    Final streetscape - sketchup, twilight, photoshop
    66 Posts 16 Posters 13.8k Views 16 Watching
    • FrederikF Offline
      Frederik
      Perhaps I shouldn't comment on this, but I really can't see the huge difference you guy's can... 😕
      Cheers
      Kim Frederik
        meak
        bravo,
        pretty light and textures.
        lovely ambience.
          kwistenbiebel
          I find the architecture quite interesting....
          and you seem to visualise the idea quite well. Nice renders.
          The Podium v 2.0 (beta) colors are indeed very nice. I am looking forward at the Christmas break to get into the new render engine.
          The Twilight renders are nice as well. Any pure Physical sky shots?
          • olisheaO Offline
            olishea
            frederik: the main difference is quality and colour. Podium 1.x renders were generally quite cold due to physical sky. Remember we are comparing Podium v2 to Podium 1.x (not podium vs twilight god forbid!!)
            biebel: I don't get you....you wanna see a physical sky render for twilight?
            oli
              rickgraham
              I like the colors alot better with v2 - more vibrant, however the grass doesn't look as nice as previous renders - is this because this a v2 work in progress like the trees too?
              Rick
                kwistenbiebel
                Or Podium v2...it doesn't matter which one.
                The reason why I ask is that in all the above renders, the sky seems to look just a bit too dark.
                That's why I would like to see what came out using pure Phys sky, without a sky image overlay in post.
                • olisheaO Offline
                  olishea
                  I made the sky a bit darker to balance the dark tarmac at bottom of image. maybe too dark but what the hell....lets have a saturated cheery sky for the planners to put a smile on their faces! I normally apply a vertical black gradient to the sky with overlay belnding mode to make it more punchy....but sometimes I go too far lol.
                  Rick I added the grass in photoshop....so its different in each image....im not very good at putting grass in yet!! its mostly trial and error lol. The tree issue affects pngs with transparency (but not all)....the podium team will fix this no doubt. remember this is just the very first beta of version 2.
                  Biebel: the v2 beta physical sky cannot be changed in this version of the beta. But the sky is pretty much raw render....i only added the clouds over the raw physical sky. So the colour and tone of the sky is as you would see it in the render. I would post the raw render but I'm not at work computer. But yes it is quite dark, I agree....but I like it! Podium team mentioned implementing hdri support and other sky options so it looks very promising.
                  Don't look too much into this image guys, i only spent 5 minutes setting up materials. It's not supposed to be a comparison of render engines....let's never go down that track again! podium and twilight are brothers not enemies. (as Miguel aka Ecuadorian quite rightly said)
                  Probably not gonna post much around xmas so if I don't say it before.....
                  HAPPY CHRISTMAS GUYS AND HAVE A GREAT NEW YEAR
                                            GET PISSED UP AND HAVE A GOOD TIME!!
                  oli
                    cadmunkey
                    Oli I think youve done a fantastic job in visualising the architects design. I like pretty much every image and can relate to the project as I'm only an hour away from you in Yorkshire 😉
                    My only crit would be directed towards the architect.. if your council estates are anything like ours then any smooth surface gets covered in grafitti pretty quickly and these houses are a grafitti artists dream.
                    Anyway have a good Xmas and keep up the good work next year. 😄
                      johnsenior1973
                      I disagree.
                      It may be the case that a cheap and nasty council estate finds itself plastered with graffiti, but I don't see this is a cheap and nasty council estate.
                      I might be wrong, but I think if that building was built it would be treated with a fair amount of respect.
                        cadmunkey
                        I'd like to agree, but Councils dont get to pick and choose their tennants. Its the people that make up the estate, and as you know council estates are predominantly made up from lower income families and have much higher crime rates.
                        Anyway, I hope its a successful scheme long term, as most estates are damn ugly to look at.
                        • olisheaO Offline
                          olishea
                          I agree. however we have more than taken this into account and all surfaces are robust enough to be stripped of graffiti etc. it was one of the first criteria in selecting each material...the wood for example is heavily laminated and vandal-proof.
                          johnsenior: although you are correct in your assumption that the houses would be trated with a fair level of respect....unfortunately there is a minority of (how should I put this) arseholes.
                          oli
                          • michaliszissiouM Offline
                            michaliszissiou
                            Volumes look heavier using podium v2. Much heavier than kerkythea, twilight or podium v1.x.
                            Nice work here Oli. 👍 👍 👍
                            • olisheaO Offline
                              olishea
                              Thanks, it means a lot.
                              😍 Merry Christmas to you Michalis. have a good one! 😍
                              oli
                                cadmunkey
                                Cutouts need a bit of work but I'm sure you know that already - overall the scheme looks good, nice work.
                                • olisheaO Offline
                                  olishea
                                  yeah man. I hate using cutout people....but they are quick and easy. thanks for comment
                                  more images to come....when they finish 😒
                                  oli
                                  • olisheaO Offline
                                    olishea
                                    here is another angle. image is not as good quality as the others but it will have to do!
                                    http://i654.photobucket.com/albums/uu269/olishea/3_final_revA-1.jpg
                                    oli
                                    • olisheaO Offline
                                      olishea
                                      here is another one:
                                      could do with some more contrast though....
                                      http://i654.photobucket.com/albums/uu269/olishea/4_final-1.jpg
                                      cheers
                                      oli
                                      • olisheaO Offline
                                        olishea
                                        different PP:
                                        http://i654.photobucket.com/albums/uu269/olishea/4_final-2.jpg
                                        oli
                                        • olisheaO Offline
                                          olishea
                                          another angle. man im tired!
                                          tried some dirt maps/grunge maps in this one.
                                          comments appreciated.
                                          http://i654.photobucket.com/albums/uu269/olishea/27_final-1.jpg
                                          oli
                                          • RichardR Offline
                                            Richard
                                            Mate looks like you need to play with the curves editor in PS! It can really make an image pop by adding contrast without loosing colour depth! Drag top quarter of diagonal left and bottom quarter right is a quick and dirty method to dress result!
                                            [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                            • 2 / 4
