    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 417.4k Views 154 Watching
      Hi Ronan,
      Have a look at this announcement and if you seem to have login issues, delete your cookies from your browser.
      http://forums.sketchucation.com/viewtopic.php?f=180&t=19797
      Ah yeah - and welcome to SCF.
      • plot-parisP Offline
        plot-paris
        I have got a file, where Zorro crashes constantly.
        I created the geometry in a bigger file and tried to slice it. it crashed. I copied the geometry to a new SU file. it crashed again.
        in the end I had to redraw the whole thing in a new file. and everything worked fine.
        any idea why that is?
        I attached the file for you to experiment...
        crooked.skp
          chimbalo
          thanks the program is really good, shame that I have the same problem, I can not make a slice cut (bug splat) when the model is a litle bit heavy, anyways thanks and keep on.
          • W Offline
            Whaat
            I can't say for sure why users are getting crashes. I am not sure if it is something I can fix or if it is a SketchUp bug. My only suggestion is to save before you use the plugin. Also, try to work with simpler scenes (save components to a separate SKP files and work with them)
              chimbalo
              After a few hours I figure it out how to fix the bug splat, I have a heavy model, every time that I started using the slice tool my model crashed up, I tryed exploding the model, chainging to newer sketch up, etc etc etc. At the end I took all the model and grouped up whith out the cuting plane, after I slice it, and was the solution for the problem, now it doesn't matter how heavy is the file, the plug in ,work fine. sorry for my bad english, I hope is useful for you.
                Well, definitely useful and I hope I will remember next time I try to use it on a similarly complex model.
                Thanks for the heads-up! 👍
                  KU ARCH STUDENT
                  This as got to be one of the best plugs I've come across. Awesome job with this one....
                  • Y Offline
                    yoshiko sasabe
                    @whaat said:
                    I guess I created a small bug just before I released the plugin that I did not release was there. i will post a fixed version later today. Sorry! I will also try to create a tutorial later today if I have time. For those of you who do not want to wait, just change line 266 to read:
                    Sketchup.active_model.start_operation("Zorro")
                    I belive this will fix the problem but I don't have time to fully test right now.
                      Jim57
                      Chimbalo—
                      I had the same experience as you. SU crashed when I tried to place the section plane inside the component and slice. I had to place the section plane from OUTSIDE the component and then it works like a charm.
                      Thanks for figuring that one out, and thanks for the Ruby!!
                      Best,
                      Jim
                        chango70
                        Whaat will there be more development on this plugin?
                        • W Offline
                          Whaat
                          Probably not, at least not for a very long time.
                          • O Offline
                            okramme
                            Best plugin for sketchup that I have seen!! Thanks
                            • W Offline
                              Whaat
                              Wow...thanks! You need to spend some more time around here to see what else is available. You might be shocked! 😉
                                mling87
                                Thank you SO much for this plugin! Being able to quickly create and render section perspectives is an architecture student's dream!
                                  JPMays
                                  Just discovered this plugin through the Maxwell Render forum, but have been having similar issues as others: bug splats every time, even after exploding and removing a lot of the geometry. Anybody found a work-around for this? My model was rather complex, groups inside of components inside of components inside of components, but I've reduced significantly. Even copying geometry and pasting into new file does nothing.
                                  Hofstadter's Law: It always takes longer than you expect, even when you take into account Hofstadter's Law.
                                  • W Offline
                                    Whaat
                                    I think one suggestion was to make sure your section cut is not inside a group or component.
                                      JPMays
                                      I've exploded the entire model (a copy of the original). There are now no groups or components. Same result.
                                      EDIT: The weird thing is that when I tell it to slice using the section, at the bottom it says "Cutting Group #2...", but there are no groups listed if I go into my Model Options. It gets stuck there and then crashes.
                                        tmok
                                        i wanna try some
                                        thanks
                                          taydiggs
                                          you will all love me for this one.
                                          In order to CUT a section within a model, YOU DO NOT need to section plane and explode and delete etc!
                                          ALL YOU HAVE TO DO is put it in PARALLEL projection and set the camera where you need the section to be.
                                          Voila, section (obviously doesnt work for perspectives, but for elevations of architectural drawings this is an amazingly fast and easy fix.
                                          • H Offline
                                            harshal kshatriya
                                            Man ijust love it
                                            • 15
                                            • 16
                                            • 6 / 16
