    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
    • Chris FullmerC Offline
      hehehe, yeas, look again, it did work in your model. Like Gai says, hit zoom extents and you will see that the bent version are all floating up above your model.
      I have a bug in the code that sometimes puts the finixhed model in the wrong spot. If you model it on theground, then there is no problem. But if you model it off the ground level, then theree are problems. I never noticed until recently.....I'm a pretty lame programmer. I'll add it to my list of things that need to get fixed on this script πŸ˜•
      • X Offline
        xrok1
        @gaieus said:
        Hi Rocky,
        It does work for me (Zoom to model extents - the resulting geometry - several instances in your model in fact - is much above your initial handle).
        Make your models on the ground plane and the result won't fly to the Moon.
        πŸ˜‰
        well i'd usually make it on the ground but in this case i copied a handle from another model then pasted in place so i could bend it then paste in place back in the original. so i though. πŸ˜†
        Chris, shame on you insulting my favorite programmer. πŸ˜† seriously though you did something no one else acheived and in ver.51 its already one of the must haves out there, thank you. (for your puny earthling efforts 🀣 )
        PS, i'll expect it fixed by monday at the latest! πŸ˜›
        • X Offline
          xrok1
          BTW, i figured out how to do it. if you draw or move your line and curve to 0 in the blue axes, the curved model will appear in the right place. the problem seems to be that the curved model is offset (from) the original the same distance the line and curve are offset from the 0 blue. β˜€
            Hey, thats great to know. I knew there was a bug, but I had never quit figured out what the problem was. Now I know, it is in how it deals with the z location of the line and arc relative tot he ground plane. Maybe that will make the fix a little bit quicker to get around to - maybe.
              danbig
              Hello -
              This is an amazing plugin!
              I can't seem to get it to work, however, on my computer.
              I have Win XP, and SU Pro 7.1.
              I've placed all the plugin files in my plugin folder, and installed progressbar.rb as well.
              When I run the script (just like is shown in the videos), my group deselects, and the message at the bottom of the SU window says "Please select a single line that lies on the red axis." However, I cannot select the line I've placed on the red axis, and I can't select anything else either. The pointer remains the white style, and I end up having to choose the select tool to reset everything.
              Any ideas?
              UPDATE:
              Here's the error from the Ruby Console:
              Error: #<TypeError: cannot convert nil into String>
              C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:158:in create_cursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:158:in make_cursors'
              C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:128:in activate' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:995:in select_tool'
              C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:995:in call' Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
              C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
              C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:173:in onMouseMove'
              SECOND UPDATE:
              My problem was I had all the files in the root plugin folder. This post was all I needed. Thanks again for the amazing plugin.
              @chris fullmer said:
              That sounds like it did not get installed quite right. There should a file called clf_shape_bender.loader.rb in the main plugins folder. Then there should be a folder caled "clf_shape_bender" and inside that folder should exist the files:
              clf_shape_bender.rb
              I'm guessing you might have ended up with everything in the main plugins folder. So manually create the clf_shape_bender folder and move all those files above into it, leaving only clf_shape_bender_loader.rb in the main plugins folders.
              See if that is by chance the problem and let me know, thanks!
                Oh good, glad you found that post and were able to get it working.
                I'm amazed at how many zip programs do not correctly unzip these plugins. The winzip I have at work is one of these that just ignores all folder and subfolder organization inside of .zip files, and just extracts everything to the same folder - very frustrating. And wreaks havoc on plugins dependent on folder organization...But glad its working. Of course, now you have to deal with all the bugs and issues involved with the script πŸ˜„
                  danbig
                  It's worked great so far.
                  Is the plugin supposed to support bending nested components? I had success initially (with a test piece), and then I froze my computer with a 8'x16' plane filled with ~4,000 1/2" holes. πŸ˜„
                  I made a component out of the 1st 1/2" hole, and copied it to fill the area I needed. I then ran the script to bend my sheet, and it froze up on the "explode" part.
                  My goal is to make a sheet of corrugated roofing with 1/2" holes all over it.
                  • X Offline
                    xrok1
                    you may want to use a texture with transparent holes instead! thats a hell of a lot of geometry and calculations for poor ol' sketchup. πŸ˜‰
                    • X Offline
                      xrok1
                      Chris the whole offset issue got me thinking... when you do get back to this plug it would be great if you would look at all the offsets XYZ between the profiles and the group and give the options to place the new object exactly where the old one is, then create a hidden layer for the original group and profiles. just a thought. πŸ˜›
                        @xrok - that is probably do-able. Is it more desireable to have the new shape go where the original was? I prefer it to go to the curve, because I normally use the curve to line it up correctly to a chunk of geometry I had bent it to match up to. But perhaps others would prefer the new shape to sit on top of the existing shape?
                        @danbig - Glad its working. It does support nested components. Though a few months ago I realized that the way I am working with them is EXTEMELY innefficient. So 4,000 of the same component could take a very long time to get through, but it should get through them. Even if SU appears frozen, it is still running. It just freezes SU while its processing. But, there is also not really any real reason to have components inside the shape, since once you bend it, they will no longer be identical components. They all get bent and tweaked in sucha way, that they won't be similar to eachother anymore, and therefore are not able to stay as a single component. So to speed it up, you might just explode all those sub components and then bend it.
