    Could this be the answer to our Energy Needs ?
    30 Posts 17 Posters 3.0k Views 17 Watching
      Jackson
      Well, I looked a couple of the videos and checked out their website and there seems to be a lot of talk, but they don't really say anything! Other than something about opposing magnets and capacitors I couldn't work out what even the basic technology was. Perhaps this perpetual motion machine is hot gas powered? ๐Ÿ˜„
      Jackson
      Jackson
      • boofredlayB Offline
        boofredlay
        I got the same feel. However if their claims are true, and it can produce more energy than it takes to make the magnets (considerably more) then here's hoping it pans out.
        I think the salt water burning idea is pretty promising as well.
        • KrisidiousK Offline
          Krisidious
          all of these inventions or finds have the same problem, implimentation...
          and powering the invention... lol
          By: Kristoff Rand
          • W Offline
            Will03
            it's been a while since I've been in physics class, but it seems to me that this was discovered somewhere around the 30's or 40's. EMR (Electro-Magnetic-Radiation) is a means of inducing a current using magnets... I'm fairly certain that it costs much more energy in the creation of such a device than the output is worth. But this isn't to say that i'm a master on the subject, I'm fairly sure that I'm wrong, but nonetheless, a less than educated guess is all i can offer!
            I for one am all for environmentally sound energy. The biggest dream I would like realized is where powerplants are decentralized, by turning entire cities into powerplants, by means of wind, solar, and bio-energy.
            It'll be interesting to see what these guys are, if it's just a hoax or if they are a genuine company!
            • John SayersJ Offline
              John Sayers
              As far as I can gather the two leading communities in alternative energy are Germany and California. In both cases it is due to the lead provided by government.
              I lived with alternative energy for 5 years. I had a solar power system with inverter and deep cycle batteries, a solar/wet back hot water system and I pumped water with a Ram pump. My only external energy source was LPG gas for cooking and a small fridge.
              It does help to make you energy conscience.
              cheers
                Krisidious
                so what was your experience John? worth it or not?
                By: Kristoff Rand
                  boofredlay
                  Quoting my fathere here:
                  Well, the objective isn't really 100% free energy, counting the costs of building the machinery (including magnets and radio wave generators) and making it available to the consumer. The objective is to get more than 100% of the energy you put into a device back out of it, so that the USE cost (which includes maintenance and repair, but is different from the BUILD cost) is near zero. None of the magnetic devices have yet been shown to do this, to my satisfaction, in any of these videos.
                  As for the salt water bit, the inventor doesn't claim to get more than 100% energy output, but merely to have come up with a way to efficiently separate hydrogen & oxygen from water, so that they can be burned and produce SOME energy. Just HOW efficient the method is was not discussed in that news report. Merely passing electricity through ordinary tap water can be made to separate the two elements, as has been demonstrated in practically every science class for many decades. Radio waves can induce "eddy currents" in many materials, and I'm not surprised to see that happen in water that contains salt -- every science student knows that adding salt to distilled water will make it conduct electricity.
                  Calling this a source of "free" and "clean" fuel not only ignores the efficiency issue, which is crucial to the USE cost, but also the costs of collecting, handling and distributing this abundant seawater, costs of corrosion prevention and other maintenance issues, and the question of what happens to all that salt when the H2 and O2 are burned. The combustion result is pure water, some of which will condense and CAN be made to flow back to the original reservoir, but much of which will escape as steam. That leaves the original salt solution more concentrated, so there'll be a cleaning and restoration problem to add to the USE cost. These factors have been prohibitive in every other saltwater engine attempt I've seen to date.
                  • W Offline
                    Will03
                    I've got a solution for separating salt water!
                    separate the two gases, use the hydrogen in hydrogen fuel cell cars, compress the oxygen into liquid oxygen for various uses (rocket fuel for instance) and collect the salt to sell as sea salt!
