    SU Plus Concrete
    16 Posts 7 Posters 2.4k Views 7 Watching
    • michaliszissiouM
      michaliszissiou
      I like your trees too. As for blender, try to get involved in the UV mapping and use texture maps, procedural textures are not the best choice there. πŸ‘ And give an emitting value of 0.001 to the material so radiosity will do its job. If you have problems with memory and speed, please don't do this for leaves textures. But at least do it for the ground.
      • david57D
        david57
        The trees are particles painted on a plane. The grass are also particles.
          Rico91
          nice building!
          i like separate buildings, so this is a good one! πŸ˜„
          [img:y90a5vdg]http://lh5.ggpht.com/_rMc47FEl0fA/Sro-DozMGPI/AAAAAAAABwU/zZsLbdpwWAs/forum_onderschrift_r3d_30pxh.jpg[/img:y90a5vdg] [url:y90a5vdg]http://www.R3Design.nl[/url:y90a5vdg]
          • david57D
            david57
            Tweaking things up like Lighting, Shadow, Materials. Hard to get it right.
            • michaliszissiouM
              michaliszissiou
              Interesting grass in the last one. No GI though.
              • Chris FullmerC
                I agree, what is the grass in the last one?
                • F
                  FoXar
                  I go with both of them, the last one has great grass, if you would like to improve I would use some real concrete textures, maybe you could combine some
                  and add seams so the home seems not to be made out of one piece like it is now, also be sure to add more vegetation, tree's, flowers ion the grass, some foliage,..
                  But it's improving already! Good work πŸ‘ , keep on going like that
                  • david57D
                    david57
                    Ok, Here's the settings i used for that last render.
                    Settings start at the left and continue on the right.
                    • michaliszissiouM
                      michaliszissiou
                      For everyone who doesn't understand, this is blender 2.5 particles system.
                      Try to render on the old 2.49b, give a slight emit value on the ground (0.002), turn-on radiosity on renderer. V 2.5 has not radiosity function, a new quality fast renderer is coming soon.
                      • david57D
                        david57
                        Oh, didnt put the size of the grass blades. You can find it under Material, called strand.
                        • david57D
                          david57
                          An update. Still trying to figure out grass particles.
                          I duplicated one section of grass and pasted in front but it looks two tone.
                          • david57D
                            david57
                            Here's more of the same.
