    Winter trees?
    35 Posts 16 Posters 6.8k Views 16 Watching
      Click Draw
      Could the trees be made into a dynamic component and then have options drop downs to choose leaves, no leaves, bark type and so on....?
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
        d12dozr
        Jeff
        Hi Jeff,
        I recently asked Tomsdesk the same question about his 2.5D trees...apparently it makes the file size too big - that's why they don't like dynamic components.
        Maybe this would work better, though?
        ...Have the same .skp tree packaged with multiple layers. Have the bare tree as the base layer and the user can turn on the spring blossom layer (if applicable), the summer layer, the fall layer and a snow layer for winter trees. The user can delete those layers he doesn't need for that project to cut down on file size...
        http://goo.gl/f7ooYh
          Click Draw
          Thanks Marcus...that makes sense.
            tomsdesk
            Guys, I think most of the 2.5d trees (mine and others) are already pretty dynamic...:`) as the color of the leaves are easily changed in the material editor and they can also be turned off for winter (though my trunks don't have near the beauty of these Solo is working on: too much poly for my intent at the time).
            2.5D Trees & Shrubs!
            • Alan FraserA Offline
              Alan Fraser
              I think Tom's right. I tried some pretty extensive experiments with dynamic vegetation. You can quite easily end up with a component that is 5MB+ A good quality png file can be not far short of 1MB on its own. Have one for every season, including bare branches with snow and the whole thing gets pretty heavy.
              Given that you have to choose the season anyway; and then perhaps explode the component and purge it of the unwanted seasons to save on file size, you might as well simply produce seasonal versions and then simply reload to suit.
              Those arial views look stunning, Pete. Are you using geometry instead of image transparency, so you can render in V-Ray or whatever? I would guess so, looking at the cast shadows in your first shots.
              3D Figures
                sepo
                First Santa render this season... πŸ˜„
                  mateo soletic
                  Christmas is coming sooner every year. πŸ˜†
                  BTW Nice trees.
                  [Concept Illustrations](http://concept-illustrations.com/)
                  • soloS Offline
                    Thanks guys, now I'm playing...
                    Xmas scene 2 (quick scene, reusing an old scene)
                    http://img59.imageshack.us/img59/5088/snowscenexmas.jpg
                      sepo
                      That is Vue I presume. The snow is just amazing. πŸ‘ πŸ‘
                        Daniel Bouchard
                        Hi Solo,
                        Like I said in Twilight forum, a winter trees and shrubs pack will be very useful for me. Most of my SU projects are done for my job, the Quebec "Winter" Carnaval.
                        Like Alan said, for the moment I usualy use Pepe trees (very good) but it will be interesting to have more choices.
                        I like Bruce idea to have trees and shrub with snow on.
                        Put me on your list.
                        • RichardR Offline
                          Richard
                          They look great Pete! We don't get snowy winters here so I could never be sure, though would the lower branches droop so much in winter with the absense of any weighty foliage?
                          Texturing these obviously has to be done out of SU due to the wrapping issue! What will you use for that! I wrapped a trunck recently with UV tools and when exported to render it spat out each face as a separate material - strange!
                          [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                            Try to triangulate the faces first, Richard. Until a recent update, Twilight did the same with UV Tool'ed wraps and that was the workaround. Maybe it could help with whatever you are trying to render, too.
                            • RichardR Offline
                              Richard
                              Thanks mate!!! I'll give that a try! Sorry Pete for the off topic!
                                Yes! Winter trees is of use for me - here in freakkin' freezing Norway!
                                  Btw, what's the theme for your next package?
                                    sepo
                                    Come on Thomas. Wnter in Norway is beautiful. Might be cold but beautiful nevertheless.
                                      The last years it's been more cold and less snow... Cold with no snow isn't that beautiful... πŸ˜• Not like the good ol' days.
                                        sepo
                                        I was not aware of that. Last time I was in Hemsedal was 3 years ago and it was really beautiful.
                                          It all depends where you do. How far up north, how high up in the mountains etc. But here in Trondheim the winters has been a bit weird. A couple of weeks of snow, a couple of weeks of rain where the snow melts - then it freezes again - making a solid layer of pure ice of the roads and pavements.
                                          When I was a kid the snow would lie stable from October til April.
                                          • EdsonE Offline
                                            Edson
                                            i think we all perceive climatic weird changes as we grow old. i for one have recollections of having four well defined seasons in south brasil. now it is a mess: you can have them all in a day, not to speak of natural phenomena we never heard of like cyclones, tyfoons and the like.
                                            http://www.mahfuz.arq.br
