    Color by Layer trick
    5 Posts 4 Posters 548 Views 4 Watching
    • N Offline
      NewOne
      I don't know if you are aware of this, but in case you aren't...
      The layer color can be texture! 😄 Just figured this out a minute ago, when playing around in SU.
      • E Offline
        Ecuadorian
        Wow, it's new for me, too, thank you for the tip!
        This is good for SketchUp-only output, but if you plan to ever render your model, it's best practice to apply colors and textures directly to front faces, as thomthom says.
        -Miguel Lescano
        • E Offline
          ericschimel
          That is a nice way to "Diagnose" layering issues...
          I do a lot with layers, using them to show different options in my designs... Sometimes when you can't figure out what layer an object is on, making it yellow, or red can help you find it...
          -Eric
          http://plugin.sketchthis.net
          Sketchup Kitchen Design Plugin
          Custom Models
          • Chris FullmerC Offline
            Your color is not a color at all though, its a material. Right? That's new to me if it is. I'll need to investigate.
            • N Offline
              NewOne
              Yes Chris... this is actually the trick! The color can be a material! And just in this second i have some ideas about how this feature can be exploited. 😄
