    My first model and render
    10 Posts 7 Posters 704 Views 7 Watching
      sandra_palega_N
      Hello,
      I am new on this forum and I would like to show you my first model of modern lamp which I have made yesterday. It is also my first model ever I have made and first in sketchup.
      ps. rendered in kerkythea.
      301 Moved Permanently
      (www.vimeo.com)
      • F Offline
        fymoro
        Welcome,
        Nice and clear render... ๐Ÿ˜‰
        http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
          d12dozr
          Welcome, Sandra! ...and excellent job on the render and animation even though I can't see that lamp in my room ๐Ÿ˜„ Maybe next time don't let the studio setup show in the render ๐Ÿ˜‰
          My last question - could you show the light from the lamp? Hopefully that will that be in your next set of renders? Good luck!
          http://goo.gl/f7ooYh
            Welcome Sandra - indeed a nice "first model"!
            @d12dozr said:
            ...My last question - could you show the light from the lamp? Hopefully that will that be in your next set of renders? Good luck!
            Yes, this would be the more interesting part; to see how the light comes through those transparent balls or what. If you experiment with this, make sure to use some higher presets in Kerkythea (and if it takes rather long, render smaller images instead for testing)
              dylan
              How do you stop it showing at various angles, is there a trick to this?
              http://dmdarchitecture.co.uk/
                d12dozr
                For the still renders, you could make the physical studio bigger so the edges don't show, or you could rotate the model within the studio for each shot. The animation would be trickier - you'd have to make an enclosed studio, and make your animation inside (but I'm not familiar with Kerkythea animations so that may or may not work.)
                • EddyNLE Offline
                  EddyNL
                  Welome! Nice render and animation.
                  Something tells me you've done this before...
                  viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
                    @d12dozr said:
                    ...The animation would be trickier - you'd have to make an enclosed studio, and make your animation inside (but I'm not familiar with Kerkythea animations so that may or may not work.)
                    And what if you turn the whole studio into a face-me component which rotates with the camera while you are "flying around" the object?
                      d12dozr
                      Even better, Gaieus! Thanks for that trick ๐Ÿ’š
                        Cyberdactyl
                        Very cool choice for your first post!
