    Vue 7 Infinite
    extensions
    77 Posts 17 Posters 17.5k Views 17 Watching
    • H Offline
      hombre
      @sheik said:
      How about the improvemts in workflow from SU to Vue? I wasn't too happy with that in Vue6. Can I now make a model in SU, like an large scale urban plan, and then (comfortably) populate it with ecosystems etc.?
      @solo said:
      Yes you can, even with 6 it was possible (see my site for examples)
      Vue is really cool, but I have this question that is an absolute bottleneck I haven't come up with a great answer for. In that such questions are probably meat for a Vue forum, the fact is, Sketchup was created for architectural purposes, not for fantasy landscapes, therefore how Vue interfaces to make Sketchup an incredibly powerful architectural tool is to me of stellar importance.
      Question:
      I have yet to find a convenient way of dealing with urban/residential lawns in Vue wherein one can populate with live growth plants, a geometric area 'ecosystem' with 'grass' and end up with a neat, manicured lawn that doesn't also want to bleed over a foot and a half into sidewalks and streets.
      The idea of planting, resizing, and rotating individual objects until the area is filled and not spilling into the concrete is really an impossibility within the parameters of any commercial project.
      Is there a way to do this that I don't know?
      • soloS Offline
        Whitney, the easiest way to achieve that is to select the mesh that you need populated with lawn (best way to do that is when in SU you apply a color to both sides of face and give it a name like 'lawn'. then once model is imported into Vue you split model by textures in model properies then select the 'lawn' mesh and copy and paste it on a new layer (delete original). now select grass mesh and and apply a base texture and ecosystem, because only the grass is selected and on a seperate layer it will not bleed over onto other geometry.
        Hope this helps.
        • H Offline
          hombre
          Thank you for your effort in attempting to help me understand, but I still don't get it.
          I have imported the model, broken it down into it's various object components, copied the 'grass' object,
          pasted it onto another layer, and deleted the original grass object on the first layer. Next I changed the object
          to an ecosystem and populated it with a livegrowth grass object.
          In the examples below, you can see that the grass ecosystem ignores the perimeter selection that was made and
          simply grows wherever it wants within the parameters of it's own specific design footprint. The only way I have gotten close to containing it is to make the scale so tiny that it encroaches more like an inch instead of a foot.
          I am also attaching a pic of the layers for your review.
          What am I doing wrong, or not doing?
            karmoh
            Under "density" tab in the material editor, try to adjust the "decay near foreign objects" value.
            That might get you the result you wanted:)
              sliner
              It is better to activate in the same tab Force regular alignment of instances
              http://s60.radikal.ru/i170/0910/90/fb36f68c66cf.jpg
              http://fancyquest.ru/albums/yucca/
              • H Offline
                hombre
                Thank you Karmoh for your suggestion on decay near foreign objects, and Sliner for your suggestion about 'Forcing regular alignment of instances' and your example which showed me it could be done simply.
                I have taken these 2 pieces of advice and after playing with the sliders have arrived at the solution, which also involved the idea of using a ONE plant module ecosystem, instead of a 'bunch of grass', which I am assuming would NEVER contain itself within a prescribed border, but would rather center its' mass within those boundaries, leading to overlapping onto other surfaces.
                Thank you all once again for your help.
                  sliner
                  Try this grass-objects .vob
                  http://s59.radikal.ru/i163/0910/a1/860ab3192876.jpg
                  3 test grasses
                  • H Offline
                    hombre
                    Thank you for the sample grass objects Sliner.
                    • H Offline
                      hombre
                      Back with another question.......
                      How does one go about making brick soldier coursing, rowlock and arches ( for use above windows etc. ) in sketchup and then translating that into vue?
                      I have been making individual bricks to represent this in sketchup, which is nuts enough, but translating that into vue becomes a monster which I don't seem to have the brain muscle to figure out...does anyone know how to do this?
                      Thanks in advance for showing me the magic button.
                      LOL
                      • soloS Offline
                        It comes down to UV mapping, no matter how you skew or distort a texture in SU it will render accordingly in Vue.
                        The problem here is SU, there is a few UV tool that Thomthom has created which may assist you in mapping the textures as you need (I just cannot remember the names to search it), anyway once you have them orientated in SU as you need then they will import into Vue no problem, and without creating millions of unique textures.
                        • H Offline
                          hombre
                          That was what I thought...if you remember the tool that you are speaking of, please post it.
                          I had a similar issue about a month ago using a SU tile pattern, and found that the pattern was also height specific. That is to say, if I started the pattern at a point which was unequal to the multiplied nominal dimension of the particular tile size the tile would be interrupted instead of starting with a clean coursing. EX: if the individual tile size is 12" and I start the tiling at 30" above FF level, then I end up with my first row cut in half.
                          The other issue is that it seems a bit absurd to have to individually draw each brick in something as common in architecture as rowlock or soldier coursing. It makes sense to manufacture a picture to fit a particular space, and I understand that Vue imports the picture very well.
                          ...that was the only other solution that my brain revealed to me and why I asked the question...LOL
                          Thanks for your effort and quick response.
                          BTW: I see that you are using the UK equivalent of the Commodore 64......very funny!
                          I waited for the big guns: a Commodore 128...LOLOLOL
                          • H Offline
                            hombre
                            Next question.
                            Is there a good source for 3D people for use in Vue?
                            I got Vue bundled with Poser, but to be perfectly honest, I don't have the desire of the Radiosity enthusiasts to learn it and play with costuming them...and obviously the flat face-me people from Sketchup don't work, dittos for the 3D offerings within the program. The notable exception is the guy who seems to have spent the last year of his life developing 'real life heroes' that has posted these wonderful, but mostly unusable types of figures in the 3D warehouse. If only he had made regular people...he could very well sell them in a bundle. I don't have much call for astronauts and deep sea divers.
                            • soloS Offline
                              Animated or not?
                              • H Offline
                                hombre
                                ...well, both would be great....animated people in vue would be icing on the cake....animated vehicles would too. I'm primarily doing stills, but motionless people/cars in a walkthrough/flyby are a bit static.
                                • DanielD Offline
                                  Daniel
                                  Hombre: if you use ACME brick's masonry designer, you can get create soldier and header courses. Rotate the headers 90 degrees to get rowlock. I've done quite a few historic buildings with brick arches, and have yet to find a decent way to duplicate them other than creating them from scratch; however, once you know the number of bricks needed, and the angle, you need to create just one and rotate and copy it (I wish some programing guru would create a masonry arch designer to go with the masonry designer program).
                                  Cornucopia3D has a number of 3d figures, as well as motion files for them, for use in VUE. They aren't detailed enough for close-up shots, but good for middle ground.
                                  My avatar is an anachronism.
                                  • H Offline
                                    hombre
                                    Thanks Daniel, unfortunately, Acme doesn't have a MAC platform at this point...and thanks for the Cornucopia tip.
                                    • soloS Offline
                                      http://www.axyz-design.com/axyz-design-3d-humans-characters-methd-evo2.php
                                      • H Offline
                                        hombre
                                        How does one populate an ecosystem with an object like this?
                                        • Chris FullmerC Offline
                                          If you can find the populate area, you will want to add objects. That lets you use .vob files. I used those grasses and they turn out very good on a little test project. Kind of high poly count though. I was able to fill an entire small section, but I could not imagine filling an entire park with lawn. Maybe I did something wrong?
                                            sliner
                                            I also encountered this problem and try to solve it. One option is to use distribution objects depending of distance to camera with Function editor, that they were not in the background. The second option to use bump-displacement.
                                            • 3 / 4
