    SketchUp+Ivy
    15 Posts 4 Posters 4.0k Views 4 Watching
    • F
      fabiorossi
      obj file imported into Blender isn't mapped map, but isdivided into three parts, branches, primary leaves and secondary leaves, obtained by exporting the same division at KT, but this is not a problem because the mapping is then very easily after ; the key issue is that large files do not come in SketchUp; I did a test on a 3DS file of 9 MB and I managed to import it up but then I nn sharing model branches, foliage primary and secondary leaves. This makes it even more difficult the whole issue
      my blog
      http://progettin3d.blogspot.com/
      • soloS
        Can you send me the file?
        pete (at) solosplace (dot) com
        • F
          fabiorossi
          http://www.mediafire.com/?sharekey=134aa94b551277b3e7c82ed4b8f0c380e04e75f6e8ebb871
          my blog
          • soloS
            No problems, it just needed mapping, as mentioned above.
            http://img24.imageshack.us/img24/3750/ivycolle.jpg
            • F
              fabiorossi
              thanks a lot! the file shared on the forum, however, its ok also by v-ray! This was to test as SU takes easily small Kb and I have problems with that large and I'm trying a road that seems to be winning: separate branches of the foliage in blender and export separately, I made a first attempt and it seems work very well, I still have some problems with the grows thats are exported in small numbers than original!
              my blog
                Interest of Ivy is that you can put another things than leaves πŸ˜„
                http://forums.polyloop.net/imagehosting/196460150c38ba97.jpg
                • soloS
                  Great to hear you are coming right.
                  Pilou, you are correct, once the direction of original mesh is mapped you can substitute the Ivy leaf for any .png image, I do that with Vue trees all the time.
                  • F
                    fabiorossi
                    here is the progress, I have exported separately branches and foliage, and this time it went well ........... but now the issues are the mapping of the leaves , it is difficult to map them all together, that makes slows or stops SU......the problems are over!
                    my blog
                    • F
                      fabiorossi
                      .....and this is the render by v-ray........the mapping needs still more accuracy
                      my blog
                      • soloS
                        looking good mate, if you want send me the Ivy only and I will map it for you.
                        • F
                          fabiorossi
                          thanks a lot da solo!
                          my blog
