    <LocalJumpError: return from proc-closure> in WebDialog
    5 Posts 4 Posters 1.7k Views 4 Watching
      MartinRinehart
      Google search found a two-year old thread near this topic, which helped me work around a Ruby bug. This post is for the next victim of this bug.
      With smaller models, this code, in an action callback, worked:
      # update some stuff
      return if msg.nil? # msg == a callback argument
      handle the msg
      With a large model, it failed, showing the title error. This solved the problem:
      # update some stuff
      unless msg.nil?
          handle the msg
        markozeta
        Interesting... Glad the model helped then. Wonder what caused it...?
        BSME - Cal Poly Pomona
        Sketchup Pipe Maniac
          Jim
          I don't know the finer details yet, but returning from a proc causes the error.
          You also get similar errors if you try to return values from command validation procs.
          This causes an error.
          def my_validation_proc
            if Sketchup.active_model.selection.nitems == 1
              return MF_ENABLED
            else
               return MF_GRAYED
          This does not
              MF_ENABLED
            else
               MF_GRAYED
            Rather odd, isn't it, as return is implied in Ruby... no?
              Jim
              Maybe, but I don't understand it myself. Rather than returning from the proc, the proc itself evaluates, and that is what is returned.
