    Chess Anyone?
    54 Posts 18 Posters 5.5k Views 18 Watching
    • boofredlayB
      boofredlay
      Better yet, how about I post up a chess model (I can't do the Wobble because it is FF property) and you can download it, make your move then render it with whatever you want. Even straight SU output. The trick is you have to pick a side and never play for the other.
      The other chess board I did here at the beginning of the tread is free and clear. I have others I want to model as well... Give me a day or so and I will have one up. ๐Ÿ˜„
        ScottPara
        Eric,
        The wobble board is great (other than the obvious). One thing that stands out is the repeating table wood texture. With such a close shot a higher res image is really needed. Maybe a bit of bump as well but this is ultra critical ๐Ÿ˜„
        Nice work!
        Scott
        Love the fact that some HATE my avatar.....
        • massimoM
          massimo Moderator
          This is a whole chess game (Kramnik-Topalov, 2003 blindfold) in a single image! ๐Ÿ˜ฎ I just love it. You can read about it here.
          • michaliszissiouM
            michaliszissiou
            Sicilian defense now. Thats why its so beautiful. ๐Ÿ˜†
            • massimoM
              massimo Moderator
              Hmmm...biased like any true Sicilian's player is. ๐Ÿ˜’ ๐Ÿ˜†
              • boofredlayB
                boofredlay
                Ok, here is an update. I fixed the square positions, rounded some more edges, added a base to the board for more weight and changed the chair.
                http://twilightrender.com/phpBB3/download/file.php?id=1703
                • massimoM
                  massimo Moderator
                  Now that's really nice. ๐Ÿ‘
                    I am affraid that you must make another render ๐Ÿ’š (deja vu) ๐Ÿ˜‰
                    Pieces are not on the good side ๐Ÿ˜‰
                    Right case is white that is good ๐Ÿ˜„
                    In classical play King is always the bigger size and has the cross (so it's good)
                    And at the start the Queen is always on its color! ๐Ÿ˜ฎ
                    so your first play is E2 E4
                    But see your image it's D2 D4 ! ๐Ÿ˜ฎ
                    It's very pertubating for a chess player (chees player) ๐Ÿ’š
                    http://www.mychesspieces.com/i/MyChessPieces/ChessBoardInitial_1.jpg
                    You can answer that is a retrograde analysis problem but I doubt that is that you want make ๐Ÿ’š
                    And don't know if this position has a solution ๐Ÿ˜‰
                    ps I understand your error of the first post: original had the same ๐Ÿ’š
                    http://www.marieclaire.com/cm/marieclaire/images/U_Wobble-ChessSet-med.jpg
                    • boofredlayB
                      boofredlay
                      Thanks Frenchy. I have to keep you guys guessing... ๐Ÿ˜’ ๐Ÿ˜†
                      • david_hD
                        david_h
                        Gorgeous .. .now go and get it built and market it. I'd buy one! ๐Ÿ‘
                        • boofredlayB
                          boofredlay
                          Then go ahead... ๐Ÿ˜„
                          http://www.umbra.com/ustore/product/377601/c656/wobble_chess_set.html
                          • david_hD
                            david_h
                            Well that breaks my heart. I thought you came up with that.
                            I ain't got $300. ๐Ÿ˜ž
                            • boofredlayB
                              boofredlay
                              And here is the final.
                              http://twilightrender.com/phpBB3/download/file.php?id=1709
                                d12dozr
                                Oooooooh......and Awe! Wow, what an improvement from the original. Great work, Boo!
                                http://goo.gl/f7ooYh
                                • Alan FraserA
                                  Alan Fraser
                                  Excellent render, Eric. I'd love one of those chess sets...not that I play chess all that often, but all the little hollows would be great for preventing Doritos crumbs from spreading all over the place. ๐Ÿ˜‰
                                  3D Figures
                                  • C
                                    Click Draw
                                    Eric,
                                    With the amount of liquor in that glass, I doubt you'll make it to the end of the game. Awesome render....!!
                                    Jeff
                                    Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                                    • michaliszissiouM
                                      michaliszissiou
                                      Wrong again. The keys, are the wrong keys ๐Ÿ˜†
                                      Great render Boofredlay ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                      • boofredlayB
                                        boofredlay
                                        ๐Ÿ˜„ Thanks. It must be apple juice then. I would hate to get drunk then see the pieces wobble on that board ๐Ÿ˜ฎ ๐Ÿ˜ฒ ๐Ÿ˜• ๐Ÿคข ๐Ÿ˜ณ
                                        • 3 / 3
