    A neat little tree generator
    7 Posts 5 Posters 2.7k Views 5 Watching
    • Alan FraserA
      Alan Fraser
      I stumbled across this the other day. Baum 3D (Tree 3D...down at the bottom of the page...the full version).
      It's in German but, if you press F2 when started it will offer you the option of resetting to English. It even has a rather neat leaf editor. It outputs with a largely useless (for our purposes...unless you're using Kerky) separate diffuse and transparency jpeg...and in VRML. But there are plenty of VRML translators out there...and it's easy enough to swap the jpeg for a transparent png, once in SU.
      The number of leaf plates is dependent upon the number of branches...but you can afford to be quite generous, as it produces an insane number of these...so you can delete them, just leaving the leaf canopy; and substitute a much simpler trunk in SU.
      I've attached a sample output done in this way. It also does rather nice conifers too...although the alpha needs tidying up a bit.
      http://www.formfonts.com/requestFile.php?type=1&id=13447&img=FF_Model_ID13447_2_gs018_thumb.jpg
      baum3d.skp
      3D Figures
      • Alan FraserA
        Alan Fraser
        Thanks for reminding me. I forgot to mention that it'll run from a folder on your Desktop...no install necessary.
        3D Figures
        • numbthumbN
          numbthumb
          And no install. Thanks for the tip, Alan.
          Comfortably numb...
          • N
            NewOne
            Nice tree generator, indeed! But I noticed that it saves as .wrl. How can I convert that in something that sketchup reads? Maybe obj?
            Thank you.
            • Alan FraserA
              Alan Fraser
              You'll need to search for VRML convert, if you don't have a decent file converter already.
              I was going to suggest Crossroads, but it only does VRML1...not VRML2. Nevertheless it's good for a few other formats and its free. It was also abondoned about 10 years ago so is getting increasingly hard to find. It can be found here. http://synapses.clm.utexas.edu/tools/xroads/xroads.stm so those of you that need it better get it quick and save it. You'll notice that web page hasn't been updated for 11 years.
              A program that does seem to do VRML2 can be found here. http://www.tb-software.com/products_2.html# I don't know the terms of the demo version, though.
              3D Figures
              • K
                Khai
                nice find πŸ˜„
                and here's an excellent converter http://meshlab.sourceforge.net/ Meshlab!
                • RichardR
                  Richard
                  Always generous with the eyes up Alan!!!
                  Thanks mate!!
                  BUILTBRAND.COM.AU
