    (REQUEST) Terrain generation plugin
    8 Posts 5 Posters 1.8k Views 5 Watching
      Starlex
      Hello!
      Does anybode know plugin for terrain generation?
      I'm working in landscape modelling and need to transform surfaces to make them look lile terrain.
      There is no need in horizontal lines, just simple little unevenness of the terrain
      • numbthumbN Offline
        numbthumb
        Hello there!
        So SU Sandbox tools are of no use in that case?
        Comfortably numb...
          @starlex said:
          ...just simple little unevenness of the terrain
          If you really just need "littleunevenness", start from a Sandbox generated TIN (as NT suggests) and have a look at this plugin - Randomize Tin (by Jim).
            numbthumb
            Thanks for reminding me of Randomize Tin plugin, Gaieus.
            BTW I had to look twice to realize what NT means... 😄
            Comfortably numb...
              Starlex
              That's almost good)
              And it will be the best, if it will be able to add more "glitter" - to make more little unevenness (smile). Give me more! (smile)
              Thanx a lot)
                You can always use the Smoove tool to give your terrain a larger scale unevenness (as suggested above) and use this plugin to add the overall, smaller unevenness. The two combined, should give you quite good results.
                  AcesHigh
                  get Terragen 1, create a terrain using any of its procedural methods, modify as you wish, export as gray image. Then, if I am not mistaken, you can import/modify a Sketchup mesh from a heighlevel image like the ones exported by Terragen (with a plugin).
                  • soloS Offline
                    An overlooked Gem is the Sculpt tools, great for small detailed terrains.
