    Fredo related plugins
    8 Posts 4 Posters 526 Views 4 Watching
      red_shift
      I am on Mac OS 10.6.2 and SU 7.1.58. I have downloaded and installed the latest Libfredo6 the latest Roundcorner, the latest tools on surface. None of these show up when I start SU. Can someone please give me some advice about how to fix this? There are no error messages, just no menus of any sort or indication that the plugins have loaded.
        Jim
        Do you need to enable them in the Window > Preferences > Extensions dialog?
          Also, note the Installation description in RoundCorner (Also apply to Fredo's other plugins) see the screenshot of the footprint.
          When you download RoundCorner 2.1c.zip you should get a folder and a .rb file. However, I've noticed on OSX, that it seem to create a folder RoundCorner 2.1c which contains these files. If you've copied this folder into your plugins folder it won't work - you must locate the ROUNDCORNER_Dir_21 folder and ZLoader__RoundCorner.rb and copy those files to the plugin folder.
            red_shift
            Here is a screen shot of my plugins folder...I think I have done things correctly, but there must be a mistake somewhere. I also moved the
            .plugin files into the Sketchup application package..
              @red_shift said:
              I also moved the
              You're not supposed to do that.
              The .plugin files in Fredo's zip files are not the same as what you got in the app package. Leave them where they where.
              And where have you tried to install the Sketchup plugins? They should go into Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins Not anywhere else.
                red_shift
                Thomthom: The first suggestion did the trick! Thank you very much..have been struggling with this for weeks. Now to figure out how everything works πŸ˜„
                  πŸ˜„ πŸ‘
                    romain210
                    thanks a lot
