    SU Ruby Cheat-sheet
    19 Posts 5 Posters 6.4k Views 5 Watching
      remus
      You thinking of Scotts objects diagram? http://code.google.com/apis/sketchup/docs/diagram.html
      If so it only has classes and observers, not methods.
      • alexschreyerA
        alexschreyer Extension Creator
        I made another version of the same sheet. This one is more condensed and prints on three pages.
        404 Not Found
        (www.alexschreyer.net)
        I think it would be a great addition to a cheat sheet to have a sample mini-plugin added as well. Is there already an accepted "framework" out there?
        Cheers,
        Alex
        Author of "Architectural Design with SketchUp":
        http://sketchupfordesign.com/
          Jim
          I wonder how it would look in a compact little WebDialog.
          • chrisglasierC
            chrisglasier
            ... a compact animated little WebDialog like this perhaps, where coding terminology is substituted for names of real objects and groupings:
            • alexschreyerA
              Good idea to put it into a webdialog. Actually, Jim, you could add a list of objects/methods to your webconsole and make those clickable so that they automatically get inserted into the editor.
              FYI: I updated the cheatsheet for the new (7.1) functions.
              Cheers,
              Alex
              • chrisglasierC
                chrisglasier
                @alexschreyer said:
                ... Actually, Jim, you could add a list of objects/methods to your webconsole and make those clickable so that they automatically get inserted into the editor.
                I think it possible to double click on a machine name to insert into your webconsole. Perhaps we can "discuss" over the newly-found collaborative editor?
                  Jim
                  Alex, can you share the data used for the cheat-sheet? It would save some work for sure. Chris Glasier and I would like to experiment with creating a dialog.
                  • alexschreyerA
                    Great to hear you want to try this out. I'll post a text file with the entire list later today.
                    Cheers, Alex
                    • alexschreyerA
                      Here ya go. This file is the 7.0 list, so you'll have to add the new functions.
                      Cheers,
                      Alex
                      sketchup_ruby_functions.txt
                      • chrisglasierC
                        chrisglasier
                        Web dialog people please see this post.
                        • chrisglasierC
                          chrisglasier
                          Here is a first shot at marrying the looks and basic funtionality of a screen machine with Jim's web console.
                          Both are separate and both can be moved and resized independently.
                          The console's textareas are set proportionately but the menu space is fixed. Perhaps there could be another menu item for preferences and another to open the machine. Both are cosmetic.
                          I think the machine will have three columns to start with:
                          1 - Display options - abc, frequently used, switch, console display options (parent, words, snippets, comments, complaints - the menu in the console would need to change to suit). Maybe display options could be done with tabs in the console but they will take needed space.
                          2 - Classes
                          3 - Methods
                          The columns of course move so no need for scrollbars.
                          But all can be changed!
                          edit: added: http://collabedit.com/display?id=38563
                          • chrisglasierC
                            chrisglasier
                            We are at the stage now the basic functionality has been completed as indicated here,
                            Manual highlight in plain text record
                            to open up the work to see how to offer the widest set of options related to the API through interaction between machine and console.
                            I see the next main task is to set up console display transformation from the plain text record and a system for anyone to contribute content and/or devices. Here's a brief description of the options currently in the first slider:
                            Classes - in centre slider - click to navigate*, show methods and register selection. Click method to navigate and register selection
                            Methods - in centre slider - click to navigate*, show classes and register selection. Click class to navigate and register selection
                            *see machine animation attached
                            Plugins - sorting options in centre (including myPlugins); list in right; details of selected in console; plug in plugin(?)
                            Update - API additions like in 7.1 - input in console; lists updated in machine
                            No output - use machine as associative index only. Web console can always also be a standalone application
                            Insert - send concatenated selection to console.
                            Snippet - send snippet related to selection to console. Use console to add or edit snippets.
                            Comments - Review, add or edit comments related to the selection
                            Inspect record - Sends record to console; highlights class and method entries
                            The Ruby Web Console was made by Jim and the API Machine by me. Jim and I worked closely to achieve the interaction so far. We would be happy to work with others to further develop the combination.
                            • alexschreyerA
                              Looks great!
                              Cheers,
                              Alex
                              • chrisglasierC
                                chrisglasier
                                Progress pic:
                                deviceAPI with listsApi extension
                                • chrisglasierC
                                  chrisglasier
                                  The nsetSketchupApi plugin is in a separate topic reserved for downloading, updates and technical questions and answers. Another topic "[WebDialog]Behind nsetSketchupAPI" starts a discussion on the potential of such an approach.
                                  But here I just want to thank Alex and Jim for prompting the development of an alternative type to Alex's cheat sheet; one that is based on animating words in a small machine-like interface rather than more familiar digital versions of paper pages.
                                  Most of all though I must thank Jim, ungenerously described as code adviser in the files, for teaching me about json, easing and all these things, but mostly for how to turn my cavalier code into something understandable and stable.
