I'm looking for. Why is the follow me tool acting silly on small scale items?
        d12dozr
        This is one of SU's limitations...the workaround is to scale up by 100, do the modeling, then scale back down by 100. SU will not make faces smaller than about 1/16".
        http://goo.gl/f7ooYh
          yeah, what Marcus says.
            Alleyviper
            bah. Ok thank you.
