    Help with Components
    30 Posts 3 Posters 4.8k Views 3 Watching
      Are you doing anything to the comp_entities variable?
      if you add right before your add_group
      adebug = comp_entities.to_a.select { |e| !e.is_a?(Sketchup;;Entity) }
      adebug.inspect
      What does it output? That snippet should return an array of everything in that collection which isn't inherited from Sketchup::Entity.
      • honoluludesktopH
        honoluludesktop
        At this time, I am not doing anything, just trying to group the array of entities. Once I figure how to do that, I will place my procedure (rotates one of the entities) in the if-end "block" (is that the right word?).
        • Chris FullmerC
          In your snippet there, the variable comp_entities is pointing to an entities object. That is not what .add_group is expecting. That is what the error is. .add_group is expecting a single entitiy OR an array of entities. So just change the loine to this and see if it works:
          my_group = entities.add_group(comp_entities.to_a)
          I just added a .to_a to turn the entities object into an actual aray. Now it should work, I think.
          • Chris FullmerC
            ok, and I just got onto a machine with SU on it. I tested what happens if I explode a group and then try to add the entities returned in the explosion to a group. And I got the error about adding entities with the same parent. So far so good.
            I found that exploding the component instance does not return the inner geometry of each sub-component like I thought it might be doing. So there really is no need to test the parent of each entity. It is just a matter of making an array of only the parts you want.
            So I exploded the component instance, and I then made an array of just faces, edges, groups and componentinstances. And then added that array to a new group and it worked just fine. Here is what that code looks like:
            model = Sketchup.active_model
            ents = model.active_entities
            explode_array = model.selection[0].explode
            good_ents = []
            explode_array.each do |e|
            good_ents << e if e.is_a? Sketchup;;Face
            good_ents << e if e.is_a? Sketchup;;Edge
            good_ents << e if e.is_a? Sketchup;;Group
            good_ents << e if e.is_a? Sketchup;;ComponentInstance
            ents.add_group( good_ents )
            And that works from the web console with a single component Instance selected, and it can have sub components and sub groups (but not sub-images since I didn't test for those.
            Anyhow, I hope it helps. But in the end I think you might be better off approaching this entirely differently.
              If you are rotating (or tranforming) everything inside a componentinstance, apply your tranformation to all the entities by using Entities.transform_entities http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#transform_entities
              Chris, that snippet can be made easier if you check for inheritance from the Drawingelements instead of individual classes.
              good_ents = explode_array.select { |e| e.is_a?(Sketchup;;Drawingelement) }
              • honoluludesktopH
                honoluludesktop
                Thanks, Guys. Not able to get back to this tonight, will try tomorrow night.
                • Chris FullmerC
                  I like that Thom. I've also seen you use "select" a few times recently. I'll try to look at it, but is it different than collect? I recently ran across that one, and I never rememeber to use it. But they both appear to do about the same thing, and are remarkably useful for populating an array.
                    They are not the same.
                    Enumerable.collect (alias Enumerable.map)
                    arr = [0, 1, 2, 3, 4] arr.collect { |i| i * 2 }
                    returns: [0, 2, 4, 6, 8]
                    I use it for instance to collect Point3ds from vertices collections.
                    points = face.vertices.collect { |vertex| vertex.position }
                    Enumerable.select (alias Enumerable.find_all)
                    arr = [0, 1, 2, 3, 4] arr.select { |i| i%2 > 0 } # block returns true if i is an odd number
                    returns: [1, 3]
                    I recently noticed this:
                    Enumerable.partition
                    arr = [0, 1, 2, 3, 4] arr.partition { |i| i%2 > 0 } # block returns true if i is and odd number
                    returns: [[1, 3], [0, 2, 4]]
                    Also rather handy.
                    The Enumerable module, which the Array class includes, has a number of very nice methods which I've found do many of the things I often do with arrays. I just haven't noticed them, partly because not everything in the Enumerable module isn't listed in the Array class docs.
                    model.selection.all? { |e| e.is_a?(Sketchup::Edge) }
                    or
                    [ruby:af7phbud]model.selection.any? { |e| e.is_a?(Sketchup::Edge) }[/ruby:af7phbud]
                    • Chris FullmerC
                      Wow those are great Thom. I see the difference now there with collect and select. And I really like that partition method. Not sure where I'd use it right now, but I have a feeling it might come in handy eventually.
                        Those five methods there has cut down many lines in my older codes. 😄
                        • honoluludesktopH
                          honoluludesktop
                          Hi Guy, Finally got around to working on my program, and thanks to you it works. I have one question. How do I understand the following bit of code?
                          comp_new = comp_entities.select do |e|
                          Sorry for the long-hand, but it helps me to read my code, perhaps when I get better:-}
                            your variable name is a bit confusing. "comp_entities" is the resulting array from .explode ? Assuming it is:
                            "comp_new" sounds like it's a ComponentInstance or ComponentDefinition, but in this case it will be a collection of entities.
                            Example of .select: arr1.select will return a new array will all the elements of arr1 when the block returns true.
                            In your case, you have an array returned from .explode. That array contains lots of thing you don't want. But the common denominator for the items you do want is that they inherit from the DrawingElement class. So we use the .select method to extract only the items that inherits from that class e.is_a?(Sketchup::Drawingelement).
                              Yes.
                              When you see in the API manual, for the Face class for example: http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html
                              Notice it says: Parent: Drawingelement
                              And the Drawingelement class says Parent: Entity
                              And the Loop class: Parent: Entity
                              So a Face
                              .is_a?(Sketchup::Face) == true
                              .is_a?(Sketchup::Drawingelement) == true
                              .is_a?(Sketchup::Entity) == true
                              But a Loop
                              .is_a?(Sketchup::Loop) == true
                              .is_a?(Sketchup::Drawingelement) == false <- Notice
                              Because the relationship of a Face is:
                              Sketchup::Face < Sketchup::Drawingelement < Sketchup::Entity < Object
                              While a Loop is:
                              Sketchup::Loop < Sketchup::Entity < Object
                                The Object Diagram is a nice graphical overview of the classes relationships: http://code.google.com/intl/nb/apis/sketchup/docs/diagram.html
                                  @honoluludesktop said:
                                  Yes, "comp_entities" is the exploded array. OK, so when I see is_a? in this manner, the do loop is "select(ing) the entity(s)" in the array that is a (are) %(#FF0000)Sketchup::Drawingelement. Is it faster (better) then:
                                  >   if e.is_a? Sketchup;;Drawingelement
                                  >     comp_new.push e
                                  >   end
                                  > end
                                  In your examples, what you mean to do is:
                                  comp_entities.each do |e|
                                      comp_new.push e
                                  Notice the .each instead of .select
                                  .each is a simple iterator - it does not return any values.
                                  .select returns a new array - where the content depends on when the block yields true.
                                  comp_new = []
                                      comp_new.push e
                                  Does the exact same thing as:
                                  Can also we written as one line:
                                  comp_new = comp_entities.select { |e| e.is_a?(Sketchup;;Drawingelement) }
                                  There are many ways to do things - but Ruby has many useful methods for repeated tasks that saves your from typing the same code structure over and over again.
                                  In these examples - I'm not sure if anyone is any significantly faster than the other. But .select saves some characters.
                                  • honoluludesktopH
                                    honoluludesktop
                                    Opps, I meant comp_entities.each. Thanks for the lesson.
                                    • honoluludesktopH
                                      honoluludesktop
                                          comp_new.push e
                                      Addenda: Corrected as noted below.
                                      • 2 / 2
