    [Plugin] PLY Importer
    33 Posts 7 Posters 111.1k Views 7 Watching
      @jim said:
      Some .ply files are huge, and both the import and the resulting model may bring SketchUp to a "white screen" state.
      Performance is greatly improved if you create a PolygonMesh and use Entities.fill_from_mesh.
        Jim
        I need another me.
          jim2 = jim.clone
            Jim
            Ok, new version posted - uses PolygonMesh.
              hm...
              while true
                jim.clone
              πŸ˜„
                Jim
                Here's a reasonably-size example:
                http://www.cs.virginia.edu/~gfx/Courses/2001/Advanced.spring.01/plymodels/cow.ply
                Moo.
                • N
                  notareal
                  Nice. Expecting to see some Chinese gardens with high poly dragons?
                    driven
                    import works,
                    and scrubs up, OK
                    but, how do you skin a cow on a Mac?
                    this could be very handy, but the skinning is not working on mac? is it possible to tweak the code?
                      Jim
                      I don't understand SketchUp sometimes - my cow looked fine and was skinned on import. I did not need to do any cleanup.
                        driven
                        how do I revert to standard import to see if it bring faces?
                          maybe the data is read somewhat differently on Mac..?
                            Jim
                            Line endings? Seems doubtful, but maybe.. will check.
                              that - or interpretation of commas/periods depending on locale settings...
                              stabbing in the dark here
                                Jim
                                After reading the spec again, I'm surprised my "naive" implementation from 2006 works at all. I probably had the same thought then as I am having right now - it's hardly worth the effort for such an obscure file format. Good programming exercise, though.
                                  driven
                                  Hi again,
                                  I certainly don't NEED it enough to warrant any effort, importing via MeshLab as either odj, dae or dxf is very painless on a mac, for the odd occasion that I'd want to.
                                  the cow, which I copy pasted into a text file, re-named cow.ply is the only .ply I've had any success importing to SU and it won't open in MeshLad (I get a missing header message)
                                  I'm more in need of 'skink-wrapping' of complex engineering geometry which I can't seem to find for Mac SU usage.
                                    Jim
                                    I re-wrote this so it should work with most ascii .ply files that have vertex and face elements. See first post for download.
                                      driven
                                      Hi Jim, thanks
                                      I'll try it out later on and see if there's still a Mac issue, cheers
                                      BTW have you ever had a play with Apanta Studio, the PC editor [that's now ported to Mac?]
                                        driven
                                        took longer to upload the Jpeg then to load into SU so that's very good, but I now have a request because I may have a use... can it import into a component, to save SU re-calculating all the faces?
                                        came in so fast
                                          Jim
                                          If there is any geometry in the model (i.e. the model is not empty,) then the import is made in a Group. Will that work?
                                          Glad to see it working.
                                            driven
                                            yep, there some very good .ply figures out there for just dropping in for a render and casting off... and group scale and move well enough.
                                            cheers
                                            jhon
