Raise an Object
How do I raise an Object/Entity in SketchUp?
all of my objects/Entity's are on ground level, i want to raise a of themIm trying to create a bed frame for my mattress.
I have the Bed frame, the bed mattress, and the legs all separate (as an Entity)
Also is there an Autosnap/(stick to guide) feature for entities? So I can snap the legs into place with my bed frame?
I have my file im working with attached to this post.
Thanks in advance.
@ThorsonB -
[flash=640,505:3w2l9v2o]http://www.youtube.com/v/2e095bSztLs&fs=1[/flash:3w2l9v2o]
[flash=640,505:3w2l9v2o]http://www.youtube.com/v/rDvwHon6-zY&fs=1[/flash:3w2l9v2o]
I highly recommend watching all the SketchUp videos before doing anything in SketchUp:
http://sketchup.google.com/training/videos.html -
Hi ThorsonB, hi folks.
If your objects have been modeled as components on the ground, they may be glued to the ground. Right click on any object and see if you have a choice labeled "Unglue" in the contextual menu. If so, choose it and now you shall be able to move the object up or down.
Just ideas.
With your input, this post could be even better š