                        • X Offline
                          xrok1
                          for me it is, at least to have the option. like i was doing earlier, take a fridge handle from an opened file cut; paste in place in new file, bend, copy; paste in place original file. πŸ˜„
                          that would be good too, but i find it doesn't actually sit on the curve, it offsets from the curve the same amount that the line is away from the group??
                            danbig
                            I played with this strategy as well. The problem I ran into is that when the texture is mapped to a corrugated surface, it looks nothing like the original tile I used to create the texture. Maybe I don't understand how SketchUp maps textures?
                            • jeff hammondJ Offline
                              it doesn't πŸ˜„
                              basically, anywhere you have a line (hidden, softened, or visible), the texture will stop and start again on the other side of the line..
                              in certain situations, it may be possible to achieve what you're after using the eyedropper but i'd have to see the file to see if it would work in your case.
                                pr0bka
                                Hey Chris,
                                Love your plugins again! I've been trying to play around with shape bender, but unfortunately haven't been able to get it to work. The problem is that it gets stuck after i choose the arc to bend it on and shortly afterwards it asks for me to press enter, however when i do, nothing happens, it just gets stuck at 1% (and i'm repeating the bending of a regular box example). I checked the console and this is what it printed out. Also, the visual bending simulation didn't show up as it did in your videos and every part of the plugin is in the right place - meaning clf_shape_bender_loader.rb is in the main plugins directory while clf_shape_bender has its own folder with the rest of the icons/ruby file. If you would like, i can also supply a screen shot.
                                C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:671
                                Error: #<NoMethodError: undefined method /' for nil:NilClass> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in draw'
                                  It is not loading correctly for some reason. That looks errors that were given AFTER you had already activated the tool. Try this, open SketchUp. Open the ruby console. Then click on the shape bender tool. Then copy and paste those errors. I think they will be a little different than the ones you psoted here. Hopefully they will give some better insight in to what is going wrong.
                                  Also, if there are any erros that pop up when you first open Sketchup, copy and paste those here as well. Thanks!
                                    pr0bka
                                    No problem, just tried to load it up again just like you said from the icon this time. i wasn't sure how far up i was supposed to go in the log, but i did notice that whenever i moved my mouse after i specified the arc's and lines new code started showing up in the dialogue, so i had to cancel it right after i pressed enter in order for it to load. maybe a screen shot might help too. Btw, i don't have any errors as soon as i open up Sketchup either. Is it possible i might need to reinstall Sketch up?
                                    ::log::
                                    Error: #<NoMethodError: undefined method all_connected' for #<Sketchup::Drawingelement:0xb56e300>> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:304:in line_picker'
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:236:in onLButtonUp' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:671 Error: #<ArgumentError: comparison of Float with nil failed> (eval):44:in >'
                                    (eval):44:in update' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:533:in exploder'
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:526:in each' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:526:in exploder'
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:244:in onLButtonUp' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:304 Error: #<NoMethodError: undefined method /' for nil:NilClass>
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in draw' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:526 Error: #<ZeroDivisionError: divided by 0> (eval):27:in /'
                                    (eval):27:in update' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:875:in transform_it'
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:288:in onReturn' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:671 Error: #<NoMethodError: undefined method /' for nil:NilClass>
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in `draw'
                                    (eval):27
                                    screenshot+debug right after hitting enter
                                      pr0bka
                                      i also tried doing it on a previous version of sketchup (6.0) and on a different computer.
                                      Here are the specs for computer 1
                                      Intel Core 2 duo, 3 gigs ram, 250 gigs hd, ATI radeon hd 2300
                                      Computer 2
                                      Amd dual core 2200, 1 gig of ram, nvidia geforce 9700 gts
                                      Perhaps i am installing it incorrectly?
                                        It is possibly an installation issue. But it might also be something wrong withhow you are setting up the model. Could you upload a model, like the one in the screenshot?
                                        And you can check the installation. This is from a previous post:
                                        There should a file called clf_shape_bender_loader.rb in the main plugins folder. Then there should be a folder caled "clf_shape_bender" and inside that folder should exist the files:
                                        clf_shape_bender.rb
                                        Upload a model and I'll check it out. Then check the installation according to the info above. We'll get it working,
                                          Justchill30
                                          Im having trouble shape bending a thin surface with rounded edges. After the shape bend the surface has holes on the edges and for the life of me I don't know how to prevent this. Any advice would be helpful. I will attach a ex. of what I am dealing with.
                                          shape bender test 3.skp
                                            I believe that is a scale issue. SketchUp has problem making faces that are very small. I see the missing ones on your model are all under 1/16", which is often too small for SU. So unfortunately, you will probably need to scale the shole thing by 10x and then scale it back down to regular size after you bend it. That is the only workaround unfortunately.
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 60 / 64
