    New 3D PDF Plugin
    extensions
    26 Posts 12 Posters 7.7k Views 12 Watching
    • MarianM Offline
      Marian
      AWESOME PLUGIN 👍
      • ely862meE Offline
        ely862me
        Very,very..interesting..Well done guys!!
        Elisei
        PS. Backplates would be awesome !!
        Elisei (sketchupper)
        Come and See EliseiDesign
          kwistenbiebel
          Indeed, very interesting and affordable as well.
          I am wondering: will the filesize of the obtained 3D PDF be in the same range of the native SU file?
          I had a look on their website and the OSG Composer looks handy as well. A bit like DeepExploration?
          • MarianM Offline
            Marian
            Yes, pretty much, i didn't notice significant size differences between the two files, at least with the trial version.
            • Mike LuceyM Offline
              Mike Lucey
              @burkhard said:
              @ Al, any chance to get the new version also running on a Mac?
              Hi Burkhard,
              It looks that you obviously are trying out Sim lab 3D PDF on a Mac. If so is it working okay for you? I tried it on my MacBook Pro but it would not work. I have a feeling it could be a problem on my end but I am trying to get it sorted with Ashraf so time will tell.
              Mike
                dtrarch
                Hi All
                I have tried both 3dPdf offerings.
                Both do pretty much the same but the Simlab 3D PDF handled large files better with the RenderPlus version failing to finish and crashing on the same file render.
                The Simlab version also produced a cleaner line hide for a native SU mode.
                The shaded mode in both was just so so for presentation.
                The two versions were downloaded last week so best to check the latest to see what new and improved today.
                dtr
                • MarianM Offline
                  Marian
                  Here are some interesting and cool examples of what can be done with 3d pdf, not necessarily from SU.
                  I've added the direct links to the files here:
                  http://soid.active-servers.com/pdf/tgv%20lyon.pdf
                  http://soid.active-servers.com/pdf/naturtest%20low85.pdf
                  http://soid.active-servers.com/pdf/island%20low%20comp.pdf
                  http://soid.active-servers.com/pdf/gugl90.pdf
                  They came from this blog and site:
                  http://directlight.de/3dpdf.html
                  http://3dpdf.blogspot.com/
                    kwistenbiebel
                    I just installed the trial version of Simlab 3DPDF.
                    Unfortunately, when clicking Plugins/3D PDF/Export, nothing happens.
                    Am I doing something wrong here?
                      ashraf
                      This should be all what you need to do, after that the plugin should ask you for the location of the PDF file.
                      If this is not working please send an email with basic information like the sketchup version, the OS version, and a small description of the error you are getting to support@simlab-soft.com
                      We will make sure that you are up and running.
                      Regards,
                      Ashraf
                        kwistenbiebel
                        Thanks for the support. I just sent you an e-mail.
                          ashraf
                          Mike,
                          We truly appreciate helping us in identifying this problem.
                          There was a problem on some Mac machines, where the plug-in was not able to find a font configuration file.
                          The problem was fixed, so if you had a previous problem with the Mac Plug-in please download the new version and give it a try.
                          Ashraf
                            Mike Lucey
                            Working fine now on the MacBook Pro 👍
                              Mike Lucey
                              I have played around with the settings and think the ones that most achieve a SketchUp 'lookalike' are 'Cad Optimized Lights' which I think is the default and 'Shaded Illustration'. I attach some screen shots of where the settings are along with a sample, Corner Cubby.
                              Mike
                              Corner Cubby.pdf
                              • 2 / 2
