    Ruby right write
    13 Posts 4 Posters 1.0k Views 4 Watching
    • chrisglasierC
      chrisglasier
      If reading a file is defined
      def load_json(file)
      subDir = "nset/Sketchup/"
      path = File.join(File.dirname(__FILE__), subDir, file)
      json = IO.read(File.join(File.dirname(__FILE__), subDir, file))
      how to define write?
        hmm..
        I never use the IO class directly to read/write files.
        I use the File class's methods.
        # Read Files
        f = File.open(file, 'rb')
        # read from file
        f.close
        # Write Files
        f = File.open(file, 'w')
        f.puts 'hello world'
        f.close
        • chrisglasierC
          chrisglasier
          Thanks Thom. Actually Jim wrote that and he should be asleep. I don't understand (File.join(File.dirname(__FILE__), subDir, file)) - why it has to be joined. Do I need to know. Is it relevant to writing?
            The join method ensures that when you combine parts of a filename that it's compiled correctly, with forward slashes etc /. It return a fully compiled path to your file.
            • chrisglasierC
              chrisglasier
              Thanks again
              • chrisglasierC
                chrisglasier
                One other thing has come from this. I can write to the same file using Ruby or activeXObject in an .hta. The Ruby version adds an extra empty line which throws an "unterminated string constant" error when read. Any idea about what is going on?
                function coreRubyReq(callback, params) {
                	window.location = "skp;" + callback + "@" + params.join(';');
                function coreJsonSave(fileName, json) {
                	var ForWriting, objFSO, objFile, txt;
                	txt = JSON.stringify(json);
                	if(config.SU === 1){
                		coreRubyReq('save_json', [fileName, txt]);
                	else{
                		ForWriting = 2;
                		objFSO = new ActiveXObject("Scripting.FileSystemObject");
                		objFile = objFSO.CreateTextFile(fileName, ForWriting);
                		objFile.Write( txt );
                		objFile.Close();
                @dlg.add_action_callback("save_json") { |d, a|
                			p = a.split(";")
                			file = File.join(File.dirname(__FILE__), subDir, p[0])
                			f.puts p[1].to_s
                			f.close
                  hmm...
                  extra line? at the end? or for each line?
                  Could be that my example opened the file as binary.
                  #binary read
                  #normal read
                  f = File.open(file, 'r')
                  This the latter treats line breaks differently. (linebreaks are different from platform to platform)
                  • chrisglasierC
                    chrisglasier
                    I left Jim's for the read and used yours for the write.
                    • chrisglasierC
                      chrisglasier
                      Maybe if I pass it though a hidden input?? I should do that anyway - forgot!
                        ? to get rid of extra lines?
                        • C
                          cjthompson
                          > 			p = a.split(";")
                          > 			f.puts p[1].to_s
                          > 			f.close
                          I think the problem is
                          f.puts p[1].to_s
                          Try using
                          f.write p[1].to_s
                          • chrisglasierC
                            chrisglasier
                            Works ... thanks Chris
                              Jim
                              I think it's odd that the parser would be sensitive to a newline at the end of the file.
