    Free Real Time Raytracer Nurbs & polys
    22 Posts 11 Posters 2.8k Views 11 Watching
    • charly2008C
      charly2008
      Hi Pilou,
      i tried the viewer, but i got at startup a failure message.
      Karlheinz
        Aerilius
        [Die haben wohl nen Fehler mit der Ordnerstruktur gemacht...]
        The error message says that some .dll files are missing, but they exist in the superior directory. I just tried something and it worked:
        Copy all .dll files from the *Augenblick MMV (32-Bit) 0.6 folder into the *bin
        folder. Then go to *bin* and doubleclick on AugenblickMMV.exe.
        • charly2008C
          charly2008
          Aerilius,
          thanks / Dankeschön it works now.
          Karlheinz
          • charly2008C
            charly2008
            It seems to be a real alpha version. I couldn't open neither a fbx file nor an obj file.
            Karlheinz
            • ely862meE
              ely862me
              Me neither. 😞
              Elisei (sketchupper)
              Come and See EliseiDesign
              • jeff hammondJ
                tried fbx, obj, & an igs.. nada
                • MarianM
                  Marian
                  Same here...
                    I suggest you to go to the forum 😉
                    • honoluludesktopH
                      honoluludesktop
                      Sorry everyone, not ray trace, but some other means called "images synthesis".
                      ".....whereas the computation time required for images synthesis is much shorter in comparison to traditional ray tracing....."
                      Well, if it looks as good......
                        It is possible for you to load an unlimited* number of polygons without affecting the frame rate, due to the ray tracing technology
                        we started developing our own binary file format, which will allow you to save and load your scenes even faster - well and more complete of course. Currently it is only a working proof of concept, but just to give a little teaser - you all remember the "fat" lucy model with 28 Million polygons? Blender loads it for ages (if at all) and even Mesh Lab takes around have a minute. Or PLY importer does it in a few seconds, but now... we can load her in 2.5 seconds - yes, that is 2 and a half of a second!
                        • honoluludesktopH
                          honoluludesktop
                          OK, you win, but only if it is real ray tracing:-)
                            Next alpha will have bigger size ans smaller watermarks 😉
                            • N
                              nomeradona
                              very interesting.. thanks for sharing pilou.
                                Comeback with another name 😉
                                RenderGin free beta release! 😄
                                • olisheaO
                                  olishea
                                  awesome....and a mac version! yay!
                                  [edit] when I run the application it just exits immediately. I see the UI for a split second and then it shuts down 😆 😢
                                  oli
                                    Seems this forum maybe can answer you 😉
                                    • olisheaO
                                      olishea
                                      😉 I already posted the problem, I'm sure it's a simple fix. 😄
                                      oli
                                      • EarthMoverE
                                        EarthMover
                                        Works on PC for me. Anyone know how you pan? Seems okay, but a little quirky. With HDRI disabled in the demo, it's hard to really gauge the results.
                                        Content Creator at Skapeup
                                        • Z
                                          Zacchia
                                          RengerGin import 3ds or obj works only when the file is for example on desktop. When on other folders may an error message is coming. Please load the foles on desktop and it should work. What does anybody think about RenderGin?
                                            New version
                                            http://www.numenus.de/lw_resource/datapool/file/item_94/honda_cbr.png
