    [Plugin] LaunchIt v 1.4 (14 oct 2009)
    30 Posts 12 Posters 43.8k Views 12 Watching
      remus
      Really cool idea, just going to try it out now πŸ‘
        remus
        Hmmm, im not getting the web dialog popping up...
          Jim
          Cool idea. I have been thinking that Chris Glasier's scene machine dialog would make a good replacement for the Plugins menu, too.
          • G
            gavvy
            oh no
            i have get an error ,i can't lunch it
            πŸŽ‰
            error code Display this
            Error: #<NoMethodError: undefined method visible?' for nil:NilClass> j:/Google SketchUp 7/Plugins/A4_launchit.rb:73:in launch_it'
            j:/Google SketchUp 7/Plugins/A4_launchit.rb:109
            j:/Google SketchUp 7/Plugins/A4_launchit.rb:109:in `call'
            • G
              gavvy
              πŸ˜†
              I have look at your ruby script ,
              πŸ‘ πŸ‘
              and now i want to add some scripts to get funcitons form a command txt files
              Good job
                a4chitect
                gavvy thanks for letting me know, I have changed the script - so hopefully the mentioned error is gone now.
                • G
                  gavvy
                  a4chitect
                  πŸŽ‰
                  i have null serieal lines
                  def launch_it
                  if($launchitdlg.visible?)
                  $launchitdlg.close
                  return false
                  #puts $launchitcmd
                  #$launchitcmd.uniq!# FF_whatis the usage????? FF_nul
                  functionlist = "var functionlist = Array("
                  functionaction = "var functionaction = Array("
                  I just NULL it AND IT work WELL πŸ˜†
                  • G
                    gavvy
                    here is the change of mine !
                    I add these to change the command list easy ,but is there any ways to read the command listfile directly?
                    AND the attachment is the plugin-GUI I changed
                    Ps: I think doubleKlick is better than oneclick πŸŽ‰
                    #命什ε…₯ε †
                    @Cpath = File.dirname(FILE)
                    @Cbarset = Set.new
                    Ctbs = Dir[@Cpath +"/A4_launchit"+ "/*.txt"]
                    Ctbs.each do |tb|
                    IO.readlines(tb).each do |cmd|
                    next if cmd[0, 1] == "#"
                    #cmd, cmt = cmd.split("#")
                    next if cmd.nil?
                    cmd.strip!
                    @Cbarset = @Cbarset.insert cmd
                    	@Cbarset.each do |ca|
                    		$launchitcmd.push ca.split("|")[0..1]
                      a4chitect
                      great stuff! it's cleaner to have commands in a separate txt. I suggest you share your whole script (as a branch?)
                      Does anybody have experience with online code hosting ? like code.google.com ? Is there a branching feature to allow deviation from the main code ?
                      Regarding your question about automatic command extraction, I think this could be done by using the IO.readline to read all plugins and look for the lines which populate the menu and context (right-click) menu.
                      As I wrote in the first post, look for the
                      .add_item("
                       string in all the rubies, after the double quote, there usually is a command name, and the action
                      • tbdT
                        tbd
                        nice work a4chitect and thanks for putting my scripts as an example πŸ˜‰
                        I like github.com for hosting source and allows forking and if you want to learn about check the online book about Git
                        http://plugins.ro
                          a4chitect
                          tbd: you're welcome. will look into the github, thx
                            stanmarsh
                            hello a4rchitect,
                            i was just thinking if this could combine and work with pluginloader by alexschreyer to load plugins, then use launchit as the front-end.
                            pluginloader link
                            http://www.alexschreyer.net/projects/plugin-loader-for-sketchup/
                              remus
                              Added a load of plugins but only one ever shows up by adding the
                              if(defined? $launchitcmd == nil)
                                 $launchitcmd = []
                              $launchitcmd.push ["Command name","Command action"]
                              Bit, but only one ever shows up.
                              seems to be in alphabetical order, so weld.rb was the only one that would load, moved out of the folder then it was webconsole.rb and so on.
                              Any ideas?
                                Jim
                                don't let this stop you from working on the plugin. Distributed version control software is nice, but can have a lengthy learning curve (my experience, at least.) If you're in it for the long haul, then learning to use git or mercurial is well worth the effort. If this is an occasional endeavor - maybe not so much.
                                  Jim
                                  I was playing around with speech, and this could turn out to be a good interface for voice command control of SketchUp. It's not quite working - I can speak the word and it gets typed in the filter box, but for whatever reason the list is not filtered.
                                  • jeff hammondJ
                                    doesn't seem to work on macs too well but... πŸ˜„
                                    this is built into OS X (it's not SU specific.. all apps have this ability)
                                    same deal, start typing some letters and all the options start popping up etc.. if you hover over a command for a second, it's path will be shown as well.. skindigo, fredo, etc works fine too..
                                    it's also sort of smart in that it won't display commands that aren't possible at the time (for instance, redo won't show up in the search if there's nothing to redo)
                                    i don't have anything to test it with but i'm almost positive voice cmmd will work.
                                    [flash=640,385:3v2nt73s]http://www.youtube.com/v/1HBmYx3w3W0&hl=en&fs=1&rel=0&color1=0x2b405b&color2=0x6b8ab6[/flash:3v2nt73s]
                                    i'll add this.. it's a cool feature but the only time i use it is for obscure commands or when learning a new app.. once you know an app, shortcut keys are way better..
                                      a4chitect
                                      Jim: I suppose that using speech for input doesn't trigger the OnKey event in the javascript - to perform the search
                                      Jeff: I envy you - because the built-in OS X functionality looks great. The whole purpose and idea of launchit was, that my plugins menu won't fit on the screen anymore, and gets 'randomized' very often - because of new plugin installations. I agree that using keyboard shortcuts is way better. I think that Google should consider integrating the shortcut preferences into the GUI. It provides the functionality of searching for commands already, but serves only to assign shortcuts.
                                        Jim
                                        How's the git repo coming?
                                          a4chitect
                                          Jim: I gave up on git or any other code repos for the time being. This plugin would probably not get developed by anyone else πŸ˜„
                                            Jim
                                            I can understand. But I did actually want to look at this as the menu for a "Protable Plugins" project to create a plugins folder people can carry with them on a portable device.
