    Twilight v1.1
    extensions
    25 Posts 12 Posters 3.3k Views 12 Watching
    • E Offline
      Ecuadorian
      Do you have more than one SketchUp version installed on your hard drive? Perhaps you installed it on the other one.
      -Miguel Lescano
      • david_hD Offline
        david_h
        No. . ..it seems to create a file tree plugins/twilight/twilight with duplicate files in each. I try to copy one over the other and it won't let me. I completely uninstalled and reinstalled but it doesn't fix it.
        D
        Oops! I figgered it out.
        Thx,
        D
          chango70
          Thanks guys I sent off the license request again. Hope it works!
          • F Offline
            Fletch
            David, please post this question at Twilight's forum, you will have your answer quite quickly I imagine.
            Fletch
            Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
            • F Offline
              Fletch
              Yes, to update your version of Twilight Render for Google SketchUp, simply download the new demo from the download section of http://twilightrender.com or from the Update V1.1 thread, and install over the top of your current version. If you already have a license it will NOT need to be re-requested. (except possibly with some 64bit systems)
              Please note especially something most people didn't notice:
              License deliveryhas changed slightly so that the email will hopefully not be blocked any more by some email admin systems.
              Save rendered images as EXR = OpenEXR (.exr) the High Dynamic Range image type developed by Industrial Lights and Magic. It can be used for many things, but some users like it for use with programs such as Motiva SOAP"
              (http://en.wikipedia.org/wiki/OpenEXR)":3eobmx9c]OpenEXR is a high dynamic range imaging image file format, released as an open standard along with a set of software tools created by Industrial Light and Magic (ILM), released under a free software license similar to the BSD license.
              It is notable for supporting 16-bits-per-channel floating point values (half precision), with a sign bit, five bits of exponent, and a ten-bit mantissa. This allows a dynamic range of over thirty stops of exposure.
              Both lossless and lossy compression of high dynamic range data is also supported.[1]
              Most importantly the new View Setup Tool view_tool.png exclusive to Twilight really guarantees you will see exactly what you will render, and be able to pick a focal point target.png any where in your scene, making setting up DOF extremely easy and fun.
              Fletch
              • 2 / 2
