    SU Plus Concrete
    16 Posts 7 Posters 1.9k Views 7 Watching
    • david57D Offline
      david57
      Messing around with another model.
        rickgraham
        Looks cool - I'd like to see the floorplan/inside. The structural engineers aren't going to like you. πŸ˜‰
        Rick
        • david57D Offline
          david57
          Here's a quick render with blender. Settings were low and render is poor quality.
          Ran out of memory, using a single core laptop.
            dylan
            It's a very cool looking building and I like your first render. It has a lot of potential.
            http://dmdarchitecture.co.uk/
            • michaliszissiouM Offline
              michaliszissiou
              I like your trees too. As for blender, try to get involved in the UV mapping and use texture maps, procedural textures are not the best choice there. πŸ‘ And give an emitting value of 0.001 to the material so radiosity will do its job. If you have problems with memory and speed, please don't do this for leaves textures. But at least do it for the ground.
              • david57D Offline
                david57
                The trees are particles painted on a plane. The grass are also particles.
                  Rico91
                  nice building!
                  i like separate buildings, so this is a good one! πŸ˜„
                  [img:y90a5vdg]http://lh5.ggpht.com/_rMc47FEl0fA/Sro-DozMGPI/AAAAAAAABwU/zZsLbdpwWAs/forum_onderschrift_r3d_30pxh.jpg[/img:y90a5vdg] [url:y90a5vdg]http://www.R3Design.nl[/url:y90a5vdg]
                  • david57D Offline
                    david57
                    Tweaking things up like Lighting, Shadow, Materials. Hard to get it right.
                      michaliszissiou
                      Interesting grass in the last one. No GI though.
                      • Chris FullmerC Offline
                        I agree, what is the grass in the last one?
                        • F Offline
                          FoXar
                          I go with both of them, the last one has great grass, if you would like to improve I would use some real concrete textures, maybe you could combine some
                          and add seams so the home seems not to be made out of one piece like it is now, also be sure to add more vegetation, tree's, flowers ion the grass, some foliage,..
                          But it's improving already! Good work πŸ‘ , keep on going like that
                          • david57D Offline
                            david57
                            Ok, Here's the settings i used for that last render.
                            Settings start at the left and continue on the right.
                              michaliszissiou
                              For everyone who doesn't understand, this is blender 2.5 particles system.
                              Try to render on the old 2.49b, give a slight emit value on the ground (0.002), turn-on radiosity on renderer. V 2.5 has not radiosity function, a new quality fast renderer is coming soon.
                              • david57D Offline
                                david57
                                Oh, didnt put the size of the grass blades. You can find it under Material, called strand.
                                • david57D Offline
                                  david57
                                  An update. Still trying to figure out grass particles.
                                  I duplicated one section of grass and pasted in front but it looks two tone.
                                  • david57D Offline
                                    david57
                                    Here's more of the same.
