    Some of my SU + KT works
    12 Posts 10 Posters 1.4k Views 10 Watching
    • GaieusG
      Wow, these renders are top notch!
      πŸ‘ πŸ‘ πŸ‘
      Except maybe the too much bump on the water surface - it looks a bit like a windy lake rather than a pool.
      • FrederikF
        Frederik
        I agree with Gaieus...
        Top notch (in particular the interior restaurant image)... πŸ‘
        You should re-scale the water material and it will improve the quality signicantly... πŸ˜‰
        Cheers
        Kim Frederik
        • majidM
          majid
          really nice renders mate. I only guess that you've used thin glass material for your tables, I offer testing dielectric glass, and as Frederick says, for sure , re-scaling the water, will improve the material
            madhav
            wow those are amazing. πŸ‘
              dspace
              Congrats to your first post, amazing work! πŸ‘
              • EscapeArtistE
                EscapeArtist
                Very nice work with the KT renders. Looks great!
                • dermotcollD
                  dermotcoll
                  Very impressive renders - you are obviously not a novice at rendering - the restaurant image is fantastic.
                  When you burn your arse - you gotta sit on the blisters!!
                  • W
                    wawo_kalbo
                    Hi Majid.
                    isnt dielectric glass mat used for mirrors? (correct me if im mistaken) whenever i use it it gives off white speckles so i often use NK Metals chrome for my clear mirrors to avoid these artifacts. i render using the photon map preset usually btw.
                    also the water is just from your water pack. how do i adjust the scale? πŸ˜› im not really an advanced user, started off in podium then switched to KT as my render app. im actually thinking of switching to twilight and have tried the demo but it seems its a bit slower than KT but definitely easier to understand.
                    Thanks for all the kind comments.
                    • FrederikF
                      Frederik
                      Sorry, but you are mistaken... πŸ˜‰
                      Please make a search at the KT Forum to understand materials and material behaviours better... πŸ˜‰
                      Please check page 17 in the KT Getting Started tutorial...
                      The only difference is, that you don't have a bitmap in the Diffuse channel...
                      Instead you have a bitmap in the bump-map channel, which you can adjust... πŸ˜‰
                      Since the Twilight Render uses the KT render engine (just like Podium v1.x is), you shouldn't notice any difference in render times - as long as you're using the same render preset... πŸ˜‰
                      Please note that the TWR presets have been optimized for Twilight, but you can use all the KT render presets in TWR as well... πŸ˜‰
                      Cheers
                      Kim Frederik
                        steelers05
                        the feel and style of these images are great. Congrats on a very good job. The interior restaurant one is my favorite
                        • N
                          nomeradona
                          whow.. excellent render wawo.. nice job with KT.
