My Bug List for 7.1.4871 Pro
when using hide similar components, the outline boxes of those hidden components are still visible.
the title of the SU instance on the Win XP task bar does not update from untitled.skp to named.skp when saved... only after reopening the file. when using multiple instances of SU, it's hard to tell what the file is on the taskbar.
moving some instances of groups or components is not allowed in another plane without copy (ctrl) being used. then once ctrl has been used once the plane is then active and the copy feature does not have to be used to allow the move into that plane.
when moving some instances of groups or components, inference only works on entities inside the given group.
when committing to a large move or action within sketchup, the program seems to become unresponsive, however it is not... it will finish in time but there is no indication of when or the what the progress is.
the back button in my component browser is missing! (Found) thanks Gaieus! bottom of the component browser on either side backward and forward buttons.
broken SU after using favorites in Component Browser... this is strange bug that greys out most all functions on SU right click after using the favorites.
precision messed up on pointer. I have TripleHead2Go so I don't know if that is part of the issue, but it was not before this update. the pointer seems to pick lines that it is not on top of but only close to.
There is a maintenance release on the way as I heard and hopefully most of the issues will be addressed there. I can't see many of what you list here however.
