    SU to blender (+ small tutorial)
    34 Posts 14 Posters 9.4k Views 14 Watching
    • michaliszissiouM
      michaliszissiou
      @fletch said:
      what resolution was this rendering? what machine/processors/processor speed?
      Thanks Adam, Sid, Fletch. Rendered at 1680x1060, blender v2.5 64bit on a mac (two xeon-nehalem, quad cores 16 threads at 2.26 Ghz). But could take 5 or 10 or 20 min, so many variations. I could say that ~1min on v2.5 or ~5min on v2.49b. What made this fast is that avoided radiosity solution using just a sun and three emitters. Blender aims at animation, so its fast.
        Cool quiet images β˜€
        The collada exporter from SU free seems don't work with the Blender Collada Importer
        But seems work when you export from SU free in KMZ (rename in .Zip, unzip = DAE) then import in Blender πŸ˜‰
        • michaliszissiouM
          michaliszissiou
          But seems work when you export from SU in KMZ (rename in .Zip, unzip = DAE) then import in Blender
          Thanks Pilou, but DAE in KMZ is identical to DAE export. A mess. Practically useless!! Its collada blender importer or a SU problem, or I'm doing something wrong. πŸ˜†
            Probably both, but it's the only thing that I can do now from the free Su for export an object directly inside the Blender 2.5 Alpha 0 πŸ˜‰
            • EscapeArtistE
              EscapeArtist
              I'll second that SU DAE to Blender Collada import stinks, I exported a building and it's gigantic mess of triangulated faces and half reversed normals. On any serious model you'll spend longer fixing normals and cleaning up faces than you ever did modeling it.
              • michaliszissiouM
                michaliszissiou
                "exported a building and it's gigantic mess of triangulated faces and half reversed normals"
                Exactly so. Maybe we should forget texturing in SU. Anyway UV texturing is superb in blender. Maybe this 'importing SU models to blender' operation is a waste of time. Maybe... πŸ˜’
                • C
                  Camara
                  It's nice to see another user of a SU/Blender workflow. I love the two programs and they make my life more easy.
                  SU is great for modeling architecture but Blender as more advance tools for modeling organic forms,texturing and render.
                  My workflow is:
                  I use SU free for modeling from the CAD files and do texturing, then use the Kerkythea exporter, then I have a Kerkythea XML file and the textures folder.
                  Then use the wonderful Nicetuna converter from the Kerkythea format into OBJ, it can be found here: http://www.nicetuna.com/kt2obj
                  Then import into Blender the OBJ file,be sure that the file are in the same folder that the textures and in the import options check the image search for Blender find them, and separate OBJ by Object/Group/Material. And VoilΓ‘.
                  The import is perfect.
                  In Blender you just need to delete duplicate vertices and transform tri faces into quads,that are very simple commands.
                  Then one can export back to Kerky for render or use another render engine available for Blender like Yafaray, Luxrender or VRay.
                  This is how I do it. Hope someone finds this information useful.
                  Portfolio: http://camara.weebly.com/
                  • EarthMoverE
                    EarthMover
                    Thanks Camara. Interesting workflow. I am going to give that a shot.
                    EDIT - Gave it a shot and it works great in 2.49. I can't seem to import .obj into 2.5 alpha. Anyone else have this problem? BTW - the KT .xml to .obl workflow also works great for going from SU to Modo.
                    Content Creator at Skapeup
                    • david57D
                      david57
                      πŸ‘
                        OBJ importer of the 2.5 Alpha 0 is bugged!
                        With some people that works 1/2, for other = 0
                        Ok cool trick β˜€ but it's not a direct workflow SU free to Blender (that was my problematic for the moment) πŸ˜‰
                        (during the bugging time time of the Alpha 0)
                        • michaliszissiouM
                          michaliszissiou
                          OK, blender 2.5 is Alpha 0, lets work with v2.49b. Lets keep v2.5 for rendering.
                          Its a small tutorial here. Exporting from SUpro as .obj. Exporting textures too. When impoted to blender check for doubles. I didn't find any though. If models are already textured in SU, DO NOT convert triangles to quads, UV problem. You can edit UV textures however, you can even have texture painting, projected textures etc. Everything works just fine, just don't subdivide geometry (bad triangulated SU models here).
                          Here's an old SU model:
                          As you may noticed I'm checking faces so to look outside, that's really important. No blue faces, ok
                          So in SUpro, export .obj like this:
                          Importing .obj in blender 2.49b like this.
                          Here's the model in blender. You can see on the right, all textures UVs etc have imported beautifully.
                          I deleted cactus and added some blender trees BTW. Everything works like a charm
                          A quick render ~2 min
                            Very cool tut and neat result! 😎
                            Can I translate your tut in French?
                            • michaliszissiouM
                              michaliszissiou
                              My pleasure Pilou.
                                Thx! β˜€
                                Done! 😎
                                • EarthMoverE
                                  EarthMover
                                  Michalis, does this mean that you will import into 2.49 first, then save as .blend file and open it in 2.5 for rendering? Just trying to understand the workflow. I can't wait until they are finished with 2.5. It is a real gem in the making...especially if it is still free!!
                                  Also where do you get your Blender trees?
                                  • michaliszissiouM
                                    michaliszissiou
                                    Yes Adam. You can save the v2.49b file and open it in 2.5 (much faster renderer). But you have to wait for a full functional 2.5.
                                    As for "if it is still free" read this one. It will always be a freeware app.
                                    http://www.blender.org/education-help/faq/gpl-for-artists/
                                    • EscapeArtistE
                                      EscapeArtist
                                      This works well, I had to do this to get the collada import to work. Import with 2.49, save as .blend, re-open in 2.5. Didn't know the .OBJ import was broken too, thanks for the heads up.
                                      • michaliszissiouM
                                        michaliszissiou
                                        An updated render, using blender particle system for dry grass. I have a lot more to learn...
                                          Jakerlund
                                          Anyone know how to run kt2obj in OS X?
                                          There is a Unix version and since OS X is Unix based i thought it would be possible.
                                          But my knowledge in terminal is πŸ‘Š
                                          Any tips are welcome.
                                          • EscapeArtistE
                                            EscapeArtist
                                            Jakerlund
                                            Your question would be better answered in its own post.