                    I think we should band together and start up this business guys! lol
                      tomasz
                      15 December 2009 - Dublin
                      Public demonstration started:
                      (www.steorn.com)
                      • EscapeArtistE Offline
                        EscapeArtist
                        Interesting idea, but as with many "miraculous devices" that are purported to be the future of clean energy, this one seems to fail. I've lost count of the number of inventions of this sort that never seem to make a good public demonstration, they all have "technical difficulties" that the purveyor/inventor blames on anything from excessive heat to sunspots.
                        I have never seen a device capable of thwarting conservation of energy rules.
                        I'll be suitably astounded if this device works as described, as will the world - but I'm not holding my breath.
                        BTW, all the vids linked in the original post are gone.
                        • soloS Offline
                          The old saying "If it sounds too good to be true.... it probably is"
                          I'm still waiting for cold fusion and laser guns.
                          • AnssiA Offline
                            Anssi
                            I seem to remember that the commercially viable fusion reactor has been just some years away since the early 1970s...
                            Anssi
                              tomasz
                              Anssi
                              You old pessimists... So many people has failed to deliver a working device that it make no sense to you to still believe in a breakthrough.
                              I am surprised that Orbos are being driven by such a big battery. If the device is recharging the battery, why didn't they use a decent capacitor instead?
                                remus
                                Who needs to be pessimistic when theres hard facts? http://www.irishtimes.com/newspaper/ireland/2009/0624/1224249416758.html
                                  You can't get something for nothing - it is a basic thermodynamic law... BUT you can move energy around to where you want it. Even Steorn fell into the trap of saying that their [now found to be flawed] gizmo 'broke the laws of the universe' ! ๐Ÿ˜’
                                  It didn't need to for it to produce more energy out of itself than you put in... I know at first glance this seems oxymoronic BUT just think about things you see every day... โ“
                                  A fridge/aircon unit moves heat energy from one place to another - it's not magic. A heat-pump uses 1kW of electricity but outputs say 3kW of heat - where'd that extra 2kW come from? it wasn't 'made', it was simply moved from somewhere else and 'concentrated' to useful levels - e.g. low-grade heat in ground-water or outside-air is moved into your home as useful heat to keep you warm. This does not break any 'laws' of the universe as the total amount of energy remains unchanged - it's just in a different place - your home is quite a bit warmer and outside is a tiny bit colder - since there's a lot more 'outside' than there is 'inside' the affects on the 'global' outside temperature is barely measurable. ๐Ÿ˜ฎ
                                  So what does this mean? Well, my point is that if you can do this with simple heat energy it must be theoretically possible to make a gizmo that gets low level energy from other sources - e.g. the flux of the earth's magnetic-field or the solar-winds etc and then makes it available to you in a concentrated local form that's useful... Since electro-magnetic and electrical fields pervade everything it must be possible to 'tap' into them and 'borrow' some of that energy - it'd not be 'making it', it'd just be moving it to where it's needed in a useful form... โ˜€ ๐Ÿ’ญ
                                  • Mike LuceyM Offline
                                    Mike Lucey
                                    I think you are right TIG in what you say. 'Moving' should be the operative word not creating by means of magic!
                                    I might pop up to Dublin a have a look at the machine in the new year! Check out this article 'Roll up, roll up to see the Irish perpetual motion machine!' http://www.gizmag.com/steorn-orbo-perpetual-motion-demonstration/13625/?utm_source=Gizmag+Subscribers&utm_campaign=50d4d4bdbb-UA-2235360-4&utm_medium=email
                                    Tomaz, yes, I wonder why a 'decent' (size) capacitor was not used at least for the ongoing running of the machine, maybe with a battery to kick it off.
                                    Mike
                                    • pbacotP Offline
                                      Like most start-ups and speculation, I think the important thing is to move money, not energy, from one location to another.
                                        tomasz
                                        Introduction to an Orbo Electromagnetic Interaction - Part 1
                                        http://www.youtube.com/watch?v=S5nae_I_Mus
                                          Jackson
                                          ROFLMAO! ๐Ÿคฃ
                                          How true... from the pockets of gullible people to the off-shore bank accounts of con-men.
                                          Jackson
                                          • FletchF Offline
                                            Fletch
                                            original links in all first post are now defunct... adding weight to the conspiracy theories... ๐Ÿ˜„
                                            Fletch
